Re: Slick size,, Is bigger better? [Re: ram87] #1124627
12/01/11 02:24 PM
12/01/11 02:24 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Remember, the larger the tire, the less grip as measured in lb. per sq. in. due to the contact patch and putting a narrower tire (same circ.) increases grip for the same reasons. Just some food for thought.
Re: Slick size,, Is bigger better? [Re: AndyF] #1124628
12/01/11 02:27 PM
12/01/11 02:27 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Call a couple of the tire mfgs and see what the tech reps recommend. Tires are engineered to handle a certain amount of weight so I'd think that if you told them the weight of your car, the weight distribution and the amount of power they could quickly recommend the best size for your car.
This. Goodyear recommended the tire I just put on and I probably would not have chosen it due to it's size and compound but the new best 1.16 60' doesn't lie!!
Re: Slick size,, Is bigger better? [Re: ram87] #1124629
12/01/11 04:46 PM
12/01/11 04:46 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I agree with Doc Fiberglass. I had a set of 33 X 18.5 X 15 M/T's on my truck. Changed to 28 X 11.5 X 15 Hoosiers and picked up .3 in the 1/8 mile. Didn't have a traction problem with either and 60 ft. wasn't that much different but sure picked up the last 1300' with the smaller tire.
You went from a 33" to a 28" slick, did you change your gear ratio to keep your roll out the same?
Re: Slick size,, Is bigger better? [Re: SCDaytona] #1124630
12/01/11 06:39 PM
12/01/11 06:39 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
VERY good point ...and VERY true.
I wish I could find some more of those 7" Firestone cheater slicks I got at Greenfield Tire in Detroit many years ago. It did not have the "look" of a 10" tire ... but those tires "worked" !
A touch over stock 440 in my 62 ... cast iron mans and Imperial muffs .... 111 mph. And I credit those tires for a big-part of that.
Re: Slick size,, Is bigger better? [Re: CRT] #1124631
12/01/11 07:06 PM
12/01/11 07:06 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Thanks,John!...REAL NICE! Hope to see it in 2013! BTW...will it be red again?
Re: Slick size,, Is bigger better? [Re: Labratt] #1124632
12/01/11 07:11 PM
12/01/11 07:11 PM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
John..what size slicks were on the Coronet..in the pics of it on the lift? They look HUGE!
Re: Slick size,, Is bigger better? [Re: Dragula] #1124633
12/01/11 07:54 PM
12/01/11 07:54 PM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
Dragula - I did not change the gear ratio 4.88's with both. Guess I could change to the 5.14's in my little truck but this was just about tire size. Not sure that I have enough RPM in the big truck for the lower gears and shorter tires.
Re: Slick size,, Is bigger better? [Re: Dragula] #1124634
12/01/11 09:25 PM
12/01/11 09:25 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
[quote
I have to say bigger is better. I was running small tire cars for a while and went to a Duster with a 17x33, and it always hooks with the 512RB, even on marginal burnouts. It makes bracket racing that much more consistent, and we took home some money this year and more than a couple of events. I am kinda dreading putting my new engine back in my 72 Cuda due to the 9.5" slicks on it....
For those who went to a bigger tire, was there any change at the end of the track. More or less stable??
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Slick size,, Is bigger better? [Re: SCDaytona] #1124635
12/01/11 10:10 PM
12/01/11 10:10 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
This always AMAZED me,,,I know it is Physics 101,,,but,,if it was right and worked like they say it should work,,why don't TF cars run a tire 3" wide....???...more lbs/bite per sq. inch..?? I am not making fun of the OP,,but I have had some interesting discussions/arguments with my kids' friends who were into Physics and thought they knew it all. I didn't have an answer or explanation for them as why the wider/bigger tires worked better,,,just "because that's the way we do it"!!!!
If you like drag racing, support your local track.
Re: Slick size,, Is bigger better? [Re: CHAPPER] #1124636
12/01/11 11:32 PM
12/01/11 11:32 PM
AndyF Offline
AndyF  Offline
They don't cover how a tire works in physics class because it is a specialized topic. A sticky tire works kind of like velcro, especially on a concrete track. In physics class they cover the "classic" friction situation of hard surfaces sliding over each other. With velcro, the more surface area you have then the more friction you have. Tires are not exactly velcro, but it is one way to think about the issue.
Tire design is actually a very complex subject. That is why my advice to the OP was to call the tire company tech line and ask for advice.
Re: Slick size,, Is bigger better? [Re: SCDaytona] #1124637
12/01/11 11:46 PM
12/01/11 11:46 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Given a perfect world. Of coarse it has to. Everything else is constant.. Say same HP, same weight same compound, it has to "Try" to plant the smaller foot print, of coarse it has to "Hold" more than a larger foot print tire. That's the point of larger tires, less force for a given area, means less likely to spin.
Its more like Cohesion than adhesion as via Velcro.
Fact is you use a good 13x31 or 14x32 tire on the car it will be more consistent in any track condition, you might give up a little e/t due to rotational weight etc, which if your spinning on a marginal track what e/t is there anyways to loose except for the round of coarse.
Re: Slick size,, Is bigger better? [Re: Bob_Coomer] #1124638
12/02/11 01:12 AM
12/02/11 01:12 AM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Great that some are willing to think about what I posted. Now throw in rim widths and that affects the footprint especially at launch. Now take a look at the ADRL guys and 10.5W X33X16 tires hitting them with way over 1000 Hp and getting them to work with beadlocks. They use a wide rim allowing for a better footprint. My take with all this is you tire the car for the combination. Why buy way oversize tires when you can get away with a smaller tire and still be consistent. Every car is different and my car with 14.5 X 33 is faster and just as consistent than the 16x33 tires I ran before.
Re: Slick size,, Is bigger better? [Re: SCDaytona] #1124639
12/02/11 02:24 AM
12/02/11 02:24 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I would run Top Fuel tires if they would fit
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Slick size,, Is bigger better? [Re: Irun5snd8th] #1124640
12/02/11 03:42 AM
12/02/11 03:42 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I would bet, more money and R&D go into a 10.5 tire than any other racing tire except maybe for nascar
Re: Slick size,, Is bigger better? [Re: sixpackgut] #1124641
12/03/11 11:28 AM
12/03/11 11:28 AM
farmingdale ny 11735
blracing Offline
blracing  Offline
for bracket racing (consistancy)the biggest tire you can fit is the way to go! it may be slower than a smaller tire, but if your interested in win lights, go big! build the car to take a big tire, you can always put a smaller tire on, not the other way around.
