Blow through big block.. Jetting ?
#1120145
11/23/11 11:23 PM
11/23/11 11:23 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
My set up is a 493" 8.5-1 with a 980 holley. Can anyone give me a idea where to start with the jetting? I have the carb set up to run well N/A right now. Do I just add a bunch to the secondaries and go from there? It will have a uego on it so I will be able to monitor the AFRs. Any help would be great!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Blow through big block.. Jetting ?
[Re: CUUDAK]
#1120148
11/24/11 01:50 PM
11/24/11 01:50 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
how much boost? power valve? if yes How big is the powervalve passage? Street? race only?
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#1120149
11/24/11 03:20 PM
11/24/11 03:20 PM
HOTMOPR
Oakville, Wa
probably 15-18 max. What do you mean by the passage? is that the holes I need to drill behind the PV? I am doing the hanger18 mods.. yes power valve unless I hear different. Its mostly race but I want to be able to throw some pump petrol in it and hit the cruise night.
[Re: bigtimeauto]
#1120151
11/25/11 02:20 AM
11/25/11 02:20 AM
HOTMOPR
Oakville, Wa
yes gas. Thanks! by the way what are you running in the dart? Stock block? how much boost/ Just curious what a stock block will handle? I am sure my components are good for more than the block can handle.
