Re: What hood scoop for my car?
[Re: 408strokerdart]
#1103160
10/28/11 12:34 PM
10/28/11 12:34 PM
Posts: 1,505 TN
SCATPACK 1
TN
Is your carb sealed to the hood you now have? Just a thought. The SSAH cars I have looked at all have the carbs about 1 inch from the top of the scoop. You may not be losing as much as you think.
Old Geezer Racing
[Re: justinp61]
#1103163
10/28/11 01:09 PM
10/28/11 01:09 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
The S/S guys don't have a choice of hood scoop's.The reason they do not seal carbs to the scoop (I asked Joe Teuton @ The Southern Nationals this year)they needed some things like clutchless trans. and a few other things and in return they had to give up some things,and sealing the carbs. to the scoop was one of them.
I found out a few years ago,if makes a different on not just sealing your carbs. to the scoop but getting the scoop where it needs to be to get the cleanest air. Just remember to richen up your carb as well or you may not seen a gain.
PS I think the body style determines more of which scoop you need to use.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: cheapstreetdustr]
#1103169
10/28/11 02:10 PM
10/28/11 02:10 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
sombody makes an enlarged-raised 6pack scoop i googled it cant find.. chepast
a 5" Hemi scoop would look muuuuuch better. Especially on 67-69 darts.
[Re: SCATPACK 1]
#1103171
10/28/11 04:34 PM
10/28/11 04:34 PM
Posts: 3,456 Out West
408strokerdart
Out West
My scoop is sealed to the carb. I have seen the SS/AH cars and they are real close also. They are limited by what they have to run though. I bet they would all tell you it would be quicker if it wasnt so close. They have probably all found that added plenum is worth more than the close carb/scoop hurts them.
[Re: Mr.Yuck]
#1103172
10/28/11 04:35 PM
10/28/11 04:35 PM
408strokerdart
Out West
cowls look good on Darts
FYI, If there is ever a cowl scoop on my car please report it.....it is stolen.
[Re: jim sciortino]
#1103173
10/28/11 04:37 PM
10/28/11 04:37 PM
408strokerdart
Out West
Probably end with with a HEMI and a screw blower, but for now I have this so I can see where I'm going on the street with the little engine.
That looks pretty nice Jim. What style is that one?
[Re: 383man]
#1103174
10/28/11 04:40 PM
10/28/11 04:40 PM
408strokerdart
Out West
Thats a bummer as I think your car looks great with the 6pk scoop. Ron
Thanks Ron, I'm not overly excited about it either, but in the name of progress it has to be done. Six pak isn't going to get it done when it has two 1250's sitting on a sheet metal tunnel ram with 640 cid under it. Would rather do it once.
#1103175
10/28/11 04:45 PM
10/28/11 04:45 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
It's the shortest aero that Glasstek sells, I believe.
