Old mp tach drive distributor cap and rotor #1087749
10/03/11 06:05 PM
10/03/11 06:05 PM
Sweden
sbdemon Offline OP
sbdemon  Offline OP
Sweden
Hi, does anyone here know if there still is an cap and rotor for the old mp tach drive distributor p4120701 available?
there used to be a cap and rotor set p4120886 but i can not find it at Mancini or summit.
sbdemon
Re: Old mp tach drive distributor cap and rotor [Re: sbdemon] #1087750
10/03/11 06:34 PM
10/03/11 06:34 PM
Call Todd Marsh 336 752 2879 I have the part numbers for those somewhere but can't locate right this minute--it is available form normal places if you have the #'s will look harder send me a PM and when I find I will send to you
Re: Old mp tach drive distributor cap and rotor [Re: sbdemon] #1087751
10/03/11 06:35 PM
10/03/11 06:35 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
accel has one that works...
accel 8330
accel is temporary out of stock....
summit shows this one as a substitute
http://www.summitracing.com/parts/TAY-918220/
Tony
70 AARCuda Vitamin C
Re: Old mp tach drive distributor cap and rotor [Re: 70AARcuda] #1087752
10/04/11 01:18 PM
10/04/11 01:18 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I have the NAPA #'s at home if you want them? just don't have them here at work. Jim
Re: Old mp tach drive distributor cap and rotor [Re: rt66jim] #1087753
10/04/11 01:48 PM
10/04/11 01:48 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
The cap/rotor that fits the "prestolite" ignition is the same.
Re: Old mp tach drive distributor cap and rotor [Re: sbdemon] #1087754
10/04/11 04:24 PM
10/04/11 04:24 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Cap/rotor for 440 Hp with dual points(cast iron distributor) is the same as tach drive.Prestolite made both for Mopar.
Nautilus Racing-
Re: Old mp tach drive distributor cap and rotor [Re: Chris2581] #1087755
10/05/11 05:49 PM
10/05/11 05:49 PM
Sweden
sbdemon Offline OP
sbdemon  Offline OP
Sweden
Thank you all for your help, i really appreciate it.
sbdemon
Re: Old mp tach drive distributor cap and rotor [Re: sbdemon] #1087756
10/05/11 06:31 PM
10/05/11 06:31 PM
Steeler Country
scottydog Offline
scottydog  Offline
Steeler Country
Sunroofgtx Rick Gorski sells them. www.customwiresets.com They are the thick compression molded USA ones.
I mostly enjoy golfing in the 70's.. The eighties are just too hot, and 60's I usually get chilly !!
Re: Old mp tach drive distributor cap and rotor [Re: scottydog] #1087757
10/09/11 06:56 PM
10/09/11 06:56 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
I have the HD ribbed versions....tan,black,with brass/copper inserts...USA MADE no vents...rotors also....at least 150+ caps and 50 rotors...odds are nobody has more...in stock
