Re: 8 3/4 axle seal leak
[Re: 68bb]
#1099231
10/22/11 05:32 PM
10/22/11 05:32 PM
Posts: 26,530 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A blocked vent or way overfull fluid will overwhelm even new seals...I'd look to the vent first.
[Re: sthemi]
#1099234
10/22/11 07:19 PM
10/22/11 07:19 PM
RapidRobert
For a leak of that magnitude I'd suspect the spring popped off or the seal got bent or not in square but you did everything spot on. Probably have to R&R them & I'd pack the rear of the seal full with vaseline or grease to keep the spring in place and I use a driver with an OD as large as will fit so it bears on the outermost OD of the seal and drive it in with as few strokes with a BFH as I can so a good whack each time EDIT get the seal barely started but firmly in there square then as recommended whack it good till it's seated and if it starts to get cocked sideways use a round flat piece of stock with a drift and move the drift to the high side to knock that side in further to even it up then switch back to the BFH/centered driver
[Re: 383man]
#1099238
10/23/11 12:13 AM
10/23/11 12:13 AM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
When I drive those seals in, I use a socket made for 4 wheel drive lock nut on 1/2 ton Dodge trucks. Perfect fit inside the axle housing and the O/D of the seal. Make sure the seal is driven in until it hits the raised stop in the housing.
Eric
