Good trans shop in Mass? #1085861
09/30/11 08:35 PM
09/30/11 08:35 PM
People's Republic of Mass.
Belvedere2 Offline OP
Looking to get my driveshaft balanced. Also get my tailshaft leak fixed; think its the bearing since replacing the rear seal didn't help. Any good shops in Mass preferably in the South Shore area? Thanks.
Re: Good trans shop in Mass? [Re: Belvedere2] #1085862
10/01/11 09:26 AM
10/01/11 09:26 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
A transmission shop is going to send your driveshaft out to a driveline shop to have it balanced , they don't have the equipment usually to do that .
Where is your leak on the trans ? what year is the car you are dealing with ?
Re: Good trans shop in Mass? [Re: JohnRR] #1085863
10/01/11 10:57 AM
10/01/11 10:57 AM
The leak is at the tailshaft seal. I've replaced the seal and used sealant. Still leaks out. Made sure I lubed up the seal before I put it in so it wouldn't tear.
Re: Good trans shop in Mass? [Re: Belvedere2] #1085864
10/01/11 11:06 AM
10/01/11 11:06 AM
JohnRR Offline
JohnRR  Offline
Is there a lot of up and down movement on the yoke in the back of the trans? What does the yoke look like ? Did you use a Booted seal like the factory ? There was a change over on rear yoke design where a seal used to be internal to the trans.
What year is the car in question , is it the original driveshaft and yoke ?
Re: Good trans shop in Mass? [Re: JohnRR] #1085865
10/01/11 11:19 AM
10/01/11 11:19 AM
Used the booted seal. It's the original yoke and shaft. At least I think so not sure. Doesn't seem loose. The seal vibrated its way off thats why I am getting the shaft balanced. Drove it on the highway and it vibrates in a certain rpm range. So I replaced the seal used sealant and it still leaks. Comes from where the yoke meets the seal.The trans is not original; bought a street/strip trans.
Re: Good trans shop in Mass? [Re: Belvedere2] #1085866
10/01/11 12:27 PM
10/01/11 12:27 PM
JohnRR Offline
JohnRR  Offline
one more time .... WHAT YEAR CAR ????????????????????????????????
Re: Good trans shop in Mass? [Re: JohnRR] #1085867
10/01/11 01:32 PM
10/01/11 01:32 PM
Sorry 67 Belvedere. But like I said trans is not original and I don't think the driveshaft is either.
Re: Good trans shop in Mass? [Re: Belvedere2] #1085868
10/01/11 05:11 PM
10/01/11 05:11 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
there is also a bushing.the seal should not have vibrated off.it was not installed correctly.
Re: Good trans shop in Mass? [Re: Belvedere2] #1085869
10/01/11 05:41 PM
10/01/11 05:41 PM
JohnRR Offline
JohnRR  Offline
You are sure it's leaking from the seal and not the backside of the yoke ? There is a yoke that has no plug in the back of it and the seal was on the transmainshft inside the trans , this yoke didn't have the double wide spline , if you put this yoke on a trans without the internal seal you will have a leak. But as stated you would have had to have one heck of a vibration to knock the seal out .
Re: Good trans shop in Mass? [Re: JohnRR] #1085870
10/01/11 06:21 PM
10/01/11 06:21 PM
Leaking from seal. I can see it right at the end of the seal lip. I made sure the surface was not gouged or anything when I put the new one on. Used a lite layer of sealant when I put it back on. Left it sitting there for a day to make sure it dried.Fired it up then drove it backwards. Checked it and it was leaking. Made sure I put some trans fluid on the inside lip so it wasn't dry and rip.
The seal came off when I drove it down the highway for about an hour or so. Driving about 60 mph. Did not leak before this and I have driven it about 1500 miles around town. When I stopped I could see the seal sitting on the shaft.
As far as the vibration goes it vibrates between 50 to 60 mph. I sort of noticed it before but really noticed it w/ the 4.10s on the highway. Thats why I figured the driveshaft is out of balance. The new gears buzzed the engine higher on the highway and made it more noticeable.
Thanks for the help.
