Coolant through the tailpipe: what's the cause? #1124145
11/29/11 05:33 PM
11/29/11 05:33 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
So after replacing a leak in my power steering pump, I tried to start my car and it wouldn't fire. Then, my battery died and couldn't be revived. One new battery later, I realized that my car still won't start. Then I see it: the Green Puddle of Death underneath my driver's side tailpipe.
So here's where the poll comes in...Is it a head gasket? (It's a 11.5:1 compression engine but the gaskets are less than 2 years old)...Is it a crack in the cylinder? (They're .055 over bore)...Or is it a crack in the aluminum Indy SRs?
The polls are open and the results will be revealed later this week.
Why is there coolant in my exhaust?
single choice
Crack in cylinder
9%, 3 Votes
The coolant fairy put it there while I was sleeping
46%, 16 Votes
Crack in head
20%, 7 Votes
Blown head gasket
26%, 9 Votes
Total Votes: 35
Voting on this poll ends: 12/11/11 04:31 PM
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Coolant through the tailpipe: what's the cause? [Re: 1968RR] #1124146
11/29/11 05:37 PM
11/29/11 05:37 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
You won't know till you pull the head. Hopefully it's just the gasket!
good luck, john
Re: Coolant through the tailpipe: what's the cause? [Re: 1968RR] #1124147
11/29/11 05:40 PM
11/29/11 05:40 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Does one of your PS bracket bolts go into the cylinder block or head. If so, you might have screwed a bolt in too deep and punched into a water jacket.
That would be the coincidental explanation.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Coolant through the tailpipe: what's the cause? [Re: 1968RR] #1124148
11/29/11 05:44 PM
11/29/11 05:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a pressure tester on the radiator and see if
you hear the leak.. might zero you in closer
Re: Coolant through the tailpipe: what's the cause? [Re: 471Magnum] #1124149
11/29/11 05:46 PM
11/29/11 05:46 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i voted for the fairy. (that guy is everywhere) i'd add some uv dye to the radiator, run it for a bit, then look for the leak(s), in case it's something smaller than easily seen with the nekkid eye.
Re: Coolant through the tailpipe: what's the cause? [Re: 1968RR] #1124150
11/29/11 05:52 PM
11/29/11 05:52 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
The car won't turn over, or just won't start? If there's fluid in a cylinder, the last thing you want to do is crank it. Fluids don't compress, so turning the motor over will likely result in broken stuff (rods).
Re: Coolant through the tailpipe: what's the cause? [Re: Fat_Mike] #1124151
11/29/11 05:56 PM
11/29/11 05:56 PM
1968RR Offline OP
1968RR  Offline OP
The engine was turning over, but not starting. As soon as I saw the puddle beneath the exhaust, I stopped trying to start the engine. When I pulled the #7 plug and saw coolant on it, no coolant flowed out of the plug hole. When I pulled the #5 plug, it looked fine.
Re: Coolant through the tailpipe: what's the cause? [Re: 471Magnum] #1124152
11/29/11 07:20 PM
11/29/11 07:20 PM
Tulsa, Oklahoma
Wagonmaster Offline
Wagonmaster  Offline
Tulsa, Oklahoma
I can guarantee there is one on a SB. DAMHIK.
Re: Coolant through the tailpipe: what's the cause? [Re: Wagonmaster] #1124153
11/29/11 08:05 PM
11/29/11 08:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Crap. Sounds like the F^@# Up Fairy paid a visit...
Re: Coolant through the tailpipe: what's the cause? [Re: topside] #1124154
11/29/11 09:03 PM
11/29/11 09:03 PM
I'm assuming BB & as you know all header bolts are wet. I'd pull that side header & pump it up w the rad tool & see which one is leaking EDIT Oh I missed that there was coolant in the cyl
Re: Coolant through the tailpipe: what's the cause? [Re: RapidRobert] #1124155
11/29/11 10:15 PM
11/29/11 10:15 PM
ill
dennismopar73 Offline
ill
Well if those heads have open holes to water jacket , it could get into cyl , but never seen those heads , I dono?
but , I'm betting on head casket
Re: Coolant through the tailpipe: what's the cause? [Re: dennismopar73] #1124156
11/29/11 10:31 PM
11/29/11 10:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pretty much just have to pull the head to see anything
Re: Coolant through the tailpipe: what's the cause? [Re: MR_P_BODY] #1124157
11/29/11 11:06 PM
11/29/11 11:06 PM
1968RR Offline OP
1968RR  Offline OP
I've literally got one more head bolt to go before I can authoritatively state the cause of the problem. Based on the goo that was on the bolts closest to cylinder #7 and the coolant that was on the plug, the problem is near the rear of the engine on the driver's side. I'm taking a break. I'll update when I get the last ridiculously-difficult-to-get-loose-with-TTI-headers-still-in-the-bay bolt out.
Re: Coolant through the tailpipe: what's the cause? [Re: 1968RR] #1124158
11/29/11 11:48 PM
11/29/11 11:48 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I don't think you will be able to see anything when you first pull it off. Have to clean things up to be able to see some cracks.
Re: Coolant through the tailpipe: what's the cause? [Re: Challenger 1] #1124159
11/30/11 12:27 AM
11/30/11 12:27 AM
1968RR Offline OP
1968RR  Offline OP
Wow. This is embarrassing. The correct answer was "none of the above".
Recall that the #7 cylinder was the suspect (gooey head bolts, coolant from the driver's side, coolant on the #7 plug)....
When I pulled the head, I noticed a loose wire hanging from the wiring harness (I have no idea what it does/did). I also noticed that the wire was completely flat at the clipped end. Then I noticed that there was the imprint of a wire on the head gasket going across a coolant port across the gasket material again and into the cylinder.
This car has run like this for two years. I got this thing into the 11s. It ran fine...AND THERE WAS A LOOSE WIRE ACROSS THE HEAD GASKET GOING INTO THE CYLINDER.
Wow. I'm both embarrassed and amazed.
I'll post some photos in the next few days.
Re: Coolant through the tailpipe: what's the cause? [Re: 1968RR] #1124160
11/30/11 12:53 AM
11/30/11 12:53 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Coolant through the tailpipe: what's the cause? [Re: 340SHORTY] #1124161
11/30/11 01:00 AM
11/30/11 01:00 AM
1968RR Offline OP
1968RR  Offline OP
I just noticed that the wire ran across a coolant port and an oil hole before going into the cylinder. Good thing that copper's softer than steel, I guess.
Re: Coolant through the tailpipe: what's the cause? [Re: 1968RR] #1124162
11/30/11 02:27 AM
11/30/11 02:27 AM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Be glad that's all it was!!!
Re: Coolant through the tailpipe: what's the cause? [Re: jvcuda] #1124163
11/30/11 02:41 AM
11/30/11 02:41 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Go buy a lottery ticket. Glad it's nothing fatal! I'm sure you're gonna change the oil & filter. If the wire is grey, that's the oil PSI sender wire.
Re: Coolant through the tailpipe: what's the cause? [Re: topside] #1124164
11/30/11 11:13 PM
11/30/11 11:13 PM
1968RR Offline OP
1968RR  Offline OP
FYI: the anonymous fried wire turned out to be the neutral safety switch. One of those wires that you only notice when you need.
