Re: T-56 or a 5 speed?
[Re: finadk]
#1092487
10/13/11 09:13 AM
10/13/11 09:13 AM
Posts: 18 New York
Fuller
New York
The driveshaft will have to be custom made. Mine came as part of the kit that included the bell, clutch, flywheel, hyd bearing, bolts, etc.
I believe the yoke is a std GM size.
Where did you buy your kit through? Just looking at a few options. I have had a qoute from keilser a long time ago but i put in another qoute for a 6 speed and haven't heard back from them yet.
[Re: Fuller]
#1092488
10/13/11 11:16 AM
10/13/11 11:16 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
That's typical for Keisler. apparently they are doing so well and have so much business, they don't need to bother with replying to requests for quotes, or calling folks back who are trying to place an order over the phone.
I've seen kits on Ebay for T-56 or TKOs for all kinds of GM vehicles. all you'd need to do is source a mopar bell and flywheel
**Photobucket sucks**
[Re: Fuller]
#1092489
10/13/11 05:12 PM
10/13/11 05:12 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I am hesitant to recommend the place that I bought it from because I had a LOT of problems, careless errors that should not happen for a purchase of this size. HOWEVER that being said, this vendor went above beyond to make sure that everything was sorted out and that I was satisfied. I wont say anything bad about them, but I am not at a point where I would recommend them either. I would be happy to talk off line if you email me at scott1956 (at) Gmail (dot)com
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: 70Cuda383]
#1092490
10/13/11 06:30 PM
10/13/11 06:30 PM
DaytonaTurbo
Manitoba, Canada
I don't understand why they don't just have pricing on their website. They must get a lot of tire kickers emailing when listing a price would make things so much simpler.
[Re: DaytonaTurbo]
#1092492
10/13/11 11:16 PM
10/13/11 11:16 PM
finadk
East Brunswick, NJ
If you are going from an automatic It will be between $4700 - $5550 depending on how good you shop.
Scott
1976 Corvette
[Re: DaytonaTurbo]
#1092495
10/14/11 03:06 AM
10/14/11 03:06 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Yes in this case converting from a manual or auto would be close in cost. Everything gets replaced anyway.
What are you planning on doing for a bellhousing? I've got a lakewood bell and I think it would be a fairly straightforward job to have it redrilled for the t-56 pattern.
How is Quicktime? They have them available through Summit: http://www.summitracing.com/search/Brand...mp;autoview=SKU
[Re: DaytonaTurbo]
#1092497
10/14/11 09:59 AM
10/14/11 09:59 AM
finadk
East Brunswick, NJ
I used a Quicktime bell. There may be others but the T56 Magnum has a boss on the front that required a relief to the machined into the bell for clearance. I have a spare quicktime small block bell NIB that I might be ready to sell.
Scott
1976 Corvette
[Re: finadk]
#1092498
10/14/11 10:11 AM
10/14/11 10:11 AM
70Cuda383
Marysville, O-H-I-O
buddy of mine has a Dakota with a T-56 and is using a quicktime bell. it made for a very clean install on his truck.
but the truck has enough room to put 2 transmissions in the tunnel, so the T-56 fit with zero sheet metal modifications.
I picked up a quicktime bell for a TKO to small block build, but won't be using it for a looong time if ever and am currently trying to sell it as well. I have it listed on a few forums...to include this one. transmission section.
they are strong, sturdy, clean pieces. SFI approved too.
[Re: Fuller]
#1092501
11/03/11 08:58 PM
11/03/11 08:58 PM
Posts: 1,349 warfordsburg, PA
dirt
warfordsburg, PA
you dont want the tr6060 from the challenger or camaro because they are set up for an independant rear suspension. there is no slip yoke only a flange, also no speedo gear, it went in the rear axle, and the shifter is mounted along with the shift rods , on top of the trans, its a major pain to make work. you end up needing a custom driveshaft that has a slip built into it , and an adapter to fit the flange on the back of the trans. then you still need to set up a sensor for the speedo. and the shifter also bolts to the floor. the T56 magnum is the same trans but with a tail shaft and shifter like a regular T56
[Re: ahy]
#1092504
11/04/11 12:55 AM
11/04/11 12:55 AM
DaytonaTurbo
Manitoba, Canada
Some comments on 4 speed vs 5 speed vs 6 speed:
4 speed: Best as a single purpose transmission. It can be set up for drag (high numerical gear), street (medium numerical gear) or road race (low numerical gear)
5 Speed: Decent multi-purpose transmission. Drag with 1'st 4 gears or road with 5'th. The compromise is in 5'th with a stout engine. Is 5'th set up as an ideal 75 MPH cruise gear? If so it is probably too tall for max top speed. Or is it set up for top speed and too short for ideal cruise?
6 Speed: 1-4 can handle drag, 5'th for top speed and 6'th for ideal cruise. The ideal manual transmission? The main drawback is size and tunnel/mount mods.
The 5-sp's 5th gear isn't as numerically low as the 6sp's 6th gear. The 6sp T56's usually have a 6th gear in the .50-.57 range where the best you can get with a tremec 5sp is a .64. Doesn't sound like much, but at these ratios, a few points makes a big difference if you really want to gear it to the max.
[Re: DaytonaTurbo]
#1092505
11/04/11 02:31 AM
11/04/11 02:31 AM
finadk
East Brunswick, NJ
One thing that I learned is that just like a cam or converter you need to choose the gear ratios as part of the entire driveline package considering rear gears, tire diameter ect. The trouble with the .50 6th gear is that you could end up in a RPM range that is too low for highway cruising. The .50 may be ok if you have 4.11 gears but depending on your cam may not be useable with 3.23's. The Tremec t56 magnum has a 2.66 1st with a .80 6th or 2.97 first gear with .63 6th. YOu need to figure out what is the lowest RPM your car can pull, and keep in ming that if the engine is lugging you may get worse fuel mileage than spinning it at higher RPM. Here is a link to some info on the Camaro 6 speeds that has more info. http://www.camaros.net/forums/showthread.php?t=98387Here is some info I gathered on the gear ratios for the various 4, 5 ,and 6 speed options Trans 1st 2nd 3rd 4th 5th 6th T56 Magnum TUET11009 2.66 1.70 1.30 1.00 0.80 0.64 T56 MagnumTUET11012 2.97 2.10 1.46 1.00 0.74 0.50 Keisler T45R (350/450HP) 3.37 1.99 1.33 1.00 0.67 TKO500 3.27 1.98 1.34 1.00 0.68 TKO600 2.87 1.89 1.28 1.00 0.64 TKO600 2.87 1.89 1.28 1.00 0.82 A833OD (75-87) 3.09 1.67 1.10 0.73 A833 (A body 64-65) 3.09 1.92 1.40 1.00 A833 71-72 18 spline) 2.44 1.77 1.34 1.00 A833 (TA 71-74)) 2.47 1.77 1.34 1.00 A833 (B/RB 64-70) 2.66 1.91 1.39 1.00 Passion Performance 2.64 1.92 1.40 1.00 0.70
Scott
1976 Corvette
