A518 transmission problems *DELETED* #1108372
11/06/11 11:06 PM
11/06/11 11:06 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
Post deleted by rhad
Re: A518 transmission problems [Re: rhad] #1108373
11/07/11 01:06 AM
11/07/11 01:06 AM
oklahoma
72383cudaman Offline
oklahoma
probally a servo or the valvebody most shops dont replace or check the electronics during a rebuild and the valve body if the trans has overheated for one the cylender for the shift piston is cast way to thin and warps easly if it has a hard shift eratic shift revs high and takes a few seconds to shift id say valve body my 95 i just sold you could take off fine stop then would have hell takin off again ended up being the valvebody
