Re: vacumm guage
[Re: Tadams]
#1121778
11/26/11 05:35 PM
11/26/11 05:35 PM
RapidRobert
The timing mark is about 2 inches of the mark My question is the vacumm gauge goes from 19 to 21 rapidly.What do I check now?
(1) clarify that (2) there's a prob somewhere (if not a radical cam). (3) If you experiment w idle mixture/speed can you get it to get steadier?. what idle speed and is that Formula S cam a lumpy one EDIT (re)read it & 19-21 would have to be a smooth cam. I'd do a compression/leakdown tests for starters after idle mixture and short each cyl to ground (cyl balance) & note what the needle does. Sounds like one cyl (or more) is a fair amt weaker than the others/not pulling it's load when it fires making it dip to 19 for that split second that it is firing
Re: vacumm guage
[Re: Tadams]
#1121779
11/26/11 06:09 PM
11/26/11 06:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I adjusted the timing with a vacumm guage as was recommended. The timing mark is about 2 inches of the mark but it starts and idles good. My question is the vacumm gauge goes from 19 to 21 rapidly. When you rev it up it smooth out. What do I check now? This a stock 273 commando in my 65 Barracuda Formula S. Thanks for your help.
On your 273 is that a mech cam... check your lash adjustment
Re: vacumm guage
[Re: MR_P_BODY]
#1121780
11/26/11 06:47 PM
11/26/11 06:47 PM
Posts: 239 North Carolina
Tadams
North Carolina
Thanks every one for your help. It is a stock engine and has a stock cam.I think with the 4 barrell this car should have dome pistons and I think the cam is a little different from the regular engine. Idle speed was 800 RPM and the high the rpm the smoother it was. I'll adjust the valves next week and see if that helps. The carb was just rebuilt and I think is set properly.
Re: vacumm guage
[Re: Tadams]
#1121781
11/26/11 08:53 PM
11/26/11 08:53 PM
Posts: 15,487 Florida
scratchnfotraction
vac gauge fluctuating bouncing could be a bad valve/weak cyl. rockers out of adjustment timeing chain sloppy vac leak for starters,a comp check and leak down wet and dry are in order. snake oil test.... hold a dollor bill at the tail pipe and see if it sux it in then pops it back out while watching the vac gauge bounce in time with the doller poping
Re: vacumm guage
[Re: RapidRobert]
#1121784
11/26/11 10:59 PM
11/26/11 10:59 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
2" off,,, are you useing # 1 plug or did you goof up and use #2 plug to hook the timing light up to???
I am truckless..
Re: vacumm guage
[Re: Tadams]
#1121787
11/27/11 01:41 AM
11/27/11 01:41 AM
RapidRobert
2" on the dampener is ~32 deg and that is just to the left edge of the tab? or is that in to the zero in the middle of the tab. Something still ain't right EDIT I suspect the too high initial is possibly causing the unsteady needle EDIT on the initial you got max vac in drive then backed off 1 in hg all the while reducing the idle speed correct?
Re: vacumm guage
[Re: Tadams]
#1121789
11/27/11 10:51 AM
11/27/11 10:51 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
My wife said I need to make a new friend locally who works on cars, sounds like a plan.
sound advice but make sure you stay involved (hands-on) join a local mopar club. for someone that isn't that mechanically inclined, all the advice (while usually good) can make your head spin!
Re: vacumm guage
[Re: Tadams]
#1121793
11/27/11 01:54 PM
11/27/11 01:54 PM
MR_P_BODY
Hi Mike, Im learning, for sure.
Dont get too hung up on the fact that the vac gauge jumps some at lower rpm... the slower the rpm it has more time to see the pulse... at higher rpm they are blended together.... plus the LSA on that cam is tighter which has more over lap and more over lap has pulses
Re: vacumm guage
[Re: MR_P_BODY]
#1121794
11/27/11 02:41 PM
11/27/11 02:41 PM
mikemee1331
bethlehem pa
BINGO
Re: vacumm guage
[Re: mikemee1331]
#1121795
11/27/11 07:23 PM
11/27/11 07:23 PM
RapidRobert
I'd recheck all the basics: adj valves (.013 in .021" ex). Timing chain (rockover). slipped dampener w the piston stop tool. marks at 10BTDC #1 compression & time dist at that initial (which is stock for all 4bbl and 2bbl w auto and or power pack). 2bbl WO them is 5. Plus compression test (leakdown too if you have a gauge setup)
