reluctor gap #1119052
11/22/11 10:13 AM
11/22/11 10:13 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
trying to learn.
I know the reluctor gap on a mopar electronic ignition is suppose to be set at 0.008". in car trouble diagnosing threads commonly see folks saying to check this gap to possibly cure ailments.
What I am unsure of is what the consequences of it being larger would be?
for instance what if it was 0.016" or 0.024"?
what's effected? starting, idling, part throttle, WOT, etc...?
Re: reluctor gap [Re: BTTG] #1119053
11/22/11 10:37 AM
11/22/11 10:37 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
All of the above, that's a huge gap.
Re: reluctor gap [Re: JohnRR] #1119054
11/22/11 10:47 AM
11/22/11 10:47 AM
scratchnfotraction Offline
make sure to use a brass feeler gauge also..very important to use brass.
it can and will bite you.
the closer the better as long as it does not touch the reluctor but 8 is the norm.
now the pertronix points conversion has a hall cell and magnets like a stock unit per say and uses a .030 gap
Re: reluctor gap [Re: scratchnfotraction] #1119055
11/22/11 12:56 PM
11/22/11 12:56 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Use brass gauge at .008, large gap will affect the way it idles.
Re: reluctor gap [Re: RJS] #1119056
11/22/11 05:42 PM
11/22/11 05:42 PM
OT I'd mark the round dist base/mainifold to be able to return it to that place then loosen the dist clamp being carefull not to put any side pressure on the housing as you rotate it around in a circle and check each of the teeth to the magnet and find the tooth that protrudes the most even a thou or 2 then working w that tooth pull the vac can thru it's travel w a Mityvac vac pump all the while moving the housing to keep the magnet lined up dead even w that tooth and find the point of least gap in it's range of travel and gap it at .006-8" being carefull not to lean on the housing & skew your measurements. Rotor phasing: Then drill a 1/2" hole in the top flat of a junk cap 2/3 of the way between the center and the #1 terminal (closer to the outside #1 terminal) and idling (assuming at a high enough vac that the can is maxed out & if not use the Mityvac) note if the rotor is dead on or nearly dead on w that terminal. Only vac adv will change phasing & will move it CCW on a SB and CW on a BB from the at rest no vacuum position. a 1/2" hole in your current cap will let ionized air out if your OK w the appearance.
Re: reluctor gap [Re: scratchnfotraction] #1119057
11/22/11 05:57 PM
11/22/11 05:57 PM
Santa Cruz, Ca
4woody Offline
4woody  Offline
Santa Cruz, Ca
I think I can guess, but what happens if you don't use the brass feeler?
Re: reluctor gap [Re: 4woody] #1119058
11/22/11 06:35 PM
11/22/11 06:35 PM
Yes you guessed right & I dont think a regular steel blade messes up the tooth as it's just steel the same as the feeler & same on the magnet it just attracts it also like it does the tooth but it doesnt completely touch but I've had the magnet get too close & chip a tooth (or 2) so not a prob from steel/steel contact but the steel feeler gauges sticks to the mag strong & you cant get a good feel for proper clearance. You could get the gap close though.
Re: reluctor gap [Re: RapidRobert] #1119059
11/22/11 06:44 PM
11/22/11 06:44 PM
it can also zap you...like a charged condencer will.
remember in small engine class it was a thing to do for the next class,charge up condencers and put them on the bench
walk up and grab it and kungpow you got shocked.
Re: reluctor gap [Re: scratchnfotraction] #1119060
11/22/11 07:10 PM
11/22/11 07:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You can substitute a matchbook cover for the .008" brass feeler gauge if need be.
Don't be the exception.
Re: reluctor gap [Re: Supercuda] #1119061
11/22/11 07:34 PM
11/22/11 07:34 PM
I always notice that too big a gap and when you have the timing light on it the timing will "jump around" Never really noticed anything else
Re: reluctor gap [Re: ] #1119062
11/22/11 08:09 PM
11/22/11 08:09 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I once had a car that (once it was warmed up) would die every time I pushed the clutch in. Other than not wanting to idle, it ran fine. The problem was the reluctor gap.
It's Swifty! Swifty, you toad sucker!
Re: reluctor gap [Re: BTTG] #1119063
11/22/11 08:15 PM
11/22/11 08:15 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Someone did this on my 340 GTS before I bought it................
It had been upgraded to a factory ECU......and depending on the weather, barometric pressure or whatever errant circumstance it was..........the car would die spontaneously at intersections pericically.
Set the gap to spec (.006-.008) and never had the problem again.
Re: reluctor gap [Re: scratchnfotraction] #1119064
11/22/11 08:17 PM
11/22/11 08:17 PM
Kirkland, Washington
Pacnorthcuda Offline
Huh? Its just a piece of steel passing on front of a magnet and creating a VERY small amount of inductance. No significant amount of current or voltage at play here...
Its not a capacitor, its not a magneto.
Re: reluctor gap [Re: Pacnorthcuda] #1119065
11/22/11 11:23 PM
11/22/11 11:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That pick-coil unit is basically and AC generator. It creates a very small ac voltage every time the reluctor pole passes the magnet and coil. It induces a small ac current that the ECU sees to determine when to fire the plug just like when points open. If the gap is to large it will not greate the ac signal and the car wont start. If the gap is wrong but it still makes enough signal to run it can change the timing and the dwell a little causing a weaker spark. Cant say I ever had one hard to start from the gap off as they either did spark and start or did not if to wide a gap. Ron
Re: reluctor gap [Re: 383man] #1119066
11/22/11 11:38 PM
11/22/11 11:38 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
One problem not covered yet: Terrible full throttle performance.
The air gap in my MP distributor slipped to .020 more than once. I had it at the drags for the first time since it was finished. It ran fine at idle and part throttle, but when the green lights came up and I went full throttle, the engine popped and sputtered to a miserable ET.
Re: reluctor gap [Re: Pacnorthcuda] #1119067
11/23/11 06:45 AM
11/23/11 06:45 AM
the FMS said it and I have had the key on and got zaped with a steel feeler
go ahead and try it,see if i am wrong
Re: reluctor gap [Re: zrxkawboy] #1119068
11/23/11 07:47 AM
11/23/11 07:47 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
The exact same thing happened to a friend of mine, gap changed slightly when warm, engine died. Set to spec and no problems after that.
Re: reluctor gap [Re: Supercuda] #1119069
11/23/11 10:15 AM
11/23/11 10:15 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I have used the matchbook cover for points because it is about .017 thick . Are matchbook covers that thin now ?
Re: reluctor gap [Re: JohnRR] #1119070
11/23/11 03:11 PM
11/23/11 03:11 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I used a business card, if I remember right, I think it was .009 so it was close enough.
As for symptoms- my dad's car's gap was too much and it was very hard to start once hot, but would fire OK once it cooled off. I don't remember how big the gap was but setting it to ~.008 fixed the hot start problem.
Re: reluctor gap [Re: scratchnfotraction] #1119071
11/23/11 08:56 PM
11/23/11 08:56 PM
Scratchin--the reason brass is used is because its non-ferrous and therefore not attracted to the magnetic pickup--using a steel feeler gauge makes it hard to get a proper 'feel' for the gap.
Brass is not. Brass is also VERY conductive--even more so than steel.
Brass ain't gonna protect you from a shock, but hey no worries anyway!
