Double pump or vacuum secondaries #1085341
09/29/11 08:52 PM
09/29/11 08:52 PM
USA
Lawn Monkey Offline OP
USA
440 ,30 over bore, 509 cam, tube headers and a Torker intake waht kind of Holley carb will work well double pump or vacuum secondaries and how about cfm?
Re: Double pump or vacuum secondaries [Re: Lawn Monkey] #1085342
09/29/11 08:55 PM
09/29/11 08:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
DP... 850 or 950 depending what you do with the car
Re: Double pump or vacuum secondaries [Re: MR_P_BODY] #1085343
09/29/11 08:57 PM
09/29/11 08:57 PM
USA
USA
Its a full body Challenger, 4 speed , 4.10 Dana just going to the track on a trailer nothing else.
Re: Double pump or vacuum secondaries [Re: Lawn Monkey] #1085344
09/29/11 09:04 PM
09/29/11 09:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe in bigger carbs but that is dependent on
how many revs you go to... I run a 1050 dom on a 405ci
but turn 8200
Re: Double pump or vacuum secondaries [Re: MR_P_BODY] #1085345
09/29/11 09:10 PM
09/29/11 09:10 PM
USA
USA
Too soon to tell on the revs, I plan to hammer it but its just a 30 over 440 with flat top 10.5 TRW's with balanced crank rods and pistons so I don't know but maybe 6,000 rpms ,,,will see..
Re: Double pump or vacuum secondaries [Re: Lawn Monkey] #1085346
09/29/11 11:04 PM
09/29/11 11:04 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use a Holley 750 DP on my 440,and the cam is the 296/557.Plenty of carb.I tried the 850 we have and it didn't run any faster.
Nautilus Racing-
Re: Double pump or vacuum secondaries [Re: Chris2581] #1085347
09/29/11 11:31 PM
09/29/11 11:31 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
I'll bet that a well prepped 750/780 vac will run as well as any DP you would try on that setup. It's a familiar test bed that I've done with three carbs in the past...780VS/750DP/850DP. No reference to my current SB drag Aspen, which also sports a modded 780 vac that works better than the DP.
