Launch dilema #1097601
10/19/11 05:08 PM
10/19/11 05:08 PM
Stratford,Ct
7sec.cuda Offline OP
Stratford,Ct
can anybody identify my problem haha cant get car to hook
http://PhotosbyJim.smugmug.com/gallery/19586001_RQ3J2Q#1534716256_BBhXBQ7-A-LB
Re: Launch dilema [Re: 7sec.cuda] #1097602
10/19/11 05:13 PM
10/19/11 05:13 PM
Stratford,Ct
Stratford,Ct
Re: Launch dilema [Re: 7sec.cuda] #1097603
10/19/11 05:22 PM
10/19/11 05:22 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
cold damp track? tire pressure? try this saturday
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Launch dilema [Re: 440lebaron] #1097604
10/19/11 05:29 PM
10/19/11 05:29 PM
Stratford,Ct
Stratford,Ct
track was good tire pressure was 7.5 3 runs 3 spins
Re: Launch dilema [Re: 7sec.cuda] #1097605
10/19/11 05:32 PM
10/19/11 05:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you tried raising your wheelie bars some so it
will transfer more
EDIT
I assume this is a 4 link... whats the length and height
Re: Launch dilema [Re: MR_P_BODY] #1097606
10/19/11 05:45 PM
10/19/11 05:45 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
whats rpm are you trying to leave at?
Re: Launch dilema [Re: 2QUICK4U] #1097607
10/19/11 05:48 PM
10/19/11 05:48 PM
Stratford,Ct
Stratford,Ct
we have tried anywhere between 6000 to 7300 does the same thing
Re: Launch dilema [Re: 7sec.cuda] #1097608
10/19/11 05:54 PM
10/19/11 05:54 PM
Stratford,Ct
Stratford,Ct
we have gone through the chassis from bumper to bumper twice. what is strange is that when it is 70 degrees or more this car has consistant 1.12 /1.13 60 ft times and the car will hook on ice. under 65 degrees this is what the car does no matter what i try
Re: Launch dilema [Re: 7sec.cuda] #1097609
10/19/11 06:01 PM
10/19/11 06:01 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Raising wheelie bar won't help, its not even trying to transfer, let alone hitting the bar.
Have you checked your tire gauge against another. Slicks look like radials to me…
Did you try loosening front shock extension?
SS/DA 1924
Re: Launch dilema [Re: SSDAcuda] #1097610
10/19/11 06:03 PM
10/19/11 06:03 PM
Stratford,Ct
Stratford,Ct
shocks are as loose as they can go 2 different sets rears also new never compared guages
Re: Launch dilema [Re: SSDAcuda] #1097611
10/19/11 06:05 PM
10/19/11 06:05 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Maybe try softening rear compression also. What # spring on the rear? Where is the IC of the four link?
SS/DA 1924
Re: Launch dilema [Re: SSDAcuda] #1097612
10/19/11 07:03 PM
10/19/11 07:03 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
watching the vids, and seeing the bouncing, looks like the springs are too stiff, tires looked hard or over inflated...
maybe a change in the 4 link setup...
Re: Launch dilema [Re: 7sec.cuda] #1097613
10/19/11 07:46 PM
10/19/11 07:46 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
Have you changed anything in the suspension since it was last out? If not, here is my .02
I had the same PS Hemi in the car I just sold, and I know how finnicky they can be. I would start by taking timing out of it, at the hit, so that you can get the car to leave (although it may be a pooch to start off), and than start ramping the timing back in, as you get the chassis figured out. I would share my old launch RPM settings, etc., but, with your big tire, I am sure that your settings are far more agressive.
Do you have a Racepak? If so, what has the driveshaft rpm been in the past, at the 1 second mark? I would back it down with timing, than sneak back up to where the graph is showing it's happiest point.
Re: Launch dilema [Re: 7sec.cuda] #1097614
10/19/11 07:48 PM
10/19/11 07:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt see a vid the first time I looks... but looking
now and seeing it, it looks like the springs are real
stiff and it looks like the tire pressure is high...
do you know what the IC is... whats the weight
(front and rear)
Re: Launch dilema [Re: 7sec.cuda] #1097615
10/19/11 07:49 PM
10/19/11 07:49 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If I had a car that was leaving with some 1.teens,,and then started acting like that,,,I'm not sure what I would do..!! You are spinning the tires on the line easier than I can in the water box..!! Hard to tell from videos, but appears the tires might have WAY to much air for some reason, if that is possible...I suppose the tires are still 'decent' for this time of the season..? That is surely amazing that this would happen over 5* temperature. I can't give you any info on 4 link suspension,,I can't even get my ladder bar sled to work like I want it to.. But, that is one of the most frustrating launches I have ever seen.
If you like drag racing, support your local track.
Re: Launch dilema [Re: CHAPPER] #1097616
10/19/11 07:59 PM
10/19/11 07:59 PM
Stratford,Ct
Stratford,Ct
we thought we had tire issues so we just bought new ones beginning of year these only have bout 15 runs like i said its amazing when its hot the car 60fts awesome but get colder the car is a different animal
Re: Launch dilema [Re: 7sec.cuda] #1097617
10/19/11 08:03 PM
10/19/11 08:03 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
what are the tires and compound rating..
are they Goodyear's D compound?
Re: Launch dilema [Re: 7sec.cuda] #1097618
10/19/11 08:06 PM
10/19/11 08:06 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Could it have been the track prep at LVD? I know Shakedown was off the hook, I've only been to LVD a few times and the prep was never stellar. I agree with the rest, something in the back seems way too stiff, could the shocks be frozen up?
Re: Launch dilema [Re: smokinwoody] #1097619
10/19/11 08:07 PM
10/19/11 08:07 PM
Stratford,Ct
Stratford,Ct
M/T 34.5 17 16 m5 compound
Re: Launch dilema [Re: Bigcube] #1097620
10/19/11 08:10 PM
10/19/11 08:10 PM
Stratford,Ct
Stratford,Ct
Jim brand new shocks,springs front and rear chasis gone over front to back twice this year car works excellent when hot does not work in cold weather .track prep wasnt the best but i had same issues at shakedown
