Page 2 of 4 1 2 3 4
Re: Why is a turbo 400 better than a 727? [Re: maximum entropy] #1114236
11/15/11 07:06 PM
11/15/11 07:06 PM
Guitar Jones Offline
you'll never find a brand x tranny in my car. you may find a 727 in my brand x.
I have felt this way for a very long time but at this point I may go to a 'glide when I have the coin to do so. Just saying. I really like my Duramax/Allison trans truck. Never in a thousand years would I have ever thought I'd say that...But times change...
Re: Why is a turbo 400 better than a 727? [Re: Guitar Jones] #1114237
11/15/11 07:27 PM
11/15/11 07:27 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
There are 904s out there in cars running 8s and leave with the wheels in the air...
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Why is a turbo 400 better than a 727? [Re: 65signet] #1114238
11/15/11 07:46 PM
11/15/11 07:46 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
if you say you will NEVER put a GM trans in your mopar, than you are never going to have a fast mopar...
its really the simple fact that a 727 can not be built to handle the same power levels, we have proved in 100 post previous to this one that you can make the 727 safe with the billet drum lba valve body and proper sprag
gearsets are not as strong, shafts are not as strong, they dont take the line pressure needed in some applications AND the most important reason imo is that you CAN NOT get a convertor to work in a true high horsepower application.
not enought convertor depth to get proper pump angle
Mr Cope and Mr Allison are friends of mine, and they both will agree. At a certain point, it doesnt make good sense
Re: Why is a turbo 400 better than a 727? [Re: Guitar Jones] #1114239
11/15/11 08:02 PM
11/15/11 08:02 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
So you are 1,073 years old ?
Re: Why is a turbo 400 better than a 727? [Re: dOc !] #1114240
11/15/11 08:06 PM
11/15/11 08:06 PM
I told I'm 12 dammit!
Re: Why is a turbo 400 better than a 727? [Re: joshking440] #1114241
11/15/11 08:12 PM
11/15/11 08:12 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
With the arguements you are making, Josh, the turbo 400 would eat power. Pro trans has been making record holding torqueflites for years. But, going back to what Josh brought up the converter ran in a Pro trans is deeper. A simple midplate made thick, fixes this problem.
I really wish guys would figure this one out. It is not the 727 designs from Mopar that blow up. If you drive it in drive with a ton of power yes. Some aftermarket valve bodies that we all used for years caused this phenomenom. They decided Low Band Apply was not necessary in race applications. Well many floarboards, feet and tranny cases later we know better. The sprags and drums from the aftermarket are better. The billet drums do not blow up. But, if you had the low/reverse band applied the drum wouldn't spin 15,000 RPM and blow up.
400 turbo trans were considered junk until they went spragless. The big issue is 1,000's of people buy 400 turbo's and race them. Only hundreds race the 727. So there is very little out there to prove the 727 can handle 2,500 HP. Where are you gonna find the diehards that want to run a 727 that can actually make that power. I think it can be done. But, I don't ,make that kinda power to prove it. Chrisman runs a blown Promod but 4.40's is not enough power to really say "Hey we have tested it to the extreme. I have seen fairly basic aftermarket parted powerglides handle that. Here is why I say this. There are many Pro flites that are using modified stock 904 parts running behind engines making over 1,000 HP and have the ET to back it up. Put the same trans behind a but kicking SS Hemi and they sometimes give up. The 727 is lightyears bigger internally and with the few aftermarket parts needed can handle 2,000HP IMO. But, there are some other parts that need upgrades to really get over and beyond that. Here is the real deal HP does not break transmissions. Torque and tire shake is what tears out transmissions. So if you have a perfect setup it is hard to tell what you can get away with.
Leon
Re: Why is a turbo 400 better than a 727? [Re: joshking440] #1114242
11/15/11 09:05 PM
11/15/11 09:05 PM
organ
maximum entropy Offline
organ
Re: Why is a turbo 400 better than a 727? [Re: maximum entropy] #1114243
11/15/11 09:25 PM
11/15/11 09:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I will never give up my pushbuttons
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Why is a turbo 400 better than a 727? [Re: hemi-itis] #1114244
11/15/11 09:27 PM
11/15/11 09:27 PM
organ
organ
Re: Why is a turbo 400 better than a 727? [Re: hemi-itis] #1114245
11/15/11 09:31 PM
11/15/11 09:31 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
AS HEAVY as that combo of yurrs might beeez .. ...
Re: Why is a turbo 400 better than a 727? [Re: John_Kunkel] #1114246
11/15/11 09:54 PM
11/15/11 09:54 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
As far as the "time bomb" argument...ALL automatic transmissions can explode; that's why NHRA requires diapers/shields on all of them.
THANK YOU !
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Why is a turbo 400 better than a 727? [Re: 65dragnet] #1114247
11/15/11 10:13 PM
11/15/11 10:13 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
because there is more aftermarket support and demand for it
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Why is a turbo 400 better than a 727? [Re: bigtimeauto] #1114248
11/15/11 11:36 PM
11/15/11 11:36 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
For the average 9 second and slower car, a torque flite in a Mopar is a no brainer. Faster that that, the gear ratios become the desired attribute. Way faster than that, and most oem type automatics are your least favorite selection. As has been proven many times, they all need the equivilent amount of $ to work. Drums, expensive converters, input shafts, gearsets, cases and on and on. They all have their problems. Is one FASTER than the other: Yes. But in a 7 round race, in a well sorted out 10.50 car, who cares? That's what shoe polish was intended for.
Re: Why is a turbo 400 better than a 727? [Re: Leon441] #1114249
11/15/11 11:39 PM
11/15/11 11:39 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Leon
The spragless design 400 makes it more like a 727. So all the benefits of the stack clutch shifting are taken away for strength and reliability.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Why is a turbo 400 better than a 727? [Re: Kam*Kuda] #1114250
11/16/11 12:05 AM
11/16/11 12:05 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
BECAUSE IT HAS A TURBO INSIDE IT .
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Why is a turbo 400 better than a 727? [Re: WHITEDART] #1114251
11/16/11 12:13 AM
11/16/11 12:13 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
thank you for the input so far.
I am looking at 850-1000 hp. (not 2000hp)
STreet STrip Car
Fairly heavy mostly all steel B body
Procharger car
I am not a tightwade but I would like to pay the price and get the correct tranny for my application once
regardless if it is a gm tranny or the 727
So the technical reasons would be great
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Why is a turbo 400 better than a 727? [Re: WHITEDART] #1114252
11/16/11 10:34 AM
11/16/11 10:34 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I actually had something relevant to add, but this post renders the entire thread moot. So simple... so brilliant! hahahah
Re: Why is a turbo 400 better than a 727? [Re: Kam*Kuda] #1114253
11/16/11 10:49 AM
11/16/11 10:49 AM
an8sec70cuda Offline
STreet STrip Car
Procharger car
For your application, I think a well built 727 will be just fine. I have one in my 850 hp street car that weighs 3800#. I did grenade the stock drum after 2 years of abuse, but that was about 3 years ago. It's been flawless since w/ the new billet drum.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Why is a turbo 400 better than a 727? [Re: an8sec70cuda] #1114254
11/16/11 11:37 AM
11/16/11 11:37 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Chip, Did you buy the billet steel one or billet aluminium?OR??? Care to speculate if you saw any difference in performance?
Thanks, Sean
Re: Why is a turbo 400 better than a 727? [Re: HardcoreB] #1114255
11/16/11 11:44 AM
11/16/11 11:44 AM
Thanks, Sean
I got the A&A billet steel drum since I still street drive it a lot. If anything, it may have slowed the car down a little bit, but not much. It's hard to tell though since the motor has a lot of runs on it.
CHIP
Page 2 of 4 1 2 3 4
