E-body rallye clock restoration. #1122795
11/28/11 12:36 AM
11/28/11 12:36 AM
Belleville Il
Dingmaster Offline OP
Belleville Il
Who would you recomend for a clock repair for my 71 Challenger?
I Dont need the face painted Just a quarts movement or repairing this one. I'm looking for someone that has a pretty quick turnaround time.
Re: E-body rallye clock restoration. [Re: Dingmaster] #1122796
11/28/11 02:20 AM
11/28/11 02:20 AM
Colorado Springs,Colorado
Roadrunner440-6 Offline
I did mine about 3 weeks ago and it took me about 90 minutes...if you dont have a shakey hand...... You might just give it a try....
Re: E-body rallye clock restoration. [Re: Roadrunner440-6] #1122797
11/28/11 10:32 AM
11/28/11 10:32 AM
Belleville Il
Belleville Il
Can I get a little more info?
Where did you get the quarts movement?
Re: E-body rallye clock restoration. [Re: Dingmaster] #1122798
11/28/11 11:57 AM
11/28/11 11:57 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Clocks are not rocket science - If you can read directions and use a soldering iron your golden.
I did one in a 1970 E-body rallye dash last year and
I just did one in a 1969 B-body rallye dash last week.
for the quartz movement go here
http://clocksandgauges.com/
Re: E-body rallye clock restoration. [Re: gtx6970] #1122799
11/28/11 12:14 PM
11/28/11 12:14 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This the B-body version thread
http://www.dodgecharger.com/forum/index.php/topic,86585.0.html
Re: E-body rallye clock restoration. [Re: Dingmaster] #1122800
11/28/11 04:40 PM
11/28/11 04:40 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
This is what I put in my Rallye Gauge Cuda:
http://rt-eng.com/mediawiki/index.php/Dash-Worx_E_Body_Clock_kit
Instructions are here:
http://rt-.com/mediawiki/images/c/cf/EbodyRallyeClock1209.pdf
Craig
"The hand in the trunk" (not trunk monkey)
by Satilite73. 06/05/20 10:04 AM
Basics of transmission/throttl
e kick down linkage?
by 67SATisfaction. 06/04/20 11:44 PM
Moparts Recent Posts
Chevelle board? A question on the 396/402
by Twostick. 06/05/20 11:01 AM
1976 FMC MOPAR 440
by Doc Fiberglass. 06/05/20 10:57 AM
DODGE JOURNEY
by ZIPPY. 06/05/20 10:51 AM
