Page 2 of 3 1 2 3
Re: What compression would you run with a 499 stroker? [Re: challengermike] #1123610
11/29/11 12:39 AM
11/29/11 12:39 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
71 degrees after BDC is late for a closing, which would reduce the DCR. The cams I've looked at typically have an intake closing between about 63-67 degress ABDC.
Re: What compression would you run with a 499 stroker? [Re: challengermike] #1123611
11/29/11 12:49 AM
11/29/11 12:49 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
If you have MS Excel, feel free to try my Compression Calculations spreadsheet, http://www.claylahatte.com
Re: What compression would you run with a 499 stroker? [Re: challengermike] #1123612
11/29/11 01:06 AM
11/29/11 01:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I must be doing something wrong at the wallace one.Its coming up with a 7.21 for the DCR,does that sound correct?i did use the 71 abdc
Heres a pic of all the specs when i built the engine with the 906 heads.
Look at the effective stroke... its 3.04
Re: What compression would you run with a 499 stroker? [Re: MR_P_BODY] #1123613
11/29/11 01:29 AM
11/29/11 01:29 AM
Amherst,NY
challengermike Offline OP
Amherst,NY
Why is the effective stroke 3.04? is that because the cam opens to early and closes late? Im sorry, i dont understand all this info.
Re: What compression would you run with a 499 stroker? [Re: challengermike] #1123614
11/29/11 01:38 AM
11/29/11 01:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Effective stroke is when you start to make compression
(when the intake closes)
Re: What compression would you run with a 499 stroker? [Re: MR_P_BODY] #1123615
11/29/11 01:56 AM
11/29/11 01:56 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
MR_P_Body, did you happen to get that 3.04 number from my spreadsheet? I see the same number there, but it may be incorrect because the dynamic stroke length calculation needs the correct rod length, and I didn't see that in his information.
Re: What compression would you run with a 499 stroker? [Re: challengermike] #1123616
11/29/11 05:16 AM
11/29/11 05:16 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The stealth heads are about the same cc as your current heads, so unless your changing pistons or milling the heads your going to have about the same compression ratio?
With the cam you mentioned, you may be able to go 11:1 compression, but I would not go to alot of trouble milling the heads if it is just a street car
Re: What compression would you run with a 499 stroker? [Re: 451Mopar] #1123617
11/29/11 08:59 AM
11/29/11 08:59 AM
Amherst,NY
Amherst,NY
the rod is 6.760
Re: What compression would you run with a 499 stroker? [Re: lahatte] #1123618
11/29/11 10:43 AM
11/29/11 10:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No I didnt BUT I see he posted 6.76 for the length...
I used 6.8... that was on the wallace site
EDIT
I changed the rod length... it made very little difference
now its 3.08... it just the 71 degree closing point
that hurt.... if you close the valve sooner it starts
to increase the effective stroke
Re: What compression would you run with a 499 stroker? [Re: challengermike] #1123619
11/29/11 09:16 PM
11/29/11 09:16 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
There are several different DCR calculators that use different closing points
Dont use KB's CR calculator for anything but SCR. I think for DCR (dur at .006) is accurate rather than KB's (dur at .050"). Wallace racing I think has good calculators
If you use the Wallace Calculator, and the actual valve closing point, the resultant DCR will be lower than what is deemed by many as the acceptable DCR for pump gas, i.e. the Wallace calculator gives lower numbers than other DCR calculators. Said differently, if you get a DCR of 8.5 using actual closing point on the Wallace Calculator, you will have serious detonation. This is why I said what I did earlier, there are several claculators that all used different closing points, and wont give you the same results.
What is the cranking cylinder pressure of your current motor, and what is you confidance in the 9.75 CR being accurate? Did you measure or validate the numbers used in the 9.75 CR calc.?
Re: What compression would you run with a 499 stroker? [Re: lahatte] #1123620
11/29/11 09:31 PM
11/29/11 09:31 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Dcuda69, I'm curious what cam are you using? Do you happen to know the closing angle after TDC (at .006) on the intake valve?
Sorry, don't have the specs. in front of me. It's Comp xr280r solid roller. 242/248@.050 .570/.576 lift IIRC. Idles beautiful at 850rpm with 12" vacuum. Pulls hard and like I said,runs fine on pump swill. My little 245 street tires don't have a chance!
Re: What compression would you run with a 499 stroker? [Re: BSB67] #1123621
11/29/11 10:14 PM
11/29/11 10:14 PM
Amherst,NY
Amherst,NY
I dont know the cranking pressure,the engine isnt in a car right now.I do trust the 9.75 comp rating,it was done by a performance shop near me when i had them do all my machine work on my engine.I have used a couple calculators on quite a few sites since last night and they all come up about the same 9.75 to 9.77,I think i might just put the same head gaskets on and keep the comp the same for now.Im just worried im going to end up needing to run some race gas or the timing real low.I just sold a 86 buick t type because the price of race gas kept me from going to the track as much as i would like to.It was $80 to $100 everytime i went to the track(including entery fee)
Re: What compression would you run with a 499 stroker? [Re: challengermike] #1123622
11/29/11 10:37 PM
11/29/11 10:37 PM
Prospect, PA
Prospect, PA
Yes, I was asking about validating the measurements (head cc, dish ccs, comp. distance), not the calculation. If you had the cranking pressure, you could work the numbers backwards to estimate an acceptable CR for the aluminum heads.
Re: What compression would you run with a 499 stroker? [Re: MR_P_BODY] #1123623
11/29/11 10:57 PM
11/29/11 10:57 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Ah, well then, I already had 6.76 for the rod length when I did the calculation earlier, so that's why I also got the 3.04 dynamic stroke length.
Re: What compression would you run with a 499 stroker? [Re: lahatte] #1123624
11/29/11 11:06 PM
11/29/11 11:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Actually that was what I got also with the 6.76...
the 3.08 was a error
Re: What compression would you run with a 499 stroker? [Re: MR_P_BODY] #1123625
11/30/11 01:26 AM
11/30/11 01:26 AM
Amherst,NY
Amherst,NY
so later down the road i could have a cam custom ground to bring the dcr up some?I was thinking this cam may be alittle small lift wize for this engine any ways.
Re: What compression would you run with a 499 stroker? [Re: challengermike] #1123626
11/30/11 01:41 AM
11/30/11 01:41 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
A Lunati salesman told me the intake valve closing angle of the 60303 is 60 degress. If that's true, it's one of the earliest I've seen. I haven't seen the specs for those cams though.
Re: What compression would you run with a 499 stroker? [Re: challengermike] #1123627
11/30/11 08:10 AM
11/30/11 08:10 AM
Prospect, PA
Prospect, PA
Generally, a larger cam with the same ICL will have a lower DCR. Putting in larger cam, and increasing the DCR are kinda going in the opposite directions, but can be done with more aggressive lobes.
Re: What compression would you run with a 499 stroker? [Re: lahatte] #1123628
11/30/11 11:16 PM
11/30/11 11:16 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
60 degrees after BDC for the Lunati 60303 cam is correct. The specs are 268/276 advertised duration, 226/234 @ 0,050" duration, 110 LSA, 106 intake centerline, 0.494"/0.513" lift.
Re: What compression would you run with a 499 stroker? [Re: 451Mopar] #1123629
12/01/11 02:03 AM
12/01/11 02:03 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
I just received my 60303 cam kit today. Now I need to get the block machined.
Page 2 of 3 1 2 3
