Page 2 of 3 1 2 3
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: BradH] #1110003
11/09/11 01:47 PM
11/09/11 01:47 PM
tboomer Offline
tboomer  Offline
Brad...I sure do miss some of Dwaynes stuff..I always respected what he had to say!
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: tboomer] #1110004
11/09/11 02:03 PM
11/09/11 02:03 PM
Idaho
LaRoy Engines Offline
Idaho
Some good info here..But how the heck did you get 2.25 valves into an rpm head? Thanks!! Ted (Sorry,Randy,for the Hi-jack)
Well, I used big intake seats.
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: Labratt] #1110005
11/09/11 02:09 PM
11/09/11 02:09 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Randy....I was looking at your signature and I see your engine is a 448(.040 over)..
my 499 was a 448 and had StageVI heads, non maxwedge w/2.14 intakes...of course those heads have raised ports...and compared to maxwedge openings and runner size, they were tiny...but yet with a .557 cam, the Duster would rock...consistant 10.0 and occasional dip into the 9's..and that was when it weighed 3300lbs gross..
so what Im saying now after looking at your info, money probably better spent on the porting and flow correction, then get a cam specked to your flow numbers...
or just can the heads and get bigger stuff...LOL
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: smokinwoody] #1110006
11/09/11 02:36 PM
11/09/11 02:36 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
If i were you Randy, i would have Jeff mill .050 off the heads and try the 2" supersucker, i'm going to try one next year.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: deaks] #1110007
11/09/11 02:41 PM
11/09/11 02:41 PM
detroit area
moderncylinder Offline
detroit area
with the 2.190 intake valve you shroud the valve with a smaller bore,, it probably is a gain but usually we only do it with a 4.375 bore or bigger
at a 2.190 the intake valve seats completely on the exh seat where the seats interlock,, this may cause issues in the life on the valve job, though for a drag race car that you freshen every 200 runs or so its fine,, for a real street car,, i dont know if id do it
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: moderncylinder] #1110008
11/09/11 03:39 PM
11/09/11 03:39 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I did not even realize at first when I went with the Indy EZ heads that they have the 2.19 intake valves. And Dwayne Porter told me to make sure I not only check piston to valve clearence but to check the radial clearence of the valves to the piston. In other words it could have enough clearence from the top of the pistons to the valves but could still be to close from the side of the valve head to the piston in the eyebrow. Mine was ok as I used the clay method to be sure. I went with the EZ heads in case I want to step it up more down the road I feel the EZ head has more potential then the Eddy's if maxed out. Randy are you leaving the shortblock as is ? Ron
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: 383man] #1110009
11/09/11 07:21 PM
11/09/11 07:21 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Ron..the answer to your question is YES...stock,re-conditioned rods and all! Brad,the answer to your question is also YES! I'm still looking for that "magical" $500.00 carburetor! I REALLY do appreciate your very fair offer on the Demon RS...and you loaning it to me this past summer! THANK YOU! After reading Jeff's comment...looks like the 2.14's are staying put! After what I found when removing the rocker arm assembly....looks like a set of HEAVY DUTY pushrods are in order! I'll post a pic a little later this evening! I need to get some Play-Dough and check the piston-to-valve clearances to determine amount to mill for CR increase. Maybe 11.5 or 12:1...if allowable.
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: Labratt] #1110010
11/09/11 07:27 PM
11/09/11 07:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At those compression ratios I think your going to
be getting away from pump gas(to me its not worth it)
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: MR_P_BODY] #1110011
11/09/11 09:53 PM
11/09/11 09:53 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Welllll....maybe just 11:1!
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: Labratt] #1110012
11/09/11 10:28 PM
11/09/11 10:28 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Randy,
it looks like you are loseing the forest because of the trees.
flowing/porting your heads will tell you what you can have/make.then spend the coin on a cam and decent carb.
heck i just recammed a 440/512 and picked up near as 40hp with a still streetable solid.Dwayne Porter did dress up the heads a few years ago.
you may even want to look to your fuel system and suspension to pick up more et.
good luck
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: firefighter3931] #1110013
11/09/11 11:13 PM
11/09/11 11:13 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
My ... you won't notice the difference anywhere except for your bank balance. Unless Jeff K says differently (and his experience obviously far exceeds mine), your combination isn't going to see a significant benefit from a increase in valve size.
And if you don't spend the additional $$$ on bigger valves, that'll leave you w/ that much more $$$ to buy a new carburator (unless you've already made that purchase).
Leave the 2.14's in there and save for a new carb
I'd also have MCH flow a few ports before & after to see what improvement you could/should expect with the cnc work
Ron
X3 with your combo.
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: Sport440] #1110014
11/10/11 12:09 AM
11/10/11 12:09 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: Sport440] #1110015
11/10/11 12:33 AM
11/10/11 12:33 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Mike! Tex..I HOPE this Comp Solid that Dwayne spec'd out for me a few yrs. ago will still work!...I REALLY like it! BTW...here is a pic of the pushrod I found when I pulled the driver's side rocker arm assembly off! WTH! I'm glad I didn't take it down the track 1 more time,a few weeks ago! Time to do some research on pushrods!..Smith Bros...Mantons..Trendz? Here are a couple of pics!
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: Labratt] #1110016
11/10/11 12:36 AM
11/10/11 12:36 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
ANOTHER!
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: Labratt] #1110017
11/10/11 12:44 AM
11/10/11 12:44 AM
Delray beach, Florida
P
Performance Only Offline
P
what brand were those?
machine shop owner and engine builder
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: Labratt] #1110018
11/10/11 12:49 AM
11/10/11 12:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What brand pushrods are they Randy ? Ron
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: LaRoy Engines] #1110019
11/10/11 01:07 AM
11/10/11 01:07 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
As I remember, the seat's already large enough for the 2.250 valve.
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: 383man] #1110020
11/10/11 01:14 AM
11/10/11 01:14 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Dan..Ron,they're from a local company..OEM Products in Mt. Clemens,Mi. Mr. P-Body(Mike Rafferty)has been using their products for quite a while...with no problems whatsoever! And he revs his W-9 small blocks a whole lot higher than my 440! I'm going to pay them a little visit..hopefully tomorrow! I believe it's a QUALITY issue...heat treat issue! I might go visit Jeff K. first...I believe he's got a Rockwell hardness tester at his shop.
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: camdog440] #1110021
11/10/11 01:26 AM
11/10/11 01:26 AM
Idaho
Idaho
There are some good comparisons here...
http://users.erols.com/srweiss/tablehdc.htm#Chrysler_Big_Block
There ya go, there ya go! Look at the big increase in flows at the lower lifts. Even if 15% of the bigger valve sees a subtle increase in shrouding, it won't lessen the total flow in that area compared to the smaller valve, and if it did, other 85% of the larger valve more than makes up for it. And lets not hear that bologna about big valves lowering the port velocity and torque. The velocity will be controlled, in the greater part, by cubic inches and rpm vs the smallest sectional area of the port, not the valve size. You will see greater average torque with the bigger valve. Everytime we put in bigger valves we see power increases in 318's to 500's.
Re: 2.19 INTAKE VALVE IN EDDY PERFORMERS??? [Re: dodgeboy11] #1110022
11/10/11 01:42 AM
11/10/11 01:42 AM
Idaho
Idaho
On all the RPM heads I have seen, the original intake insert is not big enough to contain the entire 2.25 valve. Therefore, you have to grind the seat for the intake valve into the exhaust seat insert, unless, you replace the intake insert with a larger one. The new intake insert does not interfere, with the exhaust valve seat area in the exhaust insert. Whew!
Page 2 of 3 1 2 3
