Mancini Roller Rockers #1123159
11/28/11 03:34 AM
11/28/11 03:34 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
I was looking around their site for a set of roller rockers for one of my small blocks. I came across their own brand of Roller Rockers, but no pictures. Has anyone used them? they are obviously someone else's rocker arms re-packaged. They were a little cheaper than the Hughes roller rockers, just wondering if anyone had a set?
Thanks in Advance
Alan Jones
Re: Mancini Roller Rockers [Re: LA360] #1123160
11/28/11 03:41 AM
11/28/11 03:41 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
PM sent
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Mancini Roller Rockers [Re: Irun5snd8th] #1123161
11/28/11 02:16 PM
11/28/11 02:16 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
from what i understand they are HS rockers made for them. bushed not roller trunion
74 dart sport 440 www.Csucarbs.com
Re: Mancini Roller Rockers [Re: shoebox] #1123162
11/29/11 12:26 AM
11/29/11 12:26 AM
Kentucky
clovis Offline
clovis  Offline
Kentucky
This is a big block set. These are produced by Harland Sharp but exclusive to Mancini. I did have to extend the oil hole just a tad to connect it to the center grove (just a touch with the dremel). These have worked out very good for me as the shape on the back side of the rocker allows valve cover clearance with my Stage VI heads.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Mancini Roller Rockers [Re: clovis] #1123163
11/29/11 01:42 AM
11/29/11 01:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just curious how much they go for ? Ron
Re: Mancini Roller Rockers [Re: 383man] #1123164
11/29/11 02:08 AM
11/29/11 02:08 AM
LA360 Offline OP
LA360  Offline OP
$419.95
Alan Jones
Re: Mancini Roller Rockers [Re: LA360] #1123165
11/29/11 10:03 AM
11/29/11 10:03 AM
I love them! We used a set on our Engine Masters 406 BB--No mods--they are great! Big adjusters just like normal Harlands and no oil pressure bleeding rollers--clear everything everywhere--Mancini is the only place I know of to get them--you have to figure there is over $100 worth of quality adjusters here--good deal IMO
Re: Mancini Roller Rockers [Re: ] #1123166
11/29/11 11:45 AM
11/29/11 11:45 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Since others have let the cat out of the bag I will chime in and confirm. I have a set that were used to solve my spring clearance issues with the 1.550 valve springs. These rockers did not need to be touched to clear. They will also bolt directly in place of a HS bearing style rocker without changing pushrod length
Re: Mancini Roller Rockers [Re: Irun5snd8th] #1123167
11/30/11 12:03 AM
11/30/11 12:03 AM
Kentucky
clovis Offline
clovis  Offline
Kentucky
If I remember correctly it is only the rockers and adjusters that are HS, the shafts and hold downs are from somewhere else.
'75 Plymouth Duster
Re: Mancini Roller Rockers [Re: clovis] #1123168
12/13/11 06:06 PM
12/13/11 06:06 PM
LA360 Offline OP
LA360  Offline OP
I ordered a set and they sent me Crane rockers. The part number on the web site matches the part number on the Crane box. To add insult to injury they added a catalog with the rockers I thought I was getting on the front page. If I knew they were going to send me Crane's, I would have bought the Hughes rockers instead like I was originally intending.
Alan Jones
Re: Mancini Roller Rockers [Re: LA360] #1123169
12/13/11 07:42 PM
12/13/11 07:42 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
That sounds to me like Mancinis problem there and they should fix that issue cause in my newest flyer they clearly state HS non roller fulcrum rockers.
Kasey
Re: Mancini Roller Rockers [Re: Moparnut426] #1123170
12/13/11 07:53 PM
12/13/11 07:53 PM
Get-X Offline
Get-X  Offline
Kasey
I agree, packaging snafu most likely. I'd definately be sending them back at their expense.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Mancini Roller Rockers [Re: Get-X] #1123171
12/13/11 07:57 PM
12/13/11 07:57 PM
LA360 Offline OP
LA360  Offline OP
I have contacted them but haven't heard back from them. This is the second time they have sent me the wrong parts, and sending parts back when you are on the other side of the world is an expensive exercise. I ordered these rockers with a BB oil pump for my friend's engine. The postage was $125
Alan Jones
Re: Mancini Roller Rockers [Re: LA360] #1123172
12/13/11 08:01 PM
12/13/11 08:01 PM
Moparnut426 Offline
Moparnut426  Offline
Well Heck, My wifes Cousin is over in Melbourne right now, She could grab them from ya when she comes home, and then mancini could send you the correct ones. Shes there for a while though.
Her name is Holly S from Nebraska.
Kasey
Re: Mancini Roller Rockers [Re: LA360] #1123173
12/14/11 07:31 AM
12/14/11 07:31 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Al - Telphone is your best friend when it comes to dealing with Mancini.
..you know I know.
Re: Mancini Roller Rockers [Re: Moparmal] #1123174
12/14/11 07:40 AM
12/14/11 07:40 AM
LA360 Offline OP
LA360  Offline OP
Thanks for the advice Mal, but I am not really fussed. I am happy to run with them, I more so just wanted to get the information out there so it doesn't happen to someone else.
Alan Jones
Re: Mancini Roller Rockers [Re: LA360] #1123175
12/14/11 10:22 AM
12/14/11 10:22 AM
Moparnut426 Offline
Moparnut426  Offline
Re: Mancini Roller Rockers [Re: Moparnut426] #1123176
12/20/11 01:19 PM
12/20/11 01:19 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
i thought they sounded interesting but looking at the pic, i guess i had the wrong idea what "bushed" meant. i was thinkign they had brass or bronze bushings in them, sort of like people do to other aluminum rockers. the pic just looks like an all aluminum rocker. i dont have a need for roller bearings in my rockers.
