well what did it gain - pick up
#1112945
11/13/11 07:51 PM
11/13/11 07:51 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
i asked the other week what i could hope to gain with a cam and jetting change to Greg's Roadrunner Well the results are in. We raced at the Mopar rumble on Sunday,yesterday.Really hot day,temps from 86F in the morning to 96F early afternoon DA from 2600 -3300 My car and Steve's Dart were both a bit over a 1/10th off,though i did still pull good mph at 119.06 early before dropping back to low 118's. After a couple of runs getting used to things Greg ended up running 11.34 and a 118.46mph so he picked up from 11.48 and the 116's which was run at 13-1500DA i know there is more,vert and suspension but money thanks for all the help and ideas Here is a link to some photos of the day,i will link some video soon http://www.moparmarketforum.com/forum/viewtopic.php?f=41&t=25974&p=298259#p298259i also have to say it was a good day for me as i won the big block class beating a friend,Darren,who's car i set up/built Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: well what did it gain - pick up
[Re: tex013]
#1112946
11/13/11 08:20 PM
11/13/11 08:20 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Under equal conditions i would think that would be at least 2/10's, which isn't bad. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1112951
11/14/11 06:26 PM
11/14/11 06:26 PM
tex013
Sydney,Australia
Mick, 511ci/440,eddy heads,mild,by Dwayne Porter 10.3ish comp,6 pack,CRT trans 4200 stall,4.10,3855lbs with driver. went from 247/251@050 to 251/259 549/556 gross lift to 566/586 Lunati jetting from 74/75 to 89 outer carbs
Tex
[Re: tex013]
#1112953
11/24/11 09:53 PM
11/24/11 09:53 PM
Posts: 18 Beyond the sun
Bakerlite
Beyond the sun
Dude... I think it's time I pointed out one critical piece of information that you have neglected to tell the members here. When that car was running it's 11.49 it was falling over because it had fuel starvation problems due to the stock pump and fuel line. I should know because I upgraded it for him.. Remember?? Now I know you changed the cam and fiddled with the jetting but the big killer was the fuel system and the car was not tested after it was upgraded, before the new cam went in. P.S...Claiming all the credit for the performance increase due to the cam etc is a little rich..
[Re: Bakerlite]
#1112955
11/25/11 05:37 AM
11/25/11 05:37 AM
deaks
robin hood country
Whilst i would agree with you to a degree, 116 mph is right in line for an 11.48. Mick
[Re: deaks]
#1112956
11/25/11 10:08 AM
11/25/11 10:08 AM
Posts: 2,177 ill
dennismopar73
ill
ok, it's a great street car/ race car,, but if I had a 500 + motor, it ran 11.30-11.40, I would have to figure there something wrong here, only because I have had 440 run there that where pretty mild, , but if everyone happy ,, then I'm happy for everyone to! ,,
[Re: dennismopar73]
#1112958
11/25/11 04:04 PM
11/25/11 04:04 PM
deaks
robin hood country
It may have a 500 motor but at 3800#, it's no lightweight and a street car is always a compromise. Mick
[Re: dennismopar73]
#1112960
11/27/11 12:20 AM
11/27/11 12:20 AM
Posts: 3 Australia
noparts
Australia
A 500 + motor, I would have thought 10.s
I must agree with you even a heavy weight with those cubes should run a 10 of some sort, the converter sounds big enough but gee that cam sounds like the one im my mums car
[Re: deaks]
#1112961
11/27/11 12:34 AM
11/27/11 12:34 AM
Posts: 2,177 ill
dennismopar73
ill
Ok , a 511 cube motor on a 3200 # car can run ,( when right!) in the 9s,,(I think deep) add 600# and take away mm over a full sec? plus some ! Ok he has a street car, i raced a 66 coronet 440 motor 410 gears street car full trim, seats, dash , 16 gallon fuel cell, the car is 3875 #, we run 11-0s at 126, 127 mph A 440 MOTOR! I get it dialed in be in the 10s we are having issues with the cal trak bars! but like I said if he is happy, then I'm happy !
