Page 3 of 5 1 2 3 4 5
Re: Fram oil filter. Where have I been? [Re: CompSyn] #1112769
11/15/11 10:32 AM
11/15/11 10:32 AM
ill
dennismopar73 Offline
ill
Well here we go again ,it's either oil filters or oil,,
This question regenerates itself over and over!
Ok , lets roll with it ,
How much oil does a oil filter actually filter?
Answer not much at all! considering the amount of flow passing thru it.
In HP motors, will a HP filter filter more or less oil?
Answer, yes and no, why is that? because a HP filter allows for more oil to go thru it with out actually filtering the oil at all.
The more filtering medium used the actual less filter gets done!
So depending on the application , don't run a cheap standard filter on blown alcohol motor, or in 'disel' application don't run you cars filter on it.
Change you're oil at regular intervals use the proper weight of oil for the application
Now everyone can argue over it say what ever they wish , those are the facts!
By the way, I don't care what filter you run , just so long as it is used in the application that reguired for it!
Re: Fram oil filter. Where have I been? [Re: dennismopar73] #1112770
11/15/11 10:54 AM
11/15/11 10:54 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
I don't believe those are facts Perhaps you simply did not express your knowledge correctly
Steve
Re: Fram oil filter. Where have I been? [Re: dennismopar73] #1112771
11/15/11 10:58 AM
11/15/11 10:58 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Fram collapsed on my step daughter's 91 Lumina a few years ago. Nice car until that happened.
I pulled the Fram off my Dart that was on there when I bought it. I see why they collapse. I pulled the Purolator apart and saw that the filter media was bonded into plastic or rubber.
The HP1 Fram is not reccomended for street. AFAIK the case is thicker. I have no need for a racing filter.
Please buy your Fram's and roll the dice. Chances are you will be OK. I am not a gambler.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Fram oil filter. Where have I been? [Re: CompSyn] #1112772
11/15/11 11:03 AM
11/15/11 11:03 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
WIX, Fram, NAPA, etc... All of them utilize paper filter media. The manufacturing of paper filter media is not exact. As much as 40% of the filtering area of paper oil filters filter nothing at all, as in the filter is 40% blocked right out of the box.
Plus, how does paper respond to moisture? Right, it absorbs it. What does paper filter media do when it absorbs moisture from engine condensation and then it gets really cold outside. Yep! It freezes. Now your paper filter that was 40% blocked when new is now frozen and is really blocked. Now you have a completely worthless oil filter that's in bypass mode at cold engine start-up until it thaws out.
Do yourself a favor, do your engine a favor and throw out the paper oil filter. Then look for a micro-glass or better yet, a nano-glass oil filter. Previously only available in commercial and industrial applications, glass filter media technology has made it's way to the car and light truck market.
Seriously, research it.
Start here if you like: http://www.youtube.com/user/ckermit8
Lived in Buffalo Ny most My life (over 60 years) and NEVER heard of an engine failing because of a FROZEN oil filter. How far is this to be taken ?
Re: Fram oil filter. Where have I been? [Re: dennismopar73] #1112773
11/15/11 11:15 AM
11/15/11 11:15 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Actually, the "facts" word for word:
"As example, a 3 micron beta 200 microglass element has less restriction than a 30 micron paper element. Filter paper manufacture is not an exact science. In many paper elements, as much as 40% of the filter may not pass oil at all, thus reducing contaminant holding capacity and increasing flow resistance. Conversely, a "manufactured" microglass element can flow through 100% of its area which results in considerably increased contaminant capacity along with lower DP/resistance compared with a paper filter medium."George Morrison, STLE CLS
In other words, WAY better filtering, and little or no pressure drop accross the filtering surface. It's not too good to be true, it's where modern technology takes us.
BTW, Those letters at the end of Mr. Morrison's name; he's more than just an internet expert on the subject of filtration.
Re: Fram oil filter. Where have I been? [Re: terzmo] #1112774
11/15/11 11:26 AM
11/15/11 11:26 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I agree...sounds bogus to me. unless all you do is short trip the car anyway, then it's a possibility.
said paper will also absorb oil. I've seen "paper towels" that would soak up oil, but not water. we used them in centerless grinders for cutting OD on parts, and sometimes the machines leak oil into the coolant tanks when changing the diamond wheels. but I've not seen paper that soaks up water and not oil.
if you drive a car to temp, there's no water in the oil to freeze anywhere after you shut it down and it freezes outside.
that's like saying never, ever let your tank run below 3/4 before filling up, because all that air space allows humid air into your gas tank, where it will cool down overnight, condense, and then you get all kinds of water in your tank causing nothing but problems.
and filter ability vs flow is one of those trade-offs that you'll never get rid of. the better the filter is at trapping smaller and smaller particles, the less it's going to flow.
my HVAC system at home will collapse a brand new, high dollar, "micro-allergen air filter" because it's a huge airflow restriction. Toss in a cheaper "dust filter" and the airflow is where it needs to be.
**Photobucket sucks**
Re: Fram oil filter. Where have I been? [Re: terzmo] #1112775
11/15/11 11:30 AM
11/15/11 11:30 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Again, word for word:
"It is not simply a "full oil filter or stasis" situation. With paper pulp having so much of its chemistry composing water, when the filter medium becomes cold soaked at below even 32F, the water molecules can begin freezing and expanding, as only water does when frozen. The expansion fills voids, and thus potential significant filter medium restriction even beyond what paper normally does.
With a synthetic medium, the medium is completely unaffected by cold temperatures and flows as if 85 degrees..." George Morrison, STLE CLS
So, could the valve train clatter we periodically hear at could winter start-up be partly attributed to the frozen "paper pulp" media oil filter? Kinda of makes one think a little...
Re: Fram oil filter. Where have I been? [Re: CompSyn] #1112776
11/15/11 11:34 AM
11/15/11 11:34 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
That sums it up nicely.
This is a diversion from the topic about Fram filters being poorly made which is obvious when they are cut open and compared to a Baldwin, WIX, etc, but its very important to choose a filter that does not by pass more oil than gets filtered due to a restrictive filter media that creates enuf differential pressure to open the bypass valve so that it routinely happens and not just on cold starts. Add the sacred hv oil pump and you have the recipe for quick wear.
Steve
Re: Fram oil filter. Where have I been? [Re: 70Cuda383] #1112777
11/15/11 12:17 PM
11/15/11 12:17 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Actually to clarify, what George is talking about is the composition of paper naturally includes water molecules. It's these naturally occurring water molecules that freeze and expand in cold temps affecting the performance of oil filters constructed of paper media and not necessarily the paper absorbing moisture from external sources.
Okay, so what do the letters after George's name really mean?
STLE = Society of Tribologists and Lubrication Engineers
CLS = Certified Lubrication Specialist
Another quote from George:
"Regarding "seems too good to be true". Welcome to the world of microglass/synthetic filtration medium. I upgrade industrial applications every day from cellulose to microglass: go from a 30 micron paper element filter to a 6 micron microglass. Vastly improved filtration, in the 90% reduction level, as in the EaO, AND the filter generally lasts 2 to 4 times longer than the cellulose filter it was replacing. How? Generally up to 40% of a cellulose filter element passes nothing, absolutely blocked.. Whereas the microglass or nanofiber (whatever) is 100% flowable filter. So, yes, filtering much finer, flowing much easier and lasting considerably longer, even though it is capturing 90% more particulates... Indeed, it is true......" George Morrison, STLE CLS
Here's a little more about George Morrison's professional background: PetroLiance® LLC Acquired AV Lubricants - link
Read down a little, George is in there. That's why I trust what he say's about lubricant filtration and why I no longer use paper oil filters. But then again, each to his own...
Re: Fram oil filter. Where have I been? [Re: Strawdawg] #1112778
11/15/11 12:19 PM
11/15/11 12:19 PM
Rug_Trucker Offline
Rug_Trucker  Offline
One other personal experience I will add.
I installed a rebuilt engine with a Fram. Faint rod knock at cold start up. Less oil pressure. I canned it for a Purolater. 360 in my van with a HV pump.
Re: Fram oil filter. Where have I been? [Re: CompSyn] #1112779
11/15/11 12:54 PM
11/15/11 12:54 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
What ? ...NOW it is only toilet-tissue ones ? ..
Re: Fram oil filter. Where have I been? [Re: CompSyn] #1112780
11/15/11 12:55 PM
11/15/11 12:55 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have heard plenty of valve clatter at "cold" start when the ambiant air tem is 100+ degrees outside
Re: Fram oil filter. Where have I been? [Re: HotRodDave] #1112781
11/15/11 01:09 PM
11/15/11 01:09 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
that clatter at startup could be a lifter blleding off oil from sitting,oil not getting to the top end fast enough or other reseans beyond a "frozen" filter. A few years back...well maybe 20+ We had a cold snap in January where the high was forecasted to be -5. It lasted about a week (cold snap) and never heard of a frozen filter.Maybe the guys in minnesota or wisconsin have input but I know they use block heaters and heated areas alot
Re: Fram oil filter. Where have I been? [Re: terzmo] #1112782
11/15/11 01:46 PM
11/15/11 01:46 PM
dogdays Offline
dogdays  Offline
FULL DISCLOSURE NEEDED
CompSyn, does everyone on this board know you are an Amsoil dealer?
Could this be why you are touting your own product?
Don't your posts belong in the FOR SALE section?
Now on to the important stuff:
I am a mechanical engineer at a power generating station and for the last six months have been formulating a plan to bring my facility's lubrication system up to speed into the 21st century. I have been reading everything I could get my hands on about lubrication and filtering. Here is what I have found so far:
Recent research shows that particulate much smaller than the clearance of the bearings does indeed increase wear. The target filter size seems to be heading towards 3 micron absolute.
Recent research shows that varnish is particulate and can actually be filtered out of the oil.
Oil coming from the manufacturer is relatively dirty. As said in one of the quotes cited by CompSyn it is possible to filter the oil in a system to be CLEANER than new. So to think you gain in cleanliness by changing the oil is wrong. The proper industrial procedure is to filter the oil INTO the application.
Water is very bad for oil. It reduces film strength greatly. It causes additives to drop out or to become catalysts for oxidation of the oil. It can do other bad things as well, and all at less percentage than it takes to make the oil cloudy. So by the time yor oil looks like a milkshake the oil has been severely compromised for a long time.
Much of motor oil particulate has traditionally come from ingested dust. That is helped by an air filter. But there are other mechanisms active in the crankcase that can also form particulate.
We are experimenting with dessicant breathers on our oil tanks. We are also using a 3 micron absolute filter on our hydraulic oil in a "kidney loop" arrangement. This has reduced the particulate loading between one and two ISO cleanliness grades, which is HUGE.
I am in no way associated with AMSOIL but it seems to me from my reading that the synthetic medium filters (like Amsoil) are definitely better than ANY paper or cellulose filter. To me, this seems to be a fact.
If you need a better filter is for you to decide.
R.
Re: Fram oil filter. Where have I been? [Re: terzmo] #1112783
11/15/11 01:52 PM
11/15/11 01:52 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
Or, it could simply be a poorly working anti-drainback filter in a poorly built oil filter
Steve
Re: Fram oil filter. Where have I been? [Re: dogdays] #1112784
11/15/11 01:53 PM
11/15/11 01:53 PM
Frozen Wastelands, Ontario, Ca...
Dr Lebaron Offline
Dr Lebaron  Offline
After meeting Herb McCandless,I only use Baldwin oil filters.
Re: Fram oil filter. Where have I been? [Re: dogdays] #1112785
11/15/11 01:56 PM
11/15/11 01:56 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
And I get to say it, as I frequently do...
Up next -- Green bearings!
Re: Fram oil filter. Where have I been? [Re: dogdays] #1112786
11/15/11 01:58 PM
11/15/11 01:58 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
R.
It should be obvious to anyone that he is a dealer. All you have to do is click on his name if it is not that obvious to you.
On the other hand, he never, to my knowledge, tries to get anyone to buy from him, or from Amsoil, but, he does bring tech data to the table to support his statements.
Seldom does anyone refute the data he presents. I don't see any problem and I do appreciate his efforts to present data rather than making claims followed by a plea to buy something from him.
Steve
Re: Fram oil filter. Where have I been? [Re: Dr Lebaron] #1112787
11/15/11 01:58 PM
11/15/11 01:58 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
That has been my choice for years
Steve
Re: Fram oil filter. Where have I been? [Re: Strawdawg] #1112788
11/15/11 02:18 PM
11/15/11 02:18 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Why not just buy that System1 filter for $190 bucks with the filter that can be washed...No need for the hoohah of buying a new one...Just put it in your dishwasher and call it a day.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
