Page 2 of 5 1 2 3 4 5
Re: Fram oil filter. Where have I been? [Re: 1_WILD_RT] #1112749
11/14/11 01:03 AM
11/14/11 01:03 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
(Quote)
if you care the PH3600 is the small diameter full length version...
and that explains why I can put the ph8 on our 2000 mini van.
I have mechanical Aptitude.
I can screw up anything.
Re: Fram oil filter. Where have I been? [Re: bboogieart] #1112750
11/14/11 08:25 AM
11/14/11 08:25 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
The big retailers, Advance, Autozone, etc., tend to buy their products based on price. If it's cheap, they buy it. NAPA on the other hand, tends to buy product that meets and often exceeds OE specs. NAPA also checks what they buy to make sure it meets their specifications. The retailers usually do not.
Re: Fram oil filter. Where have I been? [Re: TooMany62s] #1112751
11/14/11 08:54 AM
11/14/11 08:54 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
If that's true, then are WIX filters bought at the big retailers different than the ones from the NAPA dealers?
Re: Fram oil filter. Where have I been? [Re: TinCuda] #1112752
11/14/11 09:04 AM
11/14/11 09:04 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I find it amusing thinking that 1/2 the oil filter "experts" who make adamant unconditional opinions here probably couldn't even rebuild a Briggs & Stratton...
"Nothing is more dangerous than a man who read a book once"
Reminds me of the Corvette forums where 9/10ths of the members wouldn't know which end of a screwdriver to use will run epic threads on "best waxing procedures".
Not one person has asked timcuda about his 440 or how it will be used.
Once a week to the Dairy Queen car show?
Sub 11 all out runs every weekend?
I'll take a shot at the fact that he could buy the cheapest oil filter at Walmart on sale and his engine would not be affected one iota.
YES! I know there have been threads opinionating what a POS the cheapest Fram is. If I had one on the shelf while doing an oil change on my DD, I wouldn't hesitate a second to put it on.
Re: Fram oil filter. Where have I been? [Re: TinCuda] #1112753
11/14/11 09:27 AM
11/14/11 09:27 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have used many Frams over the years, the 440 I bought in 2005 had one on it. I started the new motor with it on it and replaced it at the first oil change.
For the last 10+ years or so I have been using Hastings filters because I know the local sales rep. I maintain about 20 vehicles for a living plus many small engines and off road equipment.
FWIW I only replace filters every other oil change most times, my
Re: Fram oil filter. Where have I been? [Re: Challenger 1] #1112754
11/14/11 10:16 AM
11/14/11 10:16 AM
Athens, Greece
Pyper70 Online content
Pyper70  Online Content
Athens, Greece
I have always used Fram. Never used anything on my Slant to 440 cars except the PH8A. I know that my oil gets changed once a year because I probably put 500 to 1000 miles on it in that span of time. I know it oxidizes. When I do an oil change I want to use a good filter because using a cheap one just doesn't do it for me. I thought Fram was an okay brand. I saw what people here said and although I never had a problem, I didn't want to become a future statistic.
I am probably the only person on this board that uses a MANN filter. Its the same size as a PH8A. It costs about $8 a filter. Heavy diesel trucks use them in Europe. I was going to go for a Napa Gold or Wix but I can't remember which of the two had the problem of not having an Anti-drainback valve. I'd like to have my oil filter full when cranking my engine. Plus its nice to have a product from an ISO 9001 company
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Fram oil filter. Where have I been? [Re: Pyper70] #1112755
11/14/11 10:40 AM
11/14/11 10:40 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Fram has always been the bottom of the filter barrel.
Why do some not have issues??
Try this, with an old junk car, cut the guts out of the filter so it cannot filter anything. Put it on and it will run 100,000 miles!!!
Open up any filter you will trust to protect your expensive motor and look at it. What you see is what you get.
Do you want to filter your oil with cardboard ends?? Or steel/plastic??
Re: Fram oil filter. Where have I been? [Re: Pyper70] #1112756
11/14/11 01:55 PM
11/14/11 01:55 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
This topic resurfaces continually here. Reminds me of the topic of which came first? The Chicken or the Egg? I don't propose to tell anyone what to spend their money on when doing their Oil changes. Buy what ever you want. Makes no never mind to me. Just remember that you get what you pay for and in this instance Fram's are the bottom feeder of Oil filters. Cheap and inexpensive yes. But the end results when an engine fails because of "CHEAP" mindedness, should give anyone with an ounce of sense, pause for concern. As the saying goes, "You get what ya pay for" and so goes the way of Fram filters. For me, Wix/Napa, Autocraft FL 1A. or K&N. Why would anyone spend large amounts of their hard earned money on an engine re-build and then throw a cheap Fram filter on a fresh 440....
Re: Fram oil filter. Where have I been? [Re: CR8CRSHR] #1112757
11/14/11 02:07 PM
11/14/11 02:07 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Got 140k+ on the wifes 4.7 Durango. Have always used Fram filters (PH8 or PH43). Rods haven't been kicked out yet!!
But I change my oil every 3500-4000 miles.
Now, I wish I could say the same about the trans.
Re: Fram oil filter. Where have I been? [Re: Commando1] #1112758
11/14/11 02:45 PM
11/14/11 02:45 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
The guy asks a question and another uses the forum for a "soapbox" oration on how He feels about reading vs doing.( and without sound documentation attempts to insult 1/2 the site members) What has that got to do about recommending a good oil filter? I've read that putting a 357 magnum to one's temple and pulling the trigger will most likely blow one's brains out..seems logical but I'm not going to try it. And it doesnt't make Me an "expert" on the subject because (per His logic) I never did it.
Re: Fram oil filter. Where have I been? [Re: terzmo] #1112759
11/14/11 10:49 PM
11/14/11 10:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Nobody...NOBODY loves to save $$ than the factory... So why does a factory Mopar filter have nearly twice the filter media than the recommended Fram?
Re: Fram oil filter. Where have I been? [Re: J_BODY] #1112760
11/14/11 11:03 PM
11/14/11 11:03 PM
IN
ahy Offline
ahy  Offline
IN
I had used Fram for some time then read several filter "teardown" posts and links with pics. There's not much filter area in the Fram and filter material and valving seems cheap. Those posts along with credible reports of bypass valves sticking open or closed steered me away. No I have never blow up an engine or lost oil pressure with one... I don't plan to find out by trying either. I use something else.
Re: Fram oil filter. Where have I been? [Re: J_BODY] #1112761
11/14/11 11:09 PM
11/14/11 11:09 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Good point!
And the answer is "Because if the engine fails the manufacturer pays the warranty".
No one said every Fram filter will fail. It's just that for a couple of bucks, why take a chance.
Re: Fram oil filter. Where have I been? [Re: TooMany62s] #1112762
11/14/11 11:40 PM
11/14/11 11:40 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
The Fram filters have failed and killed many Cummins engines.
The Cummins uses an oil port to cool the bottom of the pistons. The premium cardboard use din the fram broke down and passed thru the oil system plugging the cooling jets.
If that isn't enough to stay away from cheap I don't know what is.
BTW, Cummins says your warrantee is with Fram not them!
I work on a few Cummins trucks and when I see that cheap filter, I tell them about the failures. Then I tell them to go home and change it to anything better-- wix/NAPA works then come back.
Yes, I have seen that filter kill a Cummins. Plug a cooling port is melting a piston on a turbo deisel.
I really don't care what you want to do with your ride, I'm telling you members some real life experiences!!
Re: Fram oil filter. Where have I been? [Re: RodStRace] #1112763
11/15/11 06:28 AM
11/15/11 06:28 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
You can do search here, or look for bob is the oil guy.com
The HP filters may be okay, but the standard Frams are proven to be the bottom of the barrel in quality and performance.
Are the HP1 filters made better than a standard orange Fram?
Re: Fram oil filter. Where have I been? [Re: RoadRunnerJD] #1112764
11/15/11 09:48 AM
11/15/11 09:48 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Nothing to fear from the HP1, or any of the HP series, but they are racing filters and the filter media will have a larger micron rating.
Re: Fram oil filter. Where have I been? [Re: RoadRunnerJD] #1112765
11/15/11 09:50 AM
11/15/11 09:50 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
wasn't there a thread about two or three years ago where sombody cut apart all the different filters and showed the diff. I'm sure i've seen something on here lately showing the same thing. Just can't remember where. See if I can find it .
Re: Fram oil filter. Where have I been? [Re: mopar_man] #1112766
11/15/11 09:55 AM
11/15/11 09:55 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Re: Fram oil filter. Where have I been? [Re: mopar_man] #1112767
11/15/11 10:00 AM
11/15/11 10:00 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Re: Fram oil filter. Where have I been? [Re: RoadRunnerJD] #1112768
11/15/11 10:02 AM
11/15/11 10:02 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
WIX, Fram, NAPA, etc... All of them utilize paper filter media. The manufacturing of paper filter media is not exact. As much as 40% of the filtering area of paper oil filters filter nothing at all, as in the filter is 40% blocked right out of the box.
Plus, how does paper respond to moisture? Right, it absorbs it. What does paper filter media do when it absorbs moisture from engine condensation and then it gets really cold outside. Yep! It freezes. Now your paper filter that was 40% blocked when new is now frozen and is really blocked. Now you have a completely worthless oil filter that's in bypass mode at cold engine start-up until it thaws out.
Do yourself a favor, do your engine a favor and throw out the paper oil filter. Then look for a micro-glass or better yet, a nano-glass oil filter. Previously only available in commercial and industrial applications, glass filter media technology has made it's way to the car and light truck market.
Seriously, research it.
Start here if you like: http://www.youtube.com/user/ckermit8
