Well now it's decision time....
#1086807
10/02/11 01:32 PM
10/02/11 01:32 PM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
After inspecting and resetting the valve lash this morning it all looked good but now I see where the pushrods are touching the heads. The new HS rockers required a .280 longer pushrod and that has moved it closer to the intake side of the head. So now the heads have to come back off, OK I can deal with that but since this engine stalls my 4200 converter to 6000 now I'm thinking it makes way more power than I anticipated so I'm considering putting a single 4 back on it instead of the TR. I have a large port M1 and a small port M1 for the W5's. Just not sure what to do now.
It's always something.
Re: Well now it's decision time....
[Re: Guitar Jones]
#1086809
10/02/11 02:47 PM
10/02/11 02:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would put the large port on... it will reduce your torque some so it will reduce the stall point some ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1086810
10/02/11 03:28 PM
10/02/11 03:28 PM
Guitar Jones
That's what I was thinking, but man I want to make at least a couple passes with TR. You know, just for a baseline of course. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: MR_P_BODY]
#1086812
10/02/11 03:55 PM
10/02/11 03:55 PM
Posts: 3,695 nc
emarine01
nc
Reduce torque ... ... .... .... ..... .... Torque is your friend.... they sell bigger tires & smaller gears ![](/ubbthreads/images/graemlins/beer.gif)
[Re: emarine01]
#1086813
10/02/11 05:00 PM
10/02/11 05:00 PM
Guitar Jones
I'm using the only pro gear ratio available for my 8.75, a 4.86. I could put a taller tire on it though, Maybe it's time for a 'glide, have to think long and hard about that one.
Anyway now that I have the intake and the rockers off I can see where the PRs are touching and it's slight, just at the top of the hole and not all of them are rubbing, only ten are so I don't need much. I'm going to try to get it clean and dry, mask it all off with duct tape and just hand file it. Wish me luck. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: emarine01]
#1086814
10/02/11 05:02 PM
10/02/11 05:02 PM
MR_P_BODY
He said with what he had... and I would think that a 6000 stall point would be above his torque ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1086815
10/02/11 07:28 PM
10/02/11 07:28 PM
Guitar Jones
Masked it all off after cleaning it real good with laquer thinner and clearanced them on the car, carefully used a shop vac to get all the pieces I could then dusted it off with a blower. Peeled the tape off and only maybe 4 filings on the head. Used the shop vac sucked them up. Success!!! I so did not want to pull the heads. ![](/ubbthreads/images/graemlins/laugh2.gif) Now that the intake is off though I'm going to take a look at the cam lobes position using the different valve lash adjustment procedures. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Guitar Jones]
#1086817
10/02/11 08:08 PM
10/02/11 08:08 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Survive, Adapt, Improvise... ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: MR_P_BODY]
#1086818
10/02/11 09:11 PM
10/02/11 09:11 PM
Posts: 3,695 nc
emarine01
nc
Mike... I was just messin with ya ![](/ubbthreads/images/graemlins/biggrin.gif)
