Re: 2005 Caravan steering rack replacement
[Re: Dave Watt]
#1091441
10/09/11 11:01 PM
10/09/11 11:01 PM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
I use a lot of crows foot line wrenches that go on a 3/8 ratchet.They will usually let you get to the lines pretty easy with wobble extensions and or impact swivels.Then I use mostly stubby wrenches to finish removing them.After doing a bunch it gets a bit easier.Some GMs you basically had no room to get to the fittings and they worked for me.Rocky
Chrysler Firepower
[Re: Dave Watt]
#1091444
10/10/11 10:43 PM
10/10/11 10:43 PM
Posts: 11,994 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have cut the metal line in a convenient place and used a compression union to reconnect it. Has always worked without a hitch for me.
Master, again and still
[Re: DaveRS23]
#1091445
10/10/11 10:52 PM
10/10/11 10:52 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
I thought about that too, but still wouldn't be able to drop the rack through the hole in the aluminum cradle. It is just big enough for the top of the rack to feed through.
[Re: therocks]
#1091446
10/10/11 10:54 PM
10/10/11 10:54 PM
Dave Watt
Atlanta Indiana
I've been looking at the crows foot line wrenches and even found some that have a built in swivel. Might be the way to go if spending money on them anyway? Anyone have experience with them?
