Re: Rear Diff Lubircant
[Re: flatiron]
#1125171
12/02/11 02:43 AM
12/02/11 02:43 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Just about anything is going to be adequate for gears. additives and modifiers are aimed at sure grip (and especially clutch style) units that rely on a specific amount of friction and lubrication as part of how they physically operate.
[Re: StealthWedge67]
#1125172
12/02/11 04:00 AM
12/02/11 04:00 AM
Posts: 30,494 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
x 22 .... I would use the LIGHTEST gear-oil I could find ... in a track-only car.
[Re: flatiron]
#1125176
12/02/11 03:30 PM
12/02/11 03:30 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Use the best stuff you can afford, especially when drag racing There is a major difference in results
[Re: dOc …]
#1125177
12/02/11 06:14 PM
12/02/11 06:14 PM
Quicktree
Check out the Red Line ShockProof gear oils. http://www.redlineoil.com/product.aspx?pid=44&pcid=4
....at 15 beans per quart ...when not really needed ?? .... THIS STUFF (like Amsoil and Royal Purple) ....is just way over-priced gimmicky oil products that are not needed in a properly maintained vehicle.
how much bracket racing have you done? It makes a difference
[Re: dogdays]
#1125180
12/02/11 10:00 PM
12/02/11 10:00 PM
dOc …
Florida STAYcation
Doc, take your pills, you are sounding cranky. Redline is good stuff. If you can't afford another $30 for lube, maybe you shouldn't be racing!
R. (I admit, I can't afford to be racing.)
YOU sound BROKE-AZZ Double-d ....
You must be spending tooooo much of your money on GIMMICKY snake-oil stuff ...
[Re: dOc …]
#1125182
12/03/11 12:25 AM
12/03/11 12:25 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The RedLine ShockProof oil is to protect the gears on hard launches. I'm not sure if the original poster would need the extra protection or not. I have used the medium weight (yes, the oil is actually blue) in a 2002 Ram 1500 with the 4.7L with no problems and picked up a bit of fuel mileage too. I use the regular RedLine 75W140 GL-5 in my Ram 3500, and the 75W90 in the Charger and Coronet.
I think the Redline oil costs less than Amsoil or Royal Purple?
A short white paper on the ShockProof oil: http://www.redlineoil.com/content/files/tech/ShockProof%20Gear%20Oil%20Tech%20Info.pdf
[Re: rickraw]
#1125185
12/03/11 01:07 AM
12/03/11 01:07 AM
dOc …
Florida STAYcation
i use royal purple 75/90w synthetic. cost a little more, but i think it's worth. why skimp on lube. u wouldn't put some cheap crap in ur tow vehicle would u?? seeya.
YURR tow-vehicle is far more critical for the sure-grip additives and such than a 1/4 mile drag-strip car ..
