I run a set of the thrush glass packs on my truck
the pop pop comes from haveing to small of a glass pack
I run headers with 2.25 pipes back to 2.5 glass packes with 2.5 tail pipes then have duel 3" 15" echo tips
mine has a nice deep rumble and has a deep throaty sound that gets real loud at WOT
never has any poping when backing down from high rpms
I will be running a set of 3" thrush glass packs bolted right to the headers and have about 4' of 3" tail piped turned out in front of the rear tires on the 88 440 truck
![](/ubbthreads/images/graemlins/thumbs.gif)
you might get rid of the pop pop by adding larger tail pipes after the muffs to reduce some back pressure.
sounds like you have the 2" glass packs if they do a lot of the pop pop
![](/ubbthreads/images/graemlins/shruggy.gif)
you did not say what size yours are.
![](/ubbthreads/images/graemlins/Twocents.gif)
