69 B door mirror #1107586
11/05/11 01:53 PM
11/05/11 01:53 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
2 questions....Whats the best way to polish the chrome, and 2... is there a way of swapping the glass from a pitted frame to a clean one?
Re: 69 B door mirror [Re: mro] #1107587
11/05/11 06:02 PM
11/05/11 06:02 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
1) i use Turtle wax chrome polish but there is any number available
2) no, not without breaking it
Re: 69 B door mirror [Re: mro] #1107588
11/06/11 04:42 AM
11/06/11 04:42 AM
Tony Offline
Tony  Offline
I have been able to remove glass without breaking it on the manual operated B body door mirrors. I put the whole mirror in the oven at 200 degrees. After about 20 minutes I removed it(using gloves of course). I then used a tool I have that is designed for bleeding brakes without help. It is a plastic vacuum pump. The pump came with a hose and at least one suction cup that attatches to the end of the hose. Place the suction cup on the mirror and build vacuum. Then just pull gently and the glue will be soft enough to pull the glass away without breaking it. I was able to save some good date coded glass this way.
Re: 69 B door mirror [Re: Tony] #1107589
11/06/11 12:02 PM
11/06/11 12:02 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Someone had mentioned in a different thread that they had good luck with soaking the mirror assy in lacquer thinner overnight.
Re: 69 B door mirror [Re: mro] #1107590
11/06/11 12:19 PM
11/06/11 12:19 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
unless the code is important to you just have a glass shop cut a new one?
