Re: BB Reluctor rotation
[Re: RobbMc]
#1092871
10/11/11 11:07 PM
10/11/11 11:07 PM
RapidRobert
What RobbMc said and vac advance if used will shift rotor phasing CW (BB) from the at rest no vacuum location and with eng off I would check the pickup gap as you pull the vac can thru it's travel with a Mityvac vacuum pump while moving the housing to keep the magnet dead on with the tooth and echlin offers a rotor with the tip .060" longer EDIT Echlin MO-3000
