well you are supposed to use @.050 on those calculators this one is exactly the same as the wallace and gives the same numbers
http://www.rbracing-rsr.com/comprAdvHD.htmthis is 9.75 to 1 0 boost 1000 feet intake valve closes at 52 if it were installed at 106
Static compression ratio of 9.75:1.
Effective stroke is 3.55 inches.
Your dynamic compression ratio is 8.28:1 .
Your dynamic cranking pressure is 166.22 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 0 PSI is 8.28 :1.
V/P (Volume to Pressure Index) is 213
10.5 to 1 would be real safe on 93
Static compression ratio of 10.5:1.
Your dynamic compression ratio is 8.93:1 .
Your dynamic cranking pressure is 183.20 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 0 PSI is 8.93 :1.
V/P (Volume to Pressure Index) is 235
11 to 1 is a could do but maybe not with a 3200 stall
Static compression ratio of 11:1.
Your dynamic compression ratio is 9.35:1 .
Your dynamic cranking pressure is 194.30 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 0 PSI is 9.35 :1.
V/P (Volume to Pressure Index) is 249
http://www.wallaceracing.com/dynamic-cr.php
