Re: Oil Pickup Clearance, touch the pan, or no?
[Re: MoparforLife]
#1097500
10/19/11 02:34 PM
10/19/11 02:34 PM
RapidRobert
Ok for a grocery getter. a perf build 1/8"
[Re: Scatransit]
#1097502
10/19/11 03:06 PM
10/19/11 03:06 PM
Posts: 30,447 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
The service manual says that the bottom of the pickup should contact the bottom of the oil pan.
Which SM says that ?
[Re: dOoC]
#1097504
10/19/11 03:53 PM
10/19/11 03:53 PM
Posts: 426 Mid-Atlantic
Scatransit
Mid-Atlantic
Page 9-65 of the '69 service Manual. Just wondering...I have mine set at about 1/4 - 3/8".
[oo]======[oo]
[Re: Scatransit]
#1097505
10/19/11 05:09 PM
10/19/11 05:09 PM
Posts: 25,857 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you're talking about the factory style pickup there's no advantage to having a clearance under it, even with the pickup contacting the pan the channel that feeds the opening is larger than the opening so there is no restriction.
Aftermarket pickups like the Milodon must have clearance.
[Re: John_Kunkel]
#1097506
10/19/11 06:19 PM
10/19/11 06:19 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
Years ago one of my friends believed that the pickup shouldn't touch the pan and hot bent it to get about 1/4" of clearance. About three years after this at the top of third gear, the pickup failed at the threaded end and he lost all oil pressure. Oh yeah, it was a '66 Hemi Coronet. IIRC there was just someone on Moparts that had the same thing happen, a crack at the pickup threads with the accompanying loss of oil pressure.
Without the pickup touching the pan it apparently can get into a resonance. This leads to metal fatigue at the threaded end with the eventual cracking failure. No, I'll continue putting BB's together with the pickup touching the pan.
[Re: Supercuda]
#1097509
10/19/11 08:04 PM
10/19/11 08:04 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Absolutely not!! It should never touch the pan, UNLESS the pickup is the OEM syle mentioned above. Two reasons why not: Dent the oil pan at the pickup, restricted flow of oil in pump and motor. Two, break something inside the motor, the oil flow is again, restricted at the pickup.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: John_Kunkel]
#1097510
10/19/11 08:10 PM
10/19/11 08:10 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Correct. Factory style can touch. Plenty of area for the oil to access the tube.
If it is aftermarket, not only should you have clearance, but add a positive spacer between the PU and pan to make sure that the pan does not get sucked up to the PU.
[Re: BSB67]
#1097511
10/19/11 08:24 PM
10/19/11 08:24 PM
RapidRobert
and a spacer would take of the resonance problem possibly causing a crack on down the line
