Just did the power steering shim trick
#1095597
10/16/11 05:29 PM
10/16/11 05:29 PM
Posts: 21,835 Kirkland, Washington
Pacnorthcuda
Ok, I finally did the Mopar Action (Ehrenberger?) trick with my power steering pump:
440 'Cuda, Fast ratio pitman, Small Steering wheel (Tuff). One would think the steering wouldn't be TOO light---wrong--way too light for my tastes.
So I yard the pump and remove the piston, take it apart. The washer under the hex measures .030. I make one that measures .053 and add it. Test drive car--had I not known I changed it I would never have felt a difference. MAYBE it was a little firmer, MAYBE a little.
I decide to do it again, I make another washer that measures .056 and add it. The total is now .139. Test drive car--its better!!! Just a little firmer, but a better overall feel.
Glad I did it, thank you E-booger and Mopar Action!
Making the washers is easy, just find one with the right ID and sandwich it between two nuts on a 3/8" bolt--then grind it down on your bench grinder till the OD measures .500".
Re: Just did the power steering shim trick
[Re: Pacnorthcuda]
#1095602
10/16/11 07:29 PM
10/16/11 07:29 PM
RapidRobert
You kept the OE washer & added the addt'l (2) right? What was the ID of em? Thanks for the info.
[Re: RapidRobert]
#1095603
10/16/11 07:35 PM
10/16/11 07:35 PM
Pacnorthcuda
Right--3 washers totaling .139. I never miked the ID--I just rummaged around till I found some that fit, but its a little over 3/8"
[Re: Strawdawg]
#1095605
10/16/11 10:30 PM
10/16/11 10:30 PM
RapidRobert
Thanks Dawg I'll make a note of those #'s
[Re: Pacnorthcuda]
#1095608
11/03/11 11:13 AM
11/03/11 11:13 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
<snip>... Glad I did it, thank you E-booger and Mopar Action!
You're welcome! I have now done this on about 10 cars and it has never failed to amaze.
Several guys have mentioned that copper sealing washers (brake hose, etc.), from the parts store or in those Chinese assortments, are available in an ideal size.
Firm Feel's lower pitman support kit, and needle bearing idler kit (both developed by ) are also equally amazing upgrades.
Rick E.
[Re: Devil]
#1095610
11/03/11 09:36 PM
11/03/11 09:36 PM
Rick_Ehrenberg
Marlboro, NY, USA
I wonder, with this improvement, the ones Ehrenberg mentioned above and a setup like Hotchkis sells for our Mopars. I wonder how it would make our cars handle. I would love to try it out on a stock car, then do it with the upgraded one...
Ryan
Hotchkis gives up a lot of brake anti-dive (which it exchanges for improved camber gain). Under some conditions, this can result in bottomed suspension (esp. if car is lowered), which equals infinite spring rate, which equals massive understeer, which equals...bang!
Rick
[Re: Rick_Ehrenberg]
#1095614
11/04/11 12:00 PM
11/04/11 12:00 PM
Posts: 10,501 Chicago, Illinois
Devil
Chicago, Illinois
Ryan
Rick
That's interesting. I will need to read up more on this. What do you feel would provide a good performance setup?
I've read all the mods done to the Green Brick, the Road Runner over the years. What do you feel would be a good all around setup for our cars?
Thank you,
Ryan
[Re: Devil]
#1095615
11/04/11 09:50 PM
11/04/11 09:50 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Another thing you can do is tear apart a couple stock pumps and ge the shims from them. Thats what I did for my old '87. Didnt bump it up much but I felt somewhat of a difference.
Since there isnt any known firm feel boxes for these trucks I'll take all I can.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
#1095616
11/09/11 09:16 PM
11/09/11 09:16 PM
Posts: 203 Sante Fe Springs, CA
Hotchkis
Ryan
Rick
Before we introduced Hotchkis Sport Suspension for Mopars, we conducted a tremendous amount of development on the street and track before bringing our suspension products to market. We understand the extreme forces the suspension undergoes when subjected to performance driving. We also strive to make our suspension products easy to install so the enthusiast can do the work at home.
The Hotchkis TVS can be installed as a complete kit or in stages, one component at a time – depending upon the builder’s budget.
- The Hotchkis TVS uses factory style suspension design and improves the geometry as well as using stronger materials. “Other” systems use Mustang II style A-Arms and steering racks. We believe in using Mopar style suspension on your Mopar, we just make it better!
- The Hotchkis system is a true bolt-on, the other guys require either fabrication or complete K-Member swap.
- Hotchkis Sport Suspension is optimized for strength vs weight using Cosmos FEA software and in real world testing.
- Our system is performance proven in drag, autocross and road course racing. Our Mopar systems have competed and won in SCCA and Goodguys Autocross events, the Virginia City Hill Climb, and we recently competed in the Optima Ultimate Street Car Invitational.
- Our E-Max test car has won more autocross events than any other classic Mopar currently competing, bar none. And it uses nothing but bolt-on components (except our subframe connectors, which are technically weld-in).
- Thousands of combined roadcourse and autocross miles without a failure.
- Competition proven with top finishes in 341 Challenge, Motor State Challenge, Goodguys autocross and OUSCI.
- Our E-Max Challenger with our bolt-on performance suspension has won in Goodguys autocross competition and is competitive with the finest Muscle Cars ever produced.
- Our Mopar customers have won the participant class at Goodguys autocross.
- No other Mopar suspension company can claim a win in a Goodguys autocross.
- We stand behind our suspension with a 3 year/ 36,000 mile warranty.
- We have a terrific group of enthusiast customers that thoroughly enjoy driving their Mopars because of the benefits of Hotchkis Sport suspension.
