Re: 1rst hit on 28x10's video
[Re: bigtimeauto]
#1111851
11/12/11 09:50 PM
11/12/11 09:50 PM
Posts: 414 pa
demongup
pa
I can tell you how fast it went..........anybody want to paypal me some money.
Pay me and I will tell u , lol No secrets here . Just ur everyday 8.50 index car
[Re: bigtimeauto]
#1111853
11/12/11 10:01 PM
11/12/11 10:01 PM
Posts: 414 pa
demongup
pa
[Re: demongup]
#1111854
11/12/11 10:12 PM
11/12/11 10:12 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
...... ................3000 lbs BB NA (Over 640 c.i.)............................................. .................3200 lbs* *No Billet Heads BB N20 (**3stage max limit on BB N20.**)...................................3325 lbs add 50 pounds for unconventional heads add 25 for extra carb BB Single Blower/Turbo( F3/106MM MAX)............... ...................3450lbs BB Twin Combos (88MM Max) or Single Blower/Turbo over F3/106MM...........3550 lbs
Inline 6 Cyl (Turbo/N2o Combos)........................................... ..-600 lbs (Deduct from SB blower turbo Weights) 4 Cyl/Rotary (Turbo/N2o Combos)...........................................-800 lbs (Deduct from blower turbo Weights) **Inline 6 & 4 Cylinder Boosted Combos are allowed 1 single N2o Nozzle between Turbo/Blower and Intake**
CHASSIS/SUSPENSION: 1.)Leaf Spring Only Suspension!!! 2.) No full chassis car 3.)Can move leafs in and shocks can be in any location. 4.) Frame Notch permitted.
BODY/INTERIOR: Anything goes as long as at weight, no tube chassis back half cars. Stock Appearing interior. Must run mufflers(Except Turbo Entries). No Billet heads (execpt SB NA) ALLOWED!!! No wheelie bars!!! Max 275/60 drag radial or 28x10.5 non w slick Sidewall
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1111855
11/12/11 10:13 PM
11/12/11 10:13 PM
1967dartgt
Hilltown Pa
PROFORMANCE / STEELE FABRICATION / AVERY ENTERPRIZES LEAF SPRING SHOOTOUT (150.00 TECH CARD) (NO MINIMUM CAR COUNT FOR PAYOUT) 4,000.00 win 1,000.00 r-up 300.00 -semis 150.00 - 1/4's Single power adder only except 4cylinder or V-6) No billet heads except NA SB NA................................................ ........................ ............ 2700 lbs SB N20 .................................................. ................................ 3100 lbs add 50 pounds for non conventional add 25 for extra carb SB Single Blower/Turbo............................................. ............. 3300 lbs SB Twins.................................................. ................................3350 lbs BB NA (Up to 640 c.i.)............................................. ................3000 lbs BB NA (Over 640 c.i.)............................................. .................3200 lbs*
[Re: MIKES_DUSTER]
#1111860
11/15/11 12:40 PM
11/15/11 12:40 PM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Lookin good Gup!
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
