Re: Blower Setups for Street? Who has Used What?
[Re: Dragula]
#1097277
11/11/11 09:35 PM
11/11/11 09:35 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
PSI 206B....
So how do you like that set-up? Is it streetable with the carbs?
Some more details about that combo would be great..
It's a 526 4.310 x 4.500 w/KB block and Stage V big valve heads, TD/Barton rockers. The mistake I made was not having PSI cut the bottom of the blower bigger to hold less boost in the case. If I keep the car, I'm going to send the blower back for a bigger cut so I can drive the blower slower and use pumpgas for street driving.
It made 1629hp @8000rpm, just touching 20lbs and even in this configuration, it's pretty easy to putt around. It's just expensive to burn C-16. With the small cut, the discharge temp in the manifold climbs when going slow, or stopped at a light. It drops as you drive and the harder you hit it, the cooler it gets. Just opposite of a roots.
After talking with PSI, we'll probably redo a couple things and knock it down to the 1200hp range for street driving on 93, then swap pulleys, retune the carbs and drive it to 30lbs with C-16 and see how much we can make.
Unless I sell the car and turn my Dart (superstock style chassis) into a grudge deal.
[Re: jim sciortino]
#1097278
11/12/11 10:02 AM
11/12/11 10:02 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Like you need that much HP for the street ![](/ubbthreads/images/graemlins/eyes.gif) I underdrive run 4 lbs of boost on pump gas for the street with over 750 HP available.UD it enough to use just pump gas ![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: hemi-itis]
#1097279
11/12/11 07:55 PM
11/12/11 07:55 PM
jim sciortino
Trumbull,CT.
Like you need that much HP for the street I underdrive run 4 lbs of boost on pump gas for the street with over 750 HP available.UD it enough to use just pump gas
You couldn't be more right. To much steam isn't really fun on the street cuz you can't jack around with it and burning C-16 to get a burger is ridiculous.
If I don't sell the car, I'm going to back the engine down plenty by opening up the blower cut and a pulley change. The chassis is killer so it can take good power, but the most fun I ever had in a street car was in the mid 90s with a 69' Barracuda w/SS springs.....it had a 499ci 440-1 that ran in the 9.20-9.40 range. About 800hp and was a blast on an empty Rt. 25 connector and ATCO rent days. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: MR_P_BODY]
#1097280
11/21/11 02:43 AM
11/21/11 02:43 AM
Posts: 1,882 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
I have a Dyers on a 440 intake.. I plan on sending it in for a freshening and a polish job then its going up for sale... its a good unit but I'm changing over to other stuff
Mike ,You have a PM ! RT
