Page 2 of 3 1 2 3
Re: Engine Noise Diagnosis [Re: InViolent] #110525
08/28/08 12:52 PM
08/28/08 12:52 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Lightly buff the head and the manifold with the 3M pads you use on the angle die grinder. Check for flattness, add a thin layer off copper RTV. No gasket!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Engine Noise Diagnosis [Re: Mopar-Al] #110526
08/28/08 01:09 PM
08/28/08 01:09 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Mr Gasket Ultra-Seal gaskets are used.
The head pipe to manifold gaskets are typical Fel-Pro...but like I said...I am running a SPACER to get the damn pipe off the underbody....I took the spacer and RTV'd the two gaskets to it when I installed this engine last summer.
I had those same gaskets on my 440-6 mine made the same noise or close to it. I had to tighten them up over and over. Then someone said to run my manifolds without gaskets, that they came that way from the factory.
I wasn't sure if that was true or not, but I pulled mine off and went without gaskets on the pass side. No more noise.
Yr one has a seperate part number for the 440-6 head pipes. Mine went on without any problems. They cost like 106 each.
In 70 there is a different part number for one of the manifolds. I got mine off of a 70 challenger six pack. The flange had a different twist to it rather than the b body 69 stuff.
sounds like a exh leak, id get the surface straight and then put them on without a gasket as mentioned above..
the seal quite well without a gasket on the exh manifolds
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110527
08/28/08 06:40 PM
08/28/08 06:40 PM
hey...make a gasket out of poster paper[white],install and run a few minutes,remove and read..nice ride.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* #110528
08/28/08 07:19 PM
08/28/08 07:19 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Man, that thing is RUINED, ya need to sell it to me REAL cheap...haha.. Yeah, thats a nice little exhaust leak ya got there. I have had them come loose on me and I have just retightened them until the gasket would "seat in", I guess the word would be. By the way, Shes a "beaut"..
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: StandOnIt] #110529
08/28/08 07:28 PM
08/28/08 07:28 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
No gasket is needed with stock manifolds. Prepare the manifold sealing surface with a 12 in flat mill file to remove any high spots or garbage left on it.
I would take the manifold to a muffler shop and hve them braze the shaft holes for the hear riser if you are not going to use it.
Clean the head sealing surface and bolt it up.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: StandOnIt] #110530
08/28/08 07:29 PM
08/28/08 07:29 PM
Clarksville, Tennessee
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
"Could be also a leak where the head pipe connects to the right exhaust manifold."
I fixed mine with this. At first, I would have sworn it was a lifter. I decided to try exhaust leak first, and this is what fixed it. I put a new gasket in where the pipe meets the manifold and that cured it.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: monoptn] #110531
08/28/08 09:22 PM
08/28/08 09:22 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Are you sure one of the lifters is not making contact with the valve cover? Look inside the cover and look for a mark.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: SCATPK] #110532
08/28/08 11:20 PM
08/28/08 11:20 PM
Kenmore, New York
InViolent Offline OP
Kenmore, New York
Yes, I verified that I was not getting contact between rocker arms and cover...although I was convinced by the sound I was!
Pulled the manifold off and I had oil in #8 port area...running the car with the valve cover off spewed plenty of oil in this area, and it found its way into the manifold. The headpipe+Spacer flange connection didnt look good either. I'm waiting an another RH manifold and will update with results next week once I can get the thing back together. Really appreciate the help thus far, and keep the opinions coming!
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110533
08/29/08 12:13 AM
08/29/08 12:13 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Maybe the heat riser valve in the manifold? Try holding a screw driver against the valve so it dosen't flop around (usually too hot to just grab.)
It din't sounds like the noise was from the bell housing, but on automatics I have has flexplate bolts scrape the cover when the wrong converter bolts were used (the bolt heads were not the correct thin style.)
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: 451Mopar] #110534
08/29/08 07:58 AM
08/29/08 07:58 AM
Kenmore, New York
Kenmore, New York
No riser...and no dust shield....went through the TC bolts hitting cover routine years ago! another pain to locate for sure! Thanks for the input though.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110535
08/29/08 08:20 AM
08/29/08 08:20 AM
Kenmore, New York
Kenmore, New York
You know, these Mr Gasket gaskets don't line up well at all with the ports. Their port openinga are too large. There is very little coverage at all at the Tops of the ports.
When talking "no gasket", is it generally agreed that I should use a "a little" copper RTV applied to the manifold prior to bolting up?
and I am assuming that Headpipe to manifold gasket(s) are required. I don't go "no gasket here, do I?
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110536
08/29/08 08:32 AM
08/29/08 08:32 AM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
To find a suspected exhaust leak have a friend hold a rag over that tail pipe and listen for the sound to get louder.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110537
08/29/08 10:06 AM
08/29/08 10:06 AM
correct, gaskets are needed there.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110538
08/29/08 10:11 AM
08/29/08 10:11 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I have used the tin covered gasket that comes in the Felpro gasket sets, with no sealer, with great success AFTER having the manifold surfaced , if its NOT flat BEFORE you bolt in on it's not going to seal well.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: JohnRR] #110539
08/29/08 10:24 AM
08/29/08 10:24 AM
Kenmore, New York
Kenmore, New York
John:
Are you talking about the gaskets with the aluminum looking perforated like look? I used these with the same manifold in the past and didn't have this issue. It was with different heads, however, but these heads were very straight and clean and well-prepped from what I thought when I got them. Like I said above, I am not impressed with how these sure seal gaskets line up with the ports.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110540
08/29/08 10:25 AM
08/29/08 10:25 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I have found that most of the brands of copper header flange gaskets do not line up with the ports, most of them have holes that are too big - this is a problem with a small-primary header, but should not be as big a deal with a manifold. Can't comment on fiber gaskets, haven't used any for 15 years but OEM-sized gaskets should be OK?
I have had good luck installign manifolds with no gaskets or RTV. I'd say the copper RTV is optional, if you have some on-hand give it a try, you've already had the manifold off so it's a 20-min job to R&R it. If you still have a leak give the RTV a try.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110541
08/29/08 10:31 AM
08/29/08 10:31 AM
John:Are you talking about the gaskets with the aluminum looking perforated like look?
YES. I had a problem with those with a SB as there are 2 different sizes offered(head to ex man) & I had the wrong ones. Once I got the correct ones problem solved.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: RapidRobert] #110542
08/29/08 10:37 AM
08/29/08 10:37 AM
Kenmore, New York
Kenmore, New York
I just went to Summit and here is how they list:
Fel-Pro
Port Ht 1.33
Port Width 1.84
Ultra Seal
Ht 1.48
Wt 1.78
That's a pretty substantial difference in height. These Mr Gasket port holes seem too large in the height direction when laying them down on the stock manifold. There was almost NO material covering the top of all of the ports at all. You can see the carbon lines on the manifold along the tops of each port....and it's right at (or maybe past!) the edge of the ports. Not Good.
BTW: I have used this mani for 5 or 6 years....this is really the first time I've had serious issues with it. Laying a straight edge over the ports, it sure seems pretty straight to me. I didnt get the feeler gauges out, but eyeing it up, I can't say this POS is warped to a point that it wouldn't give me a decent seal.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110543
08/29/08 10:47 AM
08/29/08 10:47 AM
I There was almost NO material covering the top of all of the ports at all. You can see the carbon lines on the manifold along the tops of each port....and it's right at (or maybe past!) the edge of the ports. Not Good.
That's what I had carbon tracks from the wrong gaskets. I dont know about warpage but when I got the ports covered that took care of it.
Re: Engine Noise Diagnosis *UPDATED WITH VIDEO!* [Re: InViolent] #110544
08/29/08 11:08 AM
08/29/08 11:08 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Fel-Pro
Port Ht 1.33
Port Width 1.84
Ultra Seal
Ht 1.48
Wt 1.78
the ultra seals are a HEADER gasket to be used more for ported heads .
Yes I was talking about that perforated steel looking gaskets .
forget the straight edge put it on a flat surface and have a light behind it so you will be able to see light under it if it's lifter off the surface , will be most noticable under the center of it .
what heads are you using ? you gasket should fit the manifold opening , what is the size of the actual port on the head ?
Page 2 of 3 1 2 3
