Re: Old mp tach drive distributor cap and rotor
[Re: sbdemon]
#1087750
10/03/11 06:34 PM
10/03/11 06:34 PM
Call Todd Marsh 336 752 2879 I have the part numbers for those somewhere but can't locate right this minute--it is available form normal places if you have the #'s will look harder send me a PM and when I find I will send to you
[Re: sbdemon]
#1087751
10/03/11 06:35 PM
10/03/11 06:35 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
accel has one that works... accel 8330 accel is temporary out of stock.... summit shows this one as a substitute http://www.summitracing.com/parts/TAY-918220/
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: rt66jim]
#1087753
10/04/11 01:48 PM
10/04/11 01:48 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
The cap/rotor that fits the "prestolite" ignition is the same.
[Re: sbdemon]
#1087754
10/04/11 04:24 PM
10/04/11 04:24 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Cap/rotor for 440 Hp with dual points(cast iron distributor) is the same as tach drive.Prestolite made both for Mopar.
[Re: sbdemon]
#1087756
10/05/11 06:31 PM
10/05/11 06:31 PM
Posts: 70 Steeler Country
scottydog
Steeler Country
Sunroofgtx Rick Gorski sells them. www.customwiresets.com They are the thick compression molded USA ones.
I mostly enjoy golfing in the 70's.. The eighties are just too hot, and 60's I usually get chilly !!
[Re: scottydog]
#1087757
10/09/11 06:56 PM
10/09/11 06:56 PM
Posts: 11,915 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
I have the HD ribbed versions....tan,black,with brass/copper inserts...USA MADE no vents...rotors also....at least 150+ caps and 50 rotors...odds are nobody has more...in stock
