Re: Will a /6 904 bolt up to a 318? #110173
08/26/08 09:09 PM
08/26/08 09:09 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
"Lots of work/expense to swap in a 318; if you're only looking for a stock 318 power level, you can get that in a slant 6 with a 2bbl carb, mild cam, and bigger exhaust pipe."
Huh?
Even if you do all that stuff you're still missing about 80hp/100 lb/tq compared to a stock 2barrel 318. About the hardest part of doing a /6 to 318 swap is getting the lopsided lump out of the car without trashing the bulkhead connector, after the 1st time you learn to disconnect it and push it inside the car.
On a 67-72 A body a /6/904 to 318/904 swap shouldn't take more than 1 day, if it does you're doing something wrong.
Re: Will a /6 904 bolt up to a 318? [Re: MoparJoe] #110174
08/26/08 10:08 PM
08/26/08 10:08 PM
Huh?
??? Comparing factory net hp ratings, there's only 50 hp difference, stock to stock.
Guess I'm slow then . . .
Re: Will a /6 904 bolt up to a 318? [Re: MoparJoe] #110175
08/26/08 10:16 PM
08/26/08 10:16 PM
Arkansas
340727dart Offline OP
Arkansas
Thank you for that tip.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Will a /6 904 bolt up to a 318? [Re: 340727dart] #110176
08/26/08 10:26 PM
08/26/08 10:26 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Why would you trash the bulkhead connector? The engine leans the other way.
Re: Will a /6 904 bolt up to a 318? [Re: slantzilla] #110177
08/27/08 08:56 AM
08/27/08 08:56 AM
Texas
vynn3 Offline
vynn3  Offline
Texas
Just more slant hateration, I assume.
If you want a V8, fine. No need to keep ragging on slants, though. Slants have been good, solid, reliable engines for 40+ years. And my mildly-modded is anything but slow.
But hey, if you break the bulkhead when you pull your engine, it's the engine's fault, right?
Re: Will a /6 904 bolt up to a 318? [Re: MoparJoe] #110178
08/27/08 09:21 AM
08/27/08 09:21 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
" lopsided lump" ?
Oh, you didn't just say that?
Let's race!!!
Re: Will a /6 904 bolt up to a 318? [Re: vynn3] #110179
08/27/08 09:35 AM
08/27/08 09:35 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I don't even pull the hood off my Valiant when I pull the motor.
Just a question for all you 318 guys. How many Hemi owners have been afraid to race you for money after they saw you make a pass at Monster Mopar?
I know Slants aren't for everyone, but that isn't the motors fault.
Re: Will a /6 904 bolt up to a 318? [Re: ZIPPY] #110180
08/28/08 11:58 AM
08/28/08 11:58 AM
Arkansas
Arkansas
What you should do is find a rusted or wrecked car (or truck) with a good running 318 and good trans in it, take everything, and put it in your car.
I just now located a '77 Aspen wagon the guy is using for a daily driver with a 318/904 and will sell to me for $500.
And, another buddy has volunteered to haul the body to the scrap yard for me.
Re: Will a /6 904 bolt up to a 318? [Re: 340727dart] #110181
08/28/08 01:09 PM
08/28/08 01:09 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's the way it's done
Re: Will a /6 904 bolt up to a 318? [Re: ZIPPY] #110182
08/28/08 02:29 PM
08/28/08 02:29 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
Find an 85' or later M body. The 318s in them had the roller cams and swirl port heads (302 castings). They were only light on power due to the smog equipment, which I don't think would be following over with it anyways.
Re: Will a /6 904 bolt up to a 318? [Re: MarkZ] #110183
08/28/08 03:03 PM
08/28/08 03:03 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
or keep the slant and get an A833OD manual. my duster is a stock 1bbl slanty with the OD tranny (3.09 first, 1.74 2nd, 1:1 3rd, .73 OD). with 25" tall tires and a 3.21 rear it keeps up with modern traffic just fine, and knocks down 24-26 combined mpg
2017 Grand Cherokee Overland
Re: Will a /6 904 bolt up to a 318? [Re: patrick] #110184
08/30/08 04:24 PM
08/30/08 04:24 PM
Arkansas
Arkansas
I rebuilt the one barrel Holley a couple of days ago and that really helped with the idle and smoothness of the engine.
However, it is still gutless.
So, I had my wife floor the gas pedal (engine off, of course) while I looked down the carb throat.
It doesn't even go to half throttle. After inspecting it some more, I discovered it has an incorrect throttle cable on it. In fact, it looks more like an aftermarket transmission kickdown cable adapted to fit.
Anyway, I placed a parts wanted ad on Moparts last night and have already gotten several responses.
Thanks Moparts.
Re: Will a /6 904 bolt up to a 318? [Re: 340727dart] #110185
08/30/08 09:01 PM
08/30/08 09:01 PM
scratchnfotraction Offline
good catch!
glad you found it,less than 1/2 throttle on a one barrel slanty would deff make it gutless
Re: Will a /6 904 bolt up to a 318? [Re: scratchnfotraction] #110186
08/30/08 11:27 PM
08/30/08 11:27 PM
Burma Shave
plymouthfan Offline
plymouthfan  Offline
Burma Shave
I have the correct throttle cable on my slant 6 and it's still slower than molasses dripping uphill.
One red car, one yellow car.
