Page 1 of 3 1 2 3
4.7 motors-are they reliable? #1102968
10/27/11 09:45 PM
10/27/11 09:45 PM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
Looking at an '06 4.7 Dakota R/T. Been asking some of my Mopar buddies what they've heard about the 4.7 as I really don't know a lot about them. So far the responses I've gotten have been rather lukewarmm. Main thing is oil issues of some sort, but no one can really point out anything specific.
I've got 187,000 on my 5.9 Dakota R/T and it has been pretty rock solid. Will the '06 have a chance at that?
Thanks!
Re: 4.7 motors-are they reliable? [Re: slantzilla] #1102969
10/27/11 10:06 PM
10/27/11 10:06 PM
70duster340 Offline
70duster340  Offline
I've had 2 Dakota's with the 4.7L. One was a 2001 and the last was a 2007. Both were trouble-free.
Re: 4.7 motors-are they reliable? [Re: 70duster340] #1102970
10/27/11 10:13 PM
10/27/11 10:13 PM
Washington
69440 Offline
69440  Offline
Washington
I bought a Ram 1500 new in 07, 4.7 equipped. It now has 81K miles on it and has never had a problem. Trouble and worry free.
Re: 4.7 motors-are they reliable? [Re: 69440] #1102971
10/27/11 10:24 PM
10/27/11 10:24 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Just don't get one of them hot. Headgasket issues and valve seats comming out of the heads are common.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 4.7 motors-are they reliable? [Re: 71yelladustr] #1102972
10/27/11 11:04 PM
10/27/11 11:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
111775 on our 99 Jeep GC no issues, still runs strong
Coming soon!!!!
Re: 4.7 motors-are they reliable? [Re: Mr.Yuck] #1102973
10/27/11 11:09 PM
10/27/11 11:09 PM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
A guy that works for me has about 250K on his original engine. Still runs strong. Has had 3 trans and a transfer case though. Used the truck as a Cable TV intaller truck. I think its an 02 (Dakota)
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: 4.7 motors-are they reliable? [Re: Mr.Yuck] #1102974
10/27/11 11:09 PM
10/27/11 11:09 PM
IN
ahy Offline
ahy  Offline
IN
I put about 70k on an early one in a Jeep. Worked well, no problems. On the lube system, the coolest point in the system is the fill hole which is pretty big like a funnel. As a result it gets condensation - looks funny when you open the cap but doesn't seem to cause any problem.
Re: 4.7 motors-are they reliable? [Re: ahy] #1102975
10/27/11 11:15 PM
10/27/11 11:15 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
we have 1 with 105000 on it and haven't had any issues but a friend that deals with a salvage yard says they can't keep any on their racks. i did some checking and was told they have/had a tendency to sludge-up due to a bad pvc set-up so i have been adding a quart of rislone to every oil change just to be safe. dave
Re: 4.7 motors-are they reliable? [Re: 3ddart] #1102976
10/27/11 11:35 PM
10/27/11 11:35 PM
ill
dennismopar73 Offline
ill
02 durango 4.7 great on gas 18 mpg ave , 0 issues
always used mobile 1
Re: 4.7 motors-are they reliable? [Re: slantzilla] #1102977
10/27/11 11:37 PM
10/27/11 11:37 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
153,000 trouble free miles on my 4.7 2002 Ram quad cab.I use 15w40 Mobil Delvac oil and PuroLator filter.
Nautilus Racing-
Re: 4.7 motors-are they reliable? [Re: Chris2581] #1102978
10/28/11 01:34 AM
10/28/11 01:34 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Very good engines if maintained like should. Like to sludge if not and ruin timing chain guides and tensioners. Remember the spark plugs NEED changed every 30k if not platinum.
Re: 4.7 motors-are they reliable? [Re: Todd] #1102979
10/28/11 03:12 AM
10/28/11 03:12 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
My exterminator has a 2000 4x4 Durango with 247k on his -- trouble free!
Re: 4.7 motors-are they reliable? [Re: slantzilla] #1102980
10/28/11 09:29 AM
10/28/11 09:29 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I had a 2000 and a 2001. Both ran perfect at 150k mi. Only thing I heard about is that the 3.7 and 4.7 can toss a rocker out from under cam and sometimes trashing cyl head in the process. That may just be the poorly maintaned vehicles. I dunno. I towed a bit with the 4.7's and they did job well.
Re: 4.7 motors-are they reliable? [Re: buildanother] #1102981
10/28/11 10:31 AM
10/28/11 10:31 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
Mine is an 02 Ram with 114K, runs great. I did have a sludge problem, probably from short trips to the commuter parking lot, and not letting it get fully warmed up. It used to let me know when it needed an oil change by ticking valve lifters. I let the dealer talk me into an engine flush, I figured it was money down the drain, but it runs good as new!!!
As mentioned, change the plugs, I let mine go 43K and one day it would not start, had to have it towed to the dealer and DUH plugs were shot. I do it every 25k now, its a 30 minute job.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: 4.7 motors-are they reliable? [Re: buildanother] #1102982
10/28/11 10:32 AM
10/28/11 10:32 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Was looking at a Jeep G. Cherokee w/a 4.0, the conversation came up about the JGC's with 4.7's, and the salesguy said the 4.7's just weren't the motor they replaced.
Occasional heads cracking and headgaskets.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 4.7 motors-are they reliable? [Re: slantzilla] #1102983
10/28/11 10:56 AM
10/28/11 10:56 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Thanks!
Absolutely.
Take car of it and it'll take care of you.
Just change spark plugs and oil/filter regularly
And a 4.7 will outrun a stock 5.9
I used to work at a new car dealership,,,
Re: 4.7 motors-are they reliable? [Re: gtx6970] #1102984
10/28/11 11:00 AM
10/28/11 11:00 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Thanks!
Absolutely.
I'd agree with that.
Re: 4.7 motors-are they reliable? [Re: slantzilla] #1102985
10/28/11 11:01 AM
10/28/11 11:01 AM
PA
noplanb Offline
noplanb  Offline
PA
120K on a 2004 Dakota. Zero issues. Mobil 1 since new, plugs and filters. Not the most exciting motor but gets it done without fuss.
remember when you said honey, some day that car is gonna look so good in front of our house
Re: 4.7 motors-are they reliable? [Re: noplanb] #1102986
10/28/11 01:39 PM
10/28/11 01:39 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
they do not like to be over heated, they will drop valve seats out of the heads. I just rebuilt a 4.7 for a 01 grand cherokee and i threw in a set of HO cams and the HO intake manifold... oh boy it rips hard.
Re: 4.7 motors-are they reliable? [Re: ditchdrift] #1102987
10/28/11 01:44 PM
10/28/11 01:44 PM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
Had an '03 Durango with this engine. Put about 90k on it before ex totaled it in a wreck.
Only problem I ever had was a broken exhaust manifold stud, so I had to replace the exhaust gasket. (That was the problem with the engine....I won't get into the problems with the ex...let's just say the 4.7 was much more reliable)
Page 1 of 3 1 2 3
