Re: Aluminum fuel line: thoughts and opinions please!
[Re: slowpoke]
#1089358
10/06/11 10:01 PM
10/06/11 10:01 PM
Challenger 1
Cincinnati, Ohio
I was thinking of using it as it would be easier to form. I ran the 3/8 line that's there now and it was a bear to bend. I'm probably going to show my ignorance here, but what is the "softer steel" and where do you get it? Can it be formed easier than the brake line steel lines? Thanks again!
Auto parts store sell it in 25' coils. I recently bought a roll of 3/16 for brake line replacement on a pickup truck. 3/16 I could bend by hand easy enough, 3/8" your gonna need a tubing bender to do it decent. It's not as hard as it appears in your mind, once you do it, it feels great! The reason everyone wants to say aluminum is fine is because there afraid to try to bend steel, don't be scared!!
[Re: slowpoke]
#1089361
10/06/11 10:36 PM
10/06/11 10:36 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
FWIW...I replaced the fuel line on my Demon race car this year.I used STEEL line.It's not hard to form or bend if you take your time.I bought a 25ft coil off EBay and used fittings and flared it at the fuel pump and regulator.Nice and neat,and I don't have to worry about the line cracking or any other sort of damage like you would with aluminum.
I had Aeroquip fuel line hose(not braided) and it worked,but finally needed replacing after MANY years.
[Re: DAYCLONA]
#1089364
10/07/11 09:19 AM
10/07/11 09:19 AM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
NAPA used to sell an easy bend steel line in 25 ft coils.It wasnt super easy to bend but was better than reg steel line.I wish I had a dollar for every foot of fuel and brake line Ive replaced in the last 30 some years at work.Any line can crack and or spring a leak.Look at most new cars they run plastic line.Repaired and replaced a bunch of those also.Rocky
Chrysler Firepower
[Re: jcc]
#1089365
10/07/11 12:08 PM
10/07/11 12:08 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
If your aluminum is cracking, you are using the wrong aluminum or its installed wrong. You DO NOT double flare aluminum, you need specific radius bends for each specific line, Aircraft vibrate much more than most race cars, they have been using it for decades and no issues when done correctly. Tim
I'd never use aluminum; only advantages are weight and ease of forming and the weight is negligeable and mild steel isn't hard to form. disadvantages are aluminum is brittle and prone to stress cracks.....not something I'd want for a fuel line. Steel or SS
Exactly. With todays gas, there will be problems with aluminum lines sooner than later too. For a street car it's much more dangerous than a race car.
I am not sure it correct to compare an airplane to a car. No fuel corrosion issues, not sure hitting a pot hole/curb is the same as being buffeted, little road debris at 5,000 ft, most lines in a plane are enclosed, and weight is a bigger issue aloft, routine inspections are required in aircraft but cars are more install and worry about when there is problem, and not much reason to worry about a fender bender in the air. However the concept of properly installing a fuel line likely is valid for both.
Yep, apples and oranges; there is a good reason to use aluminum in an airplane, but not on a street car which is subjected to far more abuse and virtually never inspected.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
