Page 2 of 3 1 2 3
Re: Run ATF to clean a gunked motor? [Re: Golden-Arm] #1106943
11/04/11 02:23 PM
11/04/11 02:23 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
the risk is small, but it's there. a diesel runs on higher compression, and you'd think some water wouldnt hurt. i've seen several diesels throw a rod or blow the top off the power assembly, from a leaking water jacket. (emd locomotives) i've also hydro-locked a diesel, trying to crank it, with water in the cylinder. bent a rod, but didnt break it.
i use an empty dish detergent bottle, and just drizzle it, in a really light stream, with the motor at a very high idle. maybe 2000-2500 rpm. you'll know you're adding too much, when the motor starts to bog down, as it fights to compress the water. i also have the car hot from driving before doing this, or you might fill the mufflers with water and crap, helping to rust/clog it.
the gas today is a lot cleaner (some of it's clear, like water, vs the dark orange stuff we used to pump) and as long as your guides arent leaking, and you dont just idle the motor endlessly, it shouldnt be all that dirty. once or twice a year should be fine, if you worry about deposits. if the plugs are clean and dry, i would imagine the rest of the combustion chamber is, as well.
That's the problem, this motor has not been run much besides idling for the past 4 years. There has been no "punching it" so that's why I cam guessing this should be done.
Thanks for the help!
Re: Run ATF to clean a gunked motor? [Re: cjskotni] #1106944
11/04/11 03:13 PM
11/04/11 03:13 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Mopar Combustion Chamber Cleaner - unless you live in California where you can't get it anymore - so it must be good!
Re: Run ATF to clean a gunked motor? [Re: 70runner] #1106945
11/04/11 03:32 PM
11/04/11 03:32 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
If the car is just dieseling, I would check the timing and/or idle mixtures.
The rest of the info on cleaning stuff is good none-the-less
Re: Run ATF to clean a gunked motor? [Re: cjskotni] #1106946
11/04/11 03:37 PM
11/04/11 03:37 PM
I have seen a running motor bend a rod due to water ingestion As already suggested put new gas in it and drive it for a long trip to warm the oil up and suck out the bad gas that is in the tank. That or drain the tank, put all new fuel in it and then drive it for 50 miles or more I've done all the old school stuff down the carb, a water and alcholol injection system will help clean the combustion chambers if you absolutely want that done One thing you need to remember about all the old school methods, that was when all gasoline had lead in the fuel Lots more deposits in the motor and exhaust sytem then than now, also keep in mind that those motors ran under 180F on a hot day, not like todays motosr runniing EFI and over 200 F to keep them effecient by atomizing the fuel better Don't pour any water, oil or ATF into the carb
Re: Run ATF to clean a gunked motor? [Re: hooziewhatsit] #1106947
11/04/11 03:38 PM
11/04/11 03:38 PM
michigan woods
imfixinmopars426 Offline
michigan woods
years ago i had a 70 chevelle 307+glide..she used oil,so at the tranny shop i had all kinds of cheap atf...so i ran pure atf...for a long time,no issues at all...in the end,the engine was very clean inside...and wouldnt die...lol.
Re: Run ATF to clean a gunked motor? [Re: imfixinmopars426] #1106948
11/04/11 03:47 PM
11/04/11 03:47 PM
GA
Boosted Offline
Boosted  Offline
GA
ATF has to high of a flash-point... Use something like Marvel Mystery oil or some 2 stroke oil...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Run ATF to clean a gunked motor? [Re: Boosted] #1106949
11/04/11 05:11 PM
11/04/11 05:11 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Dang! You guys are killing me! The use of ATF, kerosene, diesel fuel etc. is intended as an engine oil additive by adding one quart to a hot idling engine and letting it idle for 5 minutes then to change oil. This is to help unstick rings, valves and lifters. If you look into the oil filler cap and see lots of buildup this is a good temporary fix but more than likely you need to replace your valve stem seals. As for the water injection, that is to break up carbon buildup in the combustion chamber and pistons and it's done by revving the engine up to about 1500RPM and SLOWLY pouring in just enough water to slow down the motor while trying to maintain 1500RPM for about 15-30 seconds. Caution has to be noted here as large chunks of carbon can break off and get lodged in the valve opening causing a bent valve.
Now as for the original posters problem with dieseling. This is most likely caused by what was previously mentioned as timing too retarded or running too rich. The ladder being my guess as old gas and old carb seals are probably causing seepage. I'd freshen up your carb, check your timing, check for vacuum leaks and see where that leads.
Re: Run ATF to clean a gunked motor? [Re: Dusted_Ya] #1106950
11/04/11 05:37 PM
11/04/11 05:37 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Hydralic lock isn't just a water issue!! an oil do it just as easy!!!
This is how I've always done it.
With a warm engine, dribble water in at a rate just fast enough to regulate the RPM while holding the throttle 1/4 open.
This is steam cleaning the combustion chamber.
never put an oil down the intake passage.
Use a light oil MMO, ATF Diesel in the oil pan 30 minutes before an oil change, and do not drive it very far, if at all. Oil will be too thin to do its job under heavy load.
I have seen the ATF in the intake and it just oils the passages and of course makes it look like the operator has NO CLUE what he is doing, other than killing mosquitos!!!
Re: Run ATF to clean a gunked motor? [Re: cjskotni] #1106951
11/04/11 11:36 PM
11/04/11 11:36 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you are wanting to clean the combustion chambers, then there are some very good products just for that purpose. And they work much better than water or ATF or Diesel.
It's called something like combustion chamber cleaner or upper cylinder cleaner and is available at a lot of places. Boat shops use it all the time. I keep some of GMs upper cylinder cleaner to clean carbs with. Works better than carb cleaner and is water soluable.
This is the same stuff that JC WHitney used to call Tune-Up-In-A-Can. But it works very well. In fact, the outboard service schools recommend these products as the preferred choice to clean their carbs. So I have used this stuff instead of carb cleaner for 20 years. Seems kind of funny that a product that is designed for and does a good job of de-carbonizing combustion chambers is not very well known.
As to the question of whether that is the root of the OPs problem, well, maybe, maybe not. But it doesn't take much time or money to clean the combustion chambers and at least rule it out.
Master, again and still
Re: Run ATF to clean a gunked motor? [Re: DaveRS23] #1106952
11/05/11 07:38 AM
11/05/11 07:38 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
We used to use the cheapest pump spray glass cleaner (cheap Windex). It's mostly water, alcohol and dye. Warm engine, put on highest fast idle - about 2500 and spray it in about as fast as you can squeeze the pump without stalling engine - use about 1/2 the large bottle. Take off fast idle, spray in and stall engine. Let sit for 10-15 min, re-start, and run at about 2000 for about a minute.
The nice thing about doing it this way is you can control the liquid better without having to worry about locking the motor up.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Run ATF to clean a gunked motor? [Re: 70runner] #1106953
11/05/11 10:14 AM
11/05/11 10:14 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I have a feeling it's relabeled Seafoam.
Re: Run ATF to clean a gunked motor? [Re: Commando1] #1106954
11/06/11 02:38 AM
11/06/11 02:38 AM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
One more vote for water. I don't mist it either. I do the garden hose. Unless you're into filling the neighborhood with smoke. Then you can use tranny fluid. Then it'll also set on the insides of the exhaust and will take centurys if not longer to get completely out of your system.
Re: Run ATF to clean a gunked motor? [Re: Leadfoot] #1106955
11/06/11 10:54 AM
11/06/11 10:54 AM
NY NY
3
340duster340 Offline
NY NY
get a siphon and train your tank, pump out the fuel line at the front of the car with a primer bulb and replace all soft lines and filters.
should be good to go.
i just got a 66 dart running that had been sitting for 10 years. the gas looked like OJ....did the above plus a quick carb doosh and it was running with no probs. a lot of times the floats and various passages with in the carb will get gacked up when sitting too long.
Re: Run ATF to clean a gunked motor? [Re: cjskotni] #1106956
11/06/11 11:16 AM
11/06/11 11:16 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
sure Your idle isn't too high ?
Re: Run ATF to clean a gunked motor? [Re: Commando1] #1106957
11/06/11 11:34 AM
11/06/11 11:34 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
diesel will do the same thing only cheaper. You guys using water may as well leave all your condensation in your gas tank and oil - hell all it is doing is flushing & cleaning our oiling and fuel systems.
Re: Run ATF to clean a gunked motor? [Re: RodStRace] #1106958
11/06/11 11:57 AM
11/06/11 11:57 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
BG fuel Induction service.
Drizzle water down the carb.
Take it out and romp on it.
ATF is for cleaning the inside of the engine, add to oil, warm without heavy loading and drain.
BG induction cleaner sucked through a vacuum source at the base of the carb that has constant vacuum.Do one can then take it out and get it warm and then repeat one more time.
I use an old A/C can tap just make sure you put a restriction in the hose so it's metered instead of pouring it down the throat of the carburetor.
Gus
64 Plymouth Savoy
Dana 60
Re: Run ATF to clean a gunked motor? [Re: Boosted] #1106959
11/06/11 01:00 PM
11/06/11 01:00 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..neighbor told me GM had service bulletin instructing the use of ATF to clean and free up noisy lifters.
Re: Run ATF to clean a gunked motor? [Re: can.al] #1106960
11/06/11 02:43 PM
11/06/11 02:43 PM
Upper Midwest
Upper Midwest
Been doing that for many years and it has been stated many times her e too. Ad a few miles before and oil change. ATF has very high detergent content. In fact if you have dirty grease cruddy hands dip into some ATF and rub in like GoJo and they will be just as clean.
Re: Run ATF to clean a gunked motor? [Re: MoparforLife] #1106961
11/07/11 01:02 PM
11/07/11 01:02 PM
Colorado
68FuryIIIColo Offline
Colorado
I have also used the Mopar cleaner directly down the plug holes on top of the pistons. Saturate it pretty good in each hole...let it set for like 15 minutes. Put the plugs back in and take it out on an aggressive run. It will smoke like hell but should clean some of the carbon off the pistons and rings. This along with the in carb method actually raised the compression of my 318 Poly a little bit. You should change your oil after you do this. The Mopar stuff is not re-labled Seafoam. Works a little better IMHO.
Re: Run ATF to clean a gunked motor? [Re: 68FuryIIIColo] #1106962
11/07/11 01:33 PM
11/07/11 01:33 PM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
I'm confused you say the engine was freshly rebuilt 4 years ago and has only been run a few times but not enough to really warm it up. What makes you think it is so dirty you need to do something so drastic? How did it get that bad?
The run on you describe is probly due to not being properly tuned up. Change oil and filter (before starting engine)
Tune it up / drain tank / carb / and lines.
Then see how it runs. MY HUMBLE OPINION
Maynard
Page 2 of 3 1 2 3
