Rear gear ratio and rpm #1117934
11/20/11 07:13 PM
11/20/11 07:13 PM
MN
Skid_Demon Offline OP
MN
Greetings, I have an old Mopar with a 360, 727, 8.75 out of a 64 Plymouth with 3.23 gears. The tach says about 2900 at about 65 mph. I don't have a working speedometer yet. Anyway, would simple math tell me have many r's if I change to a 2.91 or 2.76? (Experts, sorry if I don't have the numbers correct). Oh, the rear tires are 225x70x15. Thanks. I am thankful.
Re: Rear gear ratio and rpm [Re: Skid_Demon] #1117935
11/20/11 07:23 PM
11/20/11 07:23 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Go to http://vexer.com/automotive-tools/speed-rpm-calculator you'll like the lay out, easy & Mopar oriented..
Re: Rear gear ratio and rpm [Re: Skid_Demon] #1117936
11/20/11 07:25 PM
11/20/11 07:25 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
not sure what you're asking?? if i read it right, the rpms would be lower at 65mph with 2.xx gears.
Re: Rear gear ratio and rpm [Re: mikemee1331] #1117937
11/20/11 07:54 PM
11/20/11 07:54 PM
MN
MN
The math said going from a 3.23 to 2.91 is 90%. If swaping rear end, would 2900 rpm be 10% less with the higher gears, 2900 x .9 equals 2610 rpm? Thanks for the info!
Re: Rear gear ratio and rpm [Re: Skid_Demon] #1117938
11/20/11 08:04 PM
11/20/11 08:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well first off 3.23 gears, 27.4" tall tire & 1-1 high gear shows you should only be spinning 2600 rpm's at 65 so if your tach is correct your convertor is slipping quite a bit... 2900 should give you about 74 mph..
65 with 2.91 = 2370 rpm
65 with 2.76 = 2200 rpm
Re: Rear gear ratio and rpm [Re: 1_WILD_RT] #1117939
11/20/11 09:56 PM
11/20/11 09:56 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
what kind of Tach do you have? I would bet its off..
I am truckless..
Re: Rear gear ratio and rpm [Re: 340SHORTY] #1117940
11/20/11 10:21 PM
11/20/11 10:21 PM
MN
MN
It's an old SunPro. I wired the lights to it and the dial pointer goes to zero when the lights are turned on. It shows okay when the lights are not on. Not sure how accurate it is.
Re: Rear gear ratio and rpm [Re: Skid_Demon] #1117941
11/21/11 12:53 PM
11/21/11 12:53 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
most factory and old aftermarket tachs are wildly inaccurate. Trust the math, not some ancient $20 tach.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Rear gear ratio and rpm [Re: DPelletier] #1117942
11/21/11 05:46 PM
11/21/11 05:46 PM
MN
MN
I might be easier to get some taller tires, 29 - 30" to lower crusing rpm. Thanks for all the info,
Re: Rear gear ratio and rpm [Re: Skid_Demon] #1117943
06/27/12 01:56 PM
06/27/12 01:56 PM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
I have been looking all over for this thread...LOL
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
