Re: Turbocharging for economy
[Re: feets]
#1085128
10/11/11 03:31 PM
10/11/11 03:31 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Now you guys went and made him angry.
[Re: feets]
#1085130
10/11/11 04:35 PM
10/11/11 04:35 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
I'm out of this one.
Maybe your blood pressure will go down some then! Geez, it's just a web board with a question...
[Re: Mr.Yuck]
#1085134
10/17/11 12:51 PM
10/17/11 12:51 PM
Posts: 22,783 Bitopia
jcc
Bitopia
I guess the First law of thermodynmics does not apply to turbos. I always thought heat/energy sent out the exhaust was wasted and deducted from the total efficency of the engine. I also thought using that wasted exhaust heat and energy to spin a turbo was beneficial to improving cylinder filling. I also thought it if it took x amount of gallons of fuel to move a car y amount of miles and z amount of heat went out the exhaust, by lowering z I could go Y+ miles or use x less gallons. Guess I was wrong. http://en.wikipedia.org/wiki/First_law_of_thermodynamics
[Re: jcc]
#1085135
10/17/11 04:09 PM
10/17/11 04:09 PM
Posts: 6,608 Indiana
EV2DEMON
The Camaro Kid
The Camaro Kid
Indiana
Guess I was wrong. ![](/ubbthreads/images/graemlins/eyes.gif)
That's not necessarily wrong, but, again, fails to account for the fact that while traveling at low-load highway speeds, a turbocharged IC gas engine is still making vacuum and not seeing any boost or associated benefits. So, the heat passing through the turbo and out the exhaust is still "wasted".
Pretty sure that was covered on the first page though.
[Re: jcc]
#1085138
10/18/11 12:15 AM
10/18/11 12:15 AM
TRENDZ
Milwaukee WI
No, It's because if it was making boost it would be accellerating. If it's not making boost it's a parasitic loss. IF YOU ADD MORE AIR YOU NEED MORE FUEL.
