Page 3 of 4 1 2 3 4
Re: Hemi Rocker Arm Deflection [Re: Troy] #1120689
11/29/11 03:44 PM
11/29/11 03:44 PM
Mt. Eden Ky.
Hemi Allstate Online content
Hemi Allstate  Online Content
Mt. Eden Ky.
Are those HI TECH ROCKER STANDS in this picture??? If so the owner needs to change out the split lock washers that are under the shaft hold down bolts. If you dont you will be low on oil pressure. I was checking my oil pressure with the valve cover off and when I hit the drill motor to build pressure, oil shot out from between the bolt and the stand. What was happening was oil was coming out of the shaft...going through the split lock washer and past the bolt. I changed over to a standard washer and all is good.
Hello Troy,
This is my engine, and the stands are Hi-Tech. I appreciate the "heads up". I wanted to be sure, so I
pulled a bolt to check and the washers are a black, flat ground, apparently hardened washer, so I guess they changed or updated the hardware. I can see where the split type would be a problem.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hemi Rocker Arm Deflection [Re: Hemi Allstate] #1120690
11/29/11 04:00 PM
11/29/11 04:00 PM
Hello Troy,
Mark
It amaszs, actuallay infuriates me, to see people, racers, use split type lock washers on cast iron ,pot metal or aluminum carbs with out a flat washer between the split lock washers and the base metal
Re: Hemi Rocker Arm Deflection [Re: Performance Only] #1120691
11/29/11 04:18 PM
11/29/11 04:18 PM
Manitoba, Canada
liteweight Offline OP
Manitoba, Canada
correlate the deflection to crankshaft degree's and you'll find it's less than 1 degree. not enough to worry about.
With the DLI 1.7 intakes, it's actually alot more than 1*, it's 14.5*
So, anytime you degree your camshaft off the lobe, not taking valve train flex into consideration, opens the valve late & closes it early.
liteweight
68 Hurst LO Hemi Dart 70 hemicuda 4 spd. R code owned since 76 70 GTX 4 spd. 21,000 orig. miles 55 Ford F100 chopped,slammed,bagged & supercharged 96 Ram 2500 4X4 Twin turbo'd Cummins 550hp 1200 ft. lbs tow vehicle
Re: Hemi Rocker Arm Deflection [Re: liteweight] #1120692
11/29/11 05:25 PM
11/29/11 05:25 PM
Delray beach, Florida
P
Performance Only Offline
P
liteweight
no offense, but if your seeing 14.5* of deflection, either your measurement is off or your measurement technique. do you realize how far the crankshaft has to turn to move 14.5 degrees?
machine shop owner and engine builder
Re: Hemi Rocker Arm Deflection [Re: Performance Only] #1120693
11/30/11 04:52 PM
11/30/11 04:52 PM
Manitoba, Canada
Manitoba, Canada
liteweight
No offense taken. Hey, you don't know me.
The 14.5* IS crankshaft degrees, 7* @ valve opening, 7.5* @ valve closing. Camshaft is of course half that in degrees rotation @ bout 3.5*opening & 3.75* @ closing. This would confirm the .052" loss of lift measured as per attachment.
liteweight
ps. If I'm doing something wrong, I'm open to all suggestions.
Re: Hemi Rocker Arm Deflection [Re: liteweight] #1120694
11/30/11 11:00 PM
11/30/11 11:00 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Hi all,
I finished plotting the exhaust events on Liteweight's Hemi build. I have attached them here. As with the intake events, there is definitely less area under the curve. In this case, it is about 7 1/2%.
So, how do the losses of area under the curve effect the torque and horsepower of the engine?
Garth
Re: Hemi Rocker Arm Deflection [Re: Big Wedge] #1120695
12/01/11 12:08 PM
12/01/11 12:08 PM
Manitoba, Canada
Manitoba, Canada
I've contacted Tim from FHO to go through this with me. He is currently at PRI & will be back next week. I'll keep you all updated.
liteweight
Re: Hemi Rocker Arm Deflection [Re: Big Wedge] #1120696
12/01/11 10:35 PM
12/01/11 10:35 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I sort of wonder why there is so much deflection right off the base circle? I would think there would be more deflection at full load on the springs. What are the seat load and open loads on the springs?
Floyd Lippencott IV
Re: Hemi Rocker Arm Deflection [Re: mr_340] #1120697
12/02/11 01:33 PM
12/02/11 01:33 PM
Manitoba, Canada
Manitoba, Canada
Glad to see someone has caught that. Most of the deflection occurs before .250" of lift. I can't answer that, as I also would think it should yield most at the higher spring pressures- ie: on the nose of the lobe.
Seat pressures are 200lbs, on the nose @.675" 600lbs. Not aggressive at all.
Thus my dilema.
liteweight
Re: Hemi Rocker Arm Deflection [Re: mr_340] #1120698
12/02/11 02:11 PM
12/02/11 02:11 PM
Manitoba, Canada
Manitoba, Canada
I was just forwarded this link to the ineffectivness of using spiral wound lock washers. Using them IS worse than no lock washers.
liteweight
http://www.boltscience.com/pages/helicalspringwashers.htm
The engineering community has abandoned split lock washers for any purpose. The opinion is they don't work and in some cases aid the fastener loosening. I've found NASA and US Navy documents confirming this opinion.
http://gltrs.grc.nasa.gov/reports/1990/RP-1228.pdf
Re: Hemi Rocker Arm Deflection [Re: liteweight] #1120699
12/02/11 02:44 PM
12/02/11 02:44 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Ray Barton HEMI Rocker arms and you can forget aboout all of this. Not necessary at all though...but if you want things perfect...or at least as close as perfect as you can get...
Re: Hemi Rocker Arm Deflection [Re: domingo] #1120700
12/02/11 03:02 PM
12/02/11 03:02 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
No matter who made the rocker arms it is also a spring
Re: Hemi Rocker Arm Deflection [Re: cbarracuda] #1120701
12/02/11 03:21 PM
12/02/11 03:21 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Thats why I said the Ray Barton Rockers will get you "at least as close as perfect as you can get". But no matter what they are made of and who makes em I bet they will always have some deflection.
Re: Hemi Rocker Arm Deflection *DELETED* [Re: domingo] #1120702
12/02/11 03:30 PM
12/02/11 03:30 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Post deleted by polyspheric
Boffin Emeritus
Re: Hemi Rocker Arm Deflection [Re: polyspheric] #1120703
12/04/11 05:33 AM
12/04/11 05:33 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
So not only do Hemi rockers have terrible ratios and consisitancy, they flex a lot? It beginning to feel like I am wasting my time building a hemi......Tim
Re: Hemi Rocker Arm Deflection [Re: astjp2] #1120704
12/04/11 09:03 AM
12/04/11 09:03 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
The factory rocker ratios were all over the place. I believe the aftermarket stuff is much better. Even with the losey ratios the Hemi still makes darn good power. If you've never had a Hemi before you're going to be surprised. The Hemi just keeps pulling.Dave
Re: Hemi Rocker Arm Deflection [Re: mr_340] #1120705
12/04/11 03:37 PM
12/04/11 03:37 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
If it is measured in crankshaft degrees directly, then the force has to go through the drive between crank and camshaft. Could this be the deflection shown directly? (Or some of it. Slack in cambearings and lifters to bore etc will also add some with springs much stiffer than test springs) What sort of drive is used; a gear or chain`or others? I would guess the loss of duration relates to this, and loss of lift is in the deflection from cam and up, my
Re: Hemi Rocker Arm Deflection [Re: Oyvind Mopar] #1120706
12/04/11 05:48 PM
12/04/11 05:48 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Yes, it looks like the test springs don't have enough force to take up any slack in the valvetrain (where ever it is?). The two plots look like one with no valve clearance and one with the clearance added. I would expect the deflection at the seat loads to be about 1/3rd of the fully open load (200# vs. 600#). It should be fairly linear if it is strictly due to loads.
Floyd Lippencott IV
Re: Hemi Rocker Arm Deflection [Re: mr_340] #1120707
12/05/11 07:35 PM
12/05/11 07:35 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Ok, here is a little more information. I plotted the delflection of each rocker arm vs the crank angle on the same graph as the valve lift. As expected, the deflection goes up as the spring is compressed. Note, there are 2 pages to the attachment.
Garth
Re: Hemi Rocker Arm Deflection [Re: Big Wedge] #1120708
12/05/11 09:02 PM
12/05/11 09:02 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Garth, there is some lost motion going on there, about .016"-.018" on both lobes. Are the rockers moving sideways or any other visible movement other than rotation? You can see this in your plots - the deflection matches the deflection up to around the .016" level and then a slow slope up to maximum lift.
Party on Garth. "Wayne"
Page 3 of 4 1 2 3 4
