ok before you guys start the op down the path of ported vacuum
![](/ubbthreads/images/graemlins/tsk.gif)
i am going to suggest to the op that he do a archive search in the tech section of moparts and read the article on ported or manifold vacuum source. it will serve him good to understand the two, also a conversation with don at FBO will be helpfull.
![](/ubbthreads/images/graemlins/popcrn.gif)
as far as adjusting the vacuum can how does he know where to set it if he does not know what kind of manifold vacuum he is pulling i.e.. if he has 16 inches of vacuum it does no good to set the can to come in at a value greater than 16 inches. how does he know where to set it? by the way 3/32 is the allen wrench size and he will need a vacuum source with a gage so that he can see when the plate starts to move at a certain vacuum. use the google search at the top of the moparts page. go to page 3 on the google page and look for " why use ported or manifold vacuum for vacuum advance" hope this helps.
