Head gasket compressed thickness. #1101143
10/24/11 09:40 PM
10/24/11 09:40 PM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
Would it matter if one gasket is .038 and one is .039 compressed thickness, the one on the passenger side is .039 and I was gonna buy a gasket that is .038 compressed thickness but didn't know if the different thicknesses would matter I had to pull off the driver side head due to it leaking.
Re: Head gasket compressed thickness. [Re: KY Charger] #1101144
10/25/11 08:55 AM
10/25/11 08:55 AM
If you sucessfully address why it was leaking & change the gasket the slight diff will not cause any probs. But for reference what gasket part #'s are you going with
Re: Head gasket compressed thickness. [Re: RapidRobert] #1101145
10/25/11 09:23 AM
10/25/11 09:23 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Fel-Pro 1008s are cheap, and .039" thick, why not just replace with the same size gasket?
**Photobucket sucks**
Re: Head gasket compressed thickness. [Re: 70Cuda383] #1101146
10/25/11 09:23 AM
10/25/11 09:23 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
or 1009s if it's a big block
Re: Head gasket compressed thickness. [Re: 70Cuda383] #1101147
10/25/11 12:22 PM
10/25/11 12:22 PM
dogdays Offline
dogdays  Offline
But it really doesn't matter. You're talking about something like 0.25cc.
R.
