Slick size,, Is bigger better? #1124607
11/30/11 08:58 PM
11/30/11 08:58 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
I have been racing my 63 on 10.5Ws for years, track prep must be near perfect for the car to hook. I am in the process of building my 68 Coronet, and I now can fit a 16x33 tire under the car, I have yet to buy wheels & tires, So my question to the racers here, is a bigger tire better? I ask cause some say that a large tire can slow a car down. What would be the perfect wheel tire combo?
The car should run high 9s to 10 flat.
and should weigh in at 3300 lbs.
Re: Slick size,, Is bigger better? [Re: CRT] #1124608
11/30/11 09:01 PM
11/30/11 09:01 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have to say bigger is better. I was running small tire cars for a while and went to a Duster with a 17x33, and it always hooks with the 512RB, even on marginal burnouts. It makes bracket racing that much more consistent, and we took home some money this year and more than a couple of events. I am kinda dreading putting my new engine back in my 72 Cuda due to the 9.5" slicks on it....
Re: Slick size,, Is bigger better? [Re: Dragula] #1124609
11/30/11 09:10 PM
11/30/11 09:10 PM
Chi-Town
PlumCrazyCharger Offline
Chi-Town
I have a set of Weld Alumastar rims and slicks for sale. Rims are 15"x16" and have Goodyear 17"x33" slicks. About 35 TS passes, probally 50 to 75 passes left on a Super Pro Car.
Re: Slick size,, Is bigger better? [Re: Dragula] #1124610
11/30/11 09:11 PM
11/30/11 09:11 PM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
I went from 13x31 to 14x32. I lost nothing. If anything I picked up.
Shawn Jennings
Re: Slick size,, Is bigger better? [Re: 572_dup2] #1124611
11/30/11 09:22 PM
11/30/11 09:22 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I found the opposite effect with the opposite change,, on my old car. Went from 14x32 to 13x31 and got quicker. My opinion/belief is,, the smallest tire that will still get you hooked and going, will probably be your quickest times. Smaller tire, smaller/lighter wheel=less rotating weight,,,rotating weight(1#=4/5# static weight) the motor thinks it is in a lighter car=quicker ET..
If you like drag racing, support your local track.
Re: Slick size,, Is bigger better? [Re: CRT] #1124612
11/30/11 09:23 PM
11/30/11 09:23 PM
NC
440Jim Offline
440Jim  Offline
NC
Always tub it to fit a little bigger, but IMO a 14x32 should be just fine. And 14 or 15 wide rims.
From what I have seen, the best 10.5 tires are 31" or 33", not the 29.0-29.5. Again use a wide rim.
Re: Slick size,, Is bigger better? [Re: CHAPPER] #1124613
11/30/11 09:44 PM
11/30/11 09:44 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Re: Slick size,, Is bigger better? [Re: 440Jim] #1124614
11/30/11 09:45 PM
11/30/11 09:45 PM
tboomer Offline
tboomer  Offline
John...What do you 60' at? My M/Ts in a 10.5w x 31" have a best of 1.385 but usually runs about a 1.4x...
Re: Slick size,, Is bigger better? [Re: CRT] #1124615
11/30/11 09:58 PM
11/30/11 09:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would use a 14 X 32... plenty of choices on that size
Re: Slick size,, Is bigger better? [Re: 440Jim] #1124616
11/30/11 11:38 PM
11/30/11 11:38 PM
PA
moparacer Offline
moparacer  Offline
PA
Yep I am also starting to think a wider rim is better as it lets you run more air pressure in the tire without pushing the center of the slick up.
Going to experiment with it in the spring when I buy a new set of slicks for my car.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Slick size,, Is bigger better? [Re: moparacer] #1124617
11/30/11 11:45 PM
11/30/11 11:45 PM
Lehigh Acres, Florida
rickstershemi Offline
If you're bracket racing then yes
Rickster
Re: Slick size,, Is bigger better? [Re: MR_P_BODY] #1124618
11/30/11 11:45 PM
11/30/11 11:45 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
If the rules for any class stated any size tire allowed, the 10.5 classes would disappear. It's all manufacturered hype. The biggest tire car, will always be a more consistent winner.
Re: Slick size,, Is bigger better? [Re: Leigh] #1124619
12/01/11 12:24 AM
12/01/11 12:24 AM
sg66mopar Offline
sg66mopar  Offline
Do you want your car to repeat or go as fast as possible every once in a while? Cars that repeat win rounds. I run 16x32s and would go bigger if there was room.
Re: Slick size,, Is bigger better? [Re: CRT] #1124620
12/01/11 12:43 AM
12/01/11 12:43 AM
AndyF Offline
AndyF  Offline
Call a couple of the tire mfgs and see what the tech reps recommend. Tires are engineered to handle a certain amount of weight so I'd think that if you told them the weight of your car, the weight distribution and the amount of power they could quickly recommend the best size for your car.
Re: Slick size,, Is bigger better? [Re: CRT] #1124621
12/01/11 12:58 AM
12/01/11 12:58 AM
It probally depends on the type of rear suspension, weight distribution and amount of torque and HP My Duster hooks well on 13.50x30 x15 M/T ET Streets on 12 inch wide rims, it hooks better on M/T 10.5x31x15W on ten inch rims. 4.10 gears. The car weighs right at 3450 lbs. with me in it,49.6 % on the rear tires, ladder bars and double adjustable Strange coil overs with a 150 lb springs, 1.39 best 60 ft. times, 9,993 ET at 134.45 MPH Several of the old time SS, gas and modified production record holding racer always said to run the smallest tire possible that would hook the car up to go the fastest possible, including John Diana(SP?)
Re: Slick size,, Is bigger better? [Re: CRT] #1124622
12/01/11 01:16 AM
12/01/11 01:16 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
John...you remember the Duster...that had 31x13.5x15's...it hooked super hard..
my 63 has 32x14x15's on 15x15 rims w/4" back space...they are Goodyears just like what was on the Duster...these havent been on the track...just ideas..
Im wanting 33x17's ...but as DOT's
Re: Slick size,, Is bigger better? [Re: CRT] #1124623
12/01/11 01:34 AM
12/01/11 01:34 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
John,best of Luck finding the right wheel/tire combo for that NICE Coronet! Could you PLEASE post more pics of it? Thanks! Randy B.
Re: Slick size,, Is bigger better? [Re: CRT] #1124624
12/01/11 06:53 AM
12/01/11 06:53 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
You want to go the fastest and quickest ? ... put the smallest tire you can on it. But if you have consistent hook-issues and you are just going to bracket race it ... the steam-roller tire and look is the plan.
REMINDS me of a customer I had some years back .... 70 Cuda - 10.90 car ...good 440 ... used to get his 9" tires used from a stock-elim guy. He came into some money ... and wanted that steam-roller look ... so he put on some 14x32's and all the expense that goes with that(and "corrected" the gear)... and the car slowed up a BUNCH ... .250 and 3 or 4 mph ... IIRC ..
If you don't need the tire in the first 20 feet ... it is going to HURT YOU in the next 1300 feet ...
Re: Slick size,, Is bigger better? [Re: dOoC] #1124625
12/01/11 11:45 AM
12/01/11 11:45 AM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
I agree with Doc Fiberglass. I had a set of 33 X 18.5 X 15 M/T's on my truck. Changed to 28 X 11.5 X 15 Hoosiers and picked up .3 in the 1/8 mile. Didn't have a traction problem with either and 60 ft. wasn't that much different but sure picked up the last 1300' with the smaller tire.
Re: Slick size,, Is bigger better? [Re: Labratt] #1124626
12/01/11 02:02 PM
12/01/11 02:02 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
I bought the car in 1989, painted it in 1991, I raced the car from 1991-2005 when I bought the 63.
It almost ready to go on the rotisary, then finish the new cage, and off for paint. I hope to have it ready by 2013
Thanks for the replys
