1968 B029 and LO23 SS A-body disc brakes? #110834
08/26/08 07:46 PM
08/26/08 07:46 PM
Sacramento,California
JRepucci Offline OP
JRepucci  Offline OP
How did they achieve large bolt pattern with small bolt spindles?
Re: 1968 B029 and LO23 SS A-body disc brakes? [Re: JRepucci] #110835
08/26/08 08:54 PM
08/26/08 08:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
a special rotor that is no longer available .
Re: 1968 B029 and LO23 SS A-body disc brakes? [Re: JohnRR] #110836
08/26/08 09:21 PM
08/26/08 09:21 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
The factory delivered setups were Budd 4 piston disk brakes as used on the c-body car line in 1968. I was the caretaker of a 68 ss dart and the front brakes had been changed over to single piston calipers sometime in it life so could not say for sure what the original spindles looked like or part number used.
Re: 1968 B029 and LO23 SS A-body disc brakes? [Re: SCATPK] #110837
08/26/08 11:20 PM
08/26/08 11:20 PM
JRepucci Offline OP
JRepucci  Offline OP
I think there was someone here on Moparts that hada set of hubs for this application but no rotors.
Re: 1968 B029 and LO23 SS A-body disc brakes? [Re: JRepucci] #110838
08/27/08 01:00 AM
08/27/08 01:00 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You don't know?
I'n done with you
Re: 1968 B029 and LO23 SS A-body disc brakes? [Re: Morty426] #110839
08/27/08 01:38 AM
08/27/08 01:38 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I had heard the disk hub came from the 66 Trans Am program. 66 A-body KH disk is the same until 72. Scott Harvey had big bolt pattern hubs made/approved for the 66 T/A cars.
The hub on the 66-72 A-body disk is sort of non wear item. The disk is just pressed to the hub.
Bob Tarrozzi happened to be in town the Spring Fling Speed Festival this year (motorcycle race the next day). He was the engineer assigned to the 68 S/S project. I asked a bunch of questions mostly about his Trans Am and Nascar involvement. What I didn't know was that Tarrozzi was a hands on working member of Harvey's "Team Starfish" race T/A group at Chrysler.
Now I see how a S/S project could get connected with 66 Trans Am parts.
