carb issue? stumbles at stoplights. #1090040
10/07/11 06:37 PM
10/07/11 06:37 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
73 Duster, mild '70 340. I've run a ThermoQuad on it that DemonSizzler originally set up for my failed 408 stroker. I've had no problems with idle or anything until recently. Car runs and drive great except when i pull up to a light...foot off the gas it idles but seems to cut out or drop out every 5 seconds or so....kinda makes the whole car hesitate for a second and makes you think "if it keeps doing this, it'll die"
It hasn't yet but somethings making me think the carb is loading up or something.
I thought about leaning it in some with the screws and at one point decided to run them in completely...I noticed this did NOT kill the motor..that made me think it's the carb as well.
Timing checked out good at 8 degrees advance and it's solid too. the motor has under 1,000 miles since the rebuild.
Any ideas on this?
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: carb issue? stumbles at stoplights. [Re: MonGoo$e] #1090041
10/07/11 06:41 PM
10/07/11 06:41 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
T-Q's are good for a bad needle/seat inlet occasionally.
Re: carb issue? stumbles at stoplights. [Re: MonGoo$e] #1090042
10/07/11 07:20 PM
10/07/11 07:20 PM
Any ideas on this?
take out the idle mixture screws and shoot a 2 second blast of starting fluid into each hole with the thin red straw then reinstall them where they originally were. But as said with them screwed in all the way it must be getting fed from somewhere; float prob/needle seat. Look down the throat with it idling then pull the air horn off & see what's up
Re: carb issue? stumbles at stoplights. [Re: MonGoo$e] #1090043
10/07/11 09:01 PM
10/07/11 09:01 PM
crlush Offline
crlush  Offline
If you can run the idle mixture screws in completly at idle speed, then you have a vacuum leak somewhere, try changing the gasket.
Re: carb issue? stumbles at stoplights. [Re: crlush] #1090044
10/07/11 09:31 PM
10/07/11 09:31 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Another common problem, especially if the carb ran good and the trouble suddenly occurred on it's own with no other changes is fuel contamination. Was your entire fuel system new/fresh from the tank forward when you installed the carb? If not some junk likely made it's way into your fresh carb, sometimes it doesn't take much to cause the issues you described.
Re: carb issue? stumbles at stoplights. [Re: ScottSmith_Harms] #1090045
10/07/11 10:47 PM
10/07/11 10:47 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Sounds like trash in the carb, possibly in the IFRs or a bad vacuum leak, but i'm sure its minor either way.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: carb issue? stumbles at stoplights. [Re: ScottSmith_Harms] #1090046
10/08/11 06:17 AM
10/08/11 06:17 AM
Central TX
roe Offline
roe  Offline
Central TX
Trash in the carb. I was having same symptoms at one point and the carb was full of crap. Fresh clean carb and all was well
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: carb issue? stumbles at stoplights. [Re: roe] #1090047
10/08/11 05:52 PM
10/08/11 05:52 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
i have a new tank, unit, and the lines were cleaned out over a year ago. I'll take it off and give it a good cleaning along with the other suggestions..thanks!
Re: carb issue? stumbles at stoplights. [Re: MonGoo$e] #1090048
10/08/11 06:09 PM
10/08/11 06:09 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Check the total timing. Run the engine to 3500 rpm and read timing. It should be about 32 with vacuum adv unhooked.If you do not have a dial back timinglight then Set timing at 18 degrees at idle, go drive it and see if it is better.
Re: carb issue? stumbles at stoplights. [Re: WheelsUp73] #1090049
10/08/11 07:29 PM
10/08/11 07:29 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
On my wagon, when it was my everyday driver, I kept having a problem of the mounting bolts for the carb (TQ) working loose (heat cycling and plain ol' vibration was my guess). Car would be running fine, then one day, the idle would be a little funky. Nothing severe, just enough to get your attention.
And, yes, I tried thread lock, but, I still had the problem.
I just got used to checking the bolts on a regular basis.
(if it matters, I'm running a stock intake).
John
