Prepping Chrome parts for Paint???
#1101694
10/25/11 09:47 PM
10/25/11 09:47 PM
Posts: 228 FL
HelleOnWheels
FL
How should I proceed with prepping a chrome air cleaner for paint? I have read some articles that say I should use 320 grit and sand away then use self etching primer. Other articles say I should sand blast it. I will be applying a black wrinkle finish that will require some heat to cure it. Any thoughts?
Re: Prepping Chrome parts for Paint???
[Re: HelleOnWheels]
#1101695
10/25/11 09:56 PM
10/25/11 09:56 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Blast it, you don't need to strip the plating, just etch the surface so the paint can have something to bite into,,,
[Re: 1_WILD_RT]
#1101697
10/26/11 08:56 AM
10/26/11 08:56 AM
Posts: 21,501 It's a dry heat
gtx6970
It's a dry heat
same thing I've done on a few 69 GTX rear panels and tail light bezels
tape up the areas you want remain chrome and run it thru the glass bead cabinet
