Anyone remote power steering pump on an older Mopar
#1111072
11/10/11 10:44 PM
11/10/11 10:44 PM
Posts: 181 Washington State
70chall440
Washington State
I am trying to figure out how to run a remote PS pump/reservoir on my 73 Cuda (416 CI, EFI 6 pac) and wondering if anyone out there is or has done it. There appears to be several options running from the Type II GM style to the late model Mopar versions. However I do not know the line pressure I should be looking for and subsequently would will work. I want to run one to clean up the left side of the motor and since this is a bit of a road race car, I think it will give me some options; not to mention I am not fond of the factory PS pumps, expecially thier pulleys. I can fabricate the brackets once I have a pumpt to work with.
01 Viper GTS ACR 10 Challenger RT PCP 6spd 70 Challenger 440 6 pac 73 Cuda 416 Road Racer 70 Hemi Roadrunner 01 Ram 4x4 / 98 Ram 3500 91 Stealth RT 05 Durango Hemi 09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: Anyone remote power steering pump on an older Mopar
[Re: MoparMarq]
#1111074
11/11/11 07:03 PM
11/11/11 07:03 PM
70chall440
Washington State
thanks, I remember reading about that now that you mention it. You are right, there are lots of pumps. I just needed a place to start (now I have one).
[Re: RV2]
#1111079
11/12/11 12:13 AM
11/12/11 12:13 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Some of the mid-late 80s HD trucks with the 360-4v also had a remote resevoir. They had two smog pumps so they had to have the remote resevoir. The pump bolts to a stock bracket IIRC and you would have to find a place to mount the resevoir.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: astjp2]
#1111082
11/13/11 01:26 AM
11/13/11 01:26 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
The stock mopar pumps like the one pictured above is a POS, we run them on jeeps and go through them like crazy. Get a good saginaw with brackets and never worry about them again. Tim
I thought this was a Sagninaw pump pictured below and in AndyF's post? That pump is the same style as the ones we run on our circle track cars.
![](https://board.moparts.org/ubbthreads/upload2/6914623-DSC_0518%28Medium%29.JPG)
[Re: astjp2]
#1111085
11/13/11 04:51 AM
11/13/11 04:51 AM
autoxcuda
So Cal
This is more like what I would buy, need a pulley though and stock brackes from small block fit. TIm
http://www.pscmotorsports.com/94-02-dodg...e-feed-can.html
That looks like the oval canned Saginaw pumps use off and on in late 60's all the way up to the 80's.
The Federal and Eaton round filler neck pump, IMHO, blow.
[Re: autoxcuda]
#1111087
11/13/11 10:55 AM
11/13/11 10:55 AM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
What AN attachments are you using 1. to get the high pressure side from the pump to the sector 2. the fittings on the sector for the high pressure and low pressure sides side
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: kilroy]
#1111090
11/13/11 03:17 PM
11/13/11 03:17 PM
autoxcuda
So Cal
Never mind.
Found some here. Does this look right?
http://www.jimsautoparts.com/steering_parts.htm
FW-923 Power Steering High Pressure Hose FITTINGS Fits All Year, Make & Model $ 39.95/pr
No. That's just a right angle version of what you probably allread have on your car. It's just compression fitting, not AN.
You need a fitting that goes from that thread in the box with a o-ring to AN. I thought there was something out there. Check/call http://www.ormebrothers.com/
DO NOT buy anything from Jims Auto Parts. They have a horrible reputation in this industry for service and price. For example that Saginaw power steering pump rebuild kit Jims lists for $89 can be bought at Rock Auto or any local parts store for under $20.
