Eddy valve stem seals #1093534
10/13/11 12:40 AM
10/13/11 12:40 AM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Can the valve stem seals that come with the Edelbrock RPM heads be used with a dual spring (comp-928)? Or should the seals be switched to a different part? I'm not having much luck finding an answer on any vendor's site.
Thx
Re: Eddy valve stem seals [Re: davenc] #1093535
10/13/11 12:43 AM
10/13/11 12:43 AM
Delray beach, Florida
P
Performance Only Offline
P
we change the seals out. i'm sure we have the ones you need since we do a lot of those heads. i'm not fond of the seals edelbrock uses.
machine shop owner and engine builder
Re: Eddy valve stem seals [Re: davenc] #1093536
10/13/11 12:44 AM
10/13/11 12:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the ID of your springs and the OD of the guide
Re: Eddy valve stem seals [Re: MR_P_BODY] #1093537
10/13/11 12:46 AM
10/13/11 12:46 AM
P
P
all eddy heads use a .530 od seal. the id of the inner spring on a 928 is .795 if memory serves me correct
Re: Eddy valve stem seals [Re: MR_P_BODY] #1093538
10/13/11 12:50 AM
10/13/11 12:50 AM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
According to COMP, the ID of the spring is 0.795". I don't have the head apart at the moment so I can't measure the OD of the guide. They are the stock e-brock guides though.
The heads had the 928 springs put on them years ago. According to my records, the seals where not switched. Not many miles on the motor but I am getting oil into the cylinders, and it looks like it may be coming down the guide.
I had some MP seals in my garage, and mentioned to my brother that I could swap them in if the seals were gone. He pointed out that I need to be careful about the seal selection with the dual spring, and that set off a light bulb wondering about the original seals from e-brock.
Re: Eddy valve stem seals [Re: Performance Only] #1093539
10/13/11 12:56 AM
10/13/11 12:56 AM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
If the seal is 0.530, wouldn't there be enough room with the 0.795 spring to not worry about contact, clearance, or displacement of the seal?
Re: Eddy valve stem seals [Re: davenc] #1093540
10/13/11 01:01 AM
10/13/11 01:01 AM
P
P
you might find some of the original seals have come off the guides. they are not a high quality seal and they're pretty big on the o.d.
Re: Eddy valve stem seals [Re: davenc] #1093541
10/13/11 01:01 AM
10/13/11 01:01 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
the eddie seals are big black things. the ones Dan was talking about will be much thinner and better for your application
damn, treed by an old man
Re: Eddy valve stem seals [Re: Performance Only] #1093542
10/13/11 01:10 AM
10/13/11 01:10 AM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Had that issues with several of my eddy seals... but I also had sticky valve guides as well until they were all cleaned up/machined... switched to comp cams .530 seals. Perfect fit and no clearance issues with my dual springs for my roller.
Re: Eddy valve stem seals [Re: Performance Only] #1093543
10/13/11 01:13 AM
10/13/11 01:13 AM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
OK, thx for the response. Seems I will need to pull the springs off to take a look.
Re: Eddy valve stem seals [Re: davenc] #1093544
10/13/11 05:32 AM
10/13/11 05:32 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Does this apply to both big and small block?
Re: Eddy valve stem seals [Re: moparpollack] #1093545
10/13/11 09:23 AM
10/13/11 09:23 AM
P
P
yes
Re: Eddy valve stem seals [Re: Performance Only] #1093546
10/13/11 10:12 AM
10/13/11 10:12 AM
tboomer Online work
tboomer  Online Work
I would bet that if you get a hold of Roadhazzard(Greg) he would have something that would work!!
Re: Eddy valve stem seals [Re: tboomer] #1093547
10/13/11 11:27 AM
10/13/11 11:27 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Here's some of what I offer
The #632FP is probably the best for your application
Re: Eddy valve stem seals [Re: roadhazard] #1093548
10/13/11 11:29 AM
10/13/11 11:29 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
These are for triple springs
I have even more but this should cover the bulk of what guys are using
Re: Eddy valve stem seals [Re: Performance Only] #1093549
10/13/11 12:08 PM
10/13/11 12:08 PM
organ
maximum entropy Offline
organ
i always replace them with positive teflon seals. yeah. teflon. flame on.
Re: Eddy valve stem seals [Re: maximum entropy] #1093550
10/13/11 01:48 PM
10/13/11 01:48 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
For the old school guys
Polymer advancements have come a long way. There are no O.E.M. users of teflon seals.
But to each his own
Re: Eddy valve stem seals [Re: roadhazard] #1093551
10/13/11 02:44 PM
10/13/11 02:44 PM
organ
organ
But to each his own
what's the latest/greatest?
Re: Eddy valve stem seals [Re: maximum entropy] #1093552
10/13/11 07:14 PM
10/13/11 07:14 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
viton
Re: Eddy valve stem seals [Re: rickraw] #1093553
10/13/11 11:54 PM
10/13/11 11:54 PM
viton
I think Blue, redand other colors onthe new seals, they seem to seal better and hold up better on a high RPM motor
