89 grill swap #1109978
11/09/11 01:38 AM
11/09/11 01:38 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
ok i got a grill out of a 89 w150 an i want to swap it into my 85 w150, i pulled the old grill out an went to put the new 1 in an it would not fit??? whats up do i need to pull the light bezels out?
drive fast, drive hard, DRIVE MOPAR
Re: 89 grill swap [Re: lifted85] #1109979
11/09/11 11:32 AM
11/09/11 11:32 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
The 86-90 grill itself is wider than the 81-85 style. To use the 89 grill you will have to change the large grill surround piece and headlight bezels as well.
Keep in mind the the headlights are attached to to the radiator support in a slightly different spot too, so the headlights won't be quite square in the headlight bezels either, but they do fit.
